There was a bottleneck in the mail server queue that's now been resolved, so you're just seeing your share of the backlog as it clears.
If it's any consolation I think many people (including me) are also getting them.
Yep, definitely getting them too, but I hoped that it was the backlog clearing, as the dates seem to be 'catching up' to real time step by step, or at least I'm hopeful that this is what is happening...
(2017-11-02, 00:08)Klojum Wrote: [ -> ]There are currently two font sizes for text links. The one created by the [url] tag is slightly smaller than normal.
should by fixed once the css cache expires
(2017-10-31, 20:54)Klojum Wrote: [ -> ]The radio buttons in the member listing are upsetting the dropdownlistbox on the far right.
should also be fixed once the css cache expires
(2017-10-08, 12:42)ronie Wrote: [ -> ]responsive design issue: login button gets hidden below the header
should be fixed once the css cache expires
(2017-10-06, 09:46)Kib Wrote: [ -> ]Required Plug-ins
both installed
test xml highlighting:
xml:
<?xml version="1.0" encoding="utf-8"?>
<window>
<defaultcontrol always="true">50</defaultcontrol>
<views>50,51,52,53,58</views>
<menucontrol>9000</menucontrol>
<controls>
<include>DefaultBackground</include>
<control type="group">
<include>ContentPanel</include>
<include>Fanart</include><!-- view id=50 -->
<include>List</include><!-- view id=51 -->
<include>FullList</include><!-- view id=52 -->
<include>Thumbnail</include><!-- view id=53 -->
<include>MediaInfo</include><!-- view id=58 -->
<include>PageControls</include>
<include>ScrollLabel</include>
</control>
<include>SideMenu</include>
</control>
<include>Header</include>
<include>Footer</include>
<include condition="Skin.HasSetting(TouchScreenMode)">TouchScreenControls</include>
<include condition="Skin.HasSetting(DebugMode)">debuginfo</include>
<include>PageFade</include>
</controls>
</window>
I've subscribed to some threads and am mostly watching them in the user control panel. Since the new forum is used, they are being marked as unread all the time, although there aren't any new posts. 2 Days ago I've marked the whole forum as read, went to UCP and they were still bold=unread. Clicked at each of the thread and they were marked as read again. Yesterday two of them got new topics and have been marked as unread, which is correct. I haven't read them yesterday and wanted to do it now, but now all of the subscribed threads are marked as unread again, which is wrong.
edit:
Sorry, just noticed the "Cannot / will not fix" section in the third post of this thread
Quote:[...]
Subscription list- cannot mark read (post 48 111) (can't fix. mybb bug?)
Sounds similar to my description of the issue...
(2017-10-31, 20:57)Klojum Wrote: [ -> ]Aren't the thread titles on the right on the forum frontpage on a very tight leash?
should be a lot better now.
(2017-10-15, 20:12)Milhouse Wrote: [ -> ]Code tags are being stripped from posts when they are previewed or posted-then-edited (may only be on "complex" posts with lists?)
The new editor seems to have fixed this issue - thank you thank you thank you!
Only gripe would be that it keeps popping up the "Auto Saved" message every 10 seconds - can this popup be disabled completely?
Quote:[*]imgbb mod - to allow image uploading to imgbb and for image link to be placed directly in post.
[*]if one marks a text, to get the option to quote that specific marked text in the next reply (slack)
[*]Full screen editor is glitchy (post 332)
all these should now be fixed / implemented as we've switched to a different editor.
(2017-11-09, 02:10)Milhouse Wrote: [ -> ]Only gripe would be that it keeps popping up the "Auto Saved" message every 10 seconds - can this popup be disabled completely?
i'll have to tweak the css a bit to hide it, stay tuned ;-)
(2017-11-10, 04:07)Oli_Oops Wrote: [ -> ]https://forum.kodi.tv/showthread.php?mod...pid2343346
Post #1 does not seem to actually be the first post.
Hello Oli_Oops
It is strange way to start off a thread, but not unusual. Some members start writing in the Title then continue on in the main text box (which I hate as sometimes we quickly glance over the thread title)
It is also possible the thread was split from another thread.
Is there something else that makes you think it is wrong?
In the overview of the Thread Subscriptions the checkbox "Select all" in the column header area is at the wrong place. It's between the labels "Replies" and "Last Post", but should be at the most right position just like the checkboxes for single selection of each thread.
