2020-04-26, 15:23
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
2020-04-27, 10:57
2020-04-28, 08:47
Since upgrading should moving scraping take so long? I think it has something to do with trailers as movies with no available trailer take a very short time to scrape, others take sooo long...
Anyone else have this happening?
I just did a scrape that downloaded a 100MB trailer so slowly...
Spec of the trailer was
Width : 1 920 pixels
Height : 816 pixels
What should my trailer settings be for a high quality trailer download? What source is the best? Is it because i have more than one source selected?
Height : 816 pixels
2020-04-28, 11:41
(2020-04-28, 08:47)ping182nz Wrote: [ -> ]Since upgrading should moving scraping take so long? I think it has something to do with trailers as movies with no available trailer take a very short time to scrape, others take sooo long...More enabled scraper = more time to parse websites, but the biggest problem is that YouTube and Apple limits the download speed (not scraping speed) extremely (i think Apple more than YouTube).
Height : 816 pixels
Nearly 100% of the trailers on DavesTrailerPage are trailers that will be downloaded from Apple.
Nearly 100% of the trailers on TMDb are from YouTube.
Apple trailers are logically from Apple.
So there isn't really much to adjust. I've setup my preffered quality to 720p, that should be enought for a trailer and takes long enought to download.
2020-04-30, 20:43
anyone know if fanart.tv is still dead in the water? Seems to not show results for me still.
2020-04-30, 22:24
(2020-04-30, 20:43)thrashmagazine Wrote: [ -> ]anyone know if fanart.tv is still dead in the water? Seems to not show results for me still.
Experiencing the same issue.
2020-05-01, 00:33
2020-05-01, 02:34
Yep Nothing scraping from fanart.tv site. Site is up and all is accesible. So is the issue on ember side ?
2020-05-01, 10:27
2020-05-01, 13:59
(2020-05-01, 10:27)DanCooper Wrote: [ -> ]Hmmm, works for me. Any hints in the log?Working now, it seems it was fanart problem.
2020-05-01, 20:52
Question I use Ember for scrapping in Episodes of Svengoolie. I get the Svengoolie-S01E88-Berserk -.nfo which works but when I put in Svengoolie-S01E88-Berserk - thumb.jpg manually in the same folder KODI doesnt show the Poster instead its a Photo clip of a scene from the movie any tips how to correct this ?
Here is the nfo
<?xml version="1.0" encoding="utf-8"?>
<episodedetails>
<xsport>False</xsport>
<xrecorded>2020-01-25</xrecorded>
<xaffiliate>MeTV-E</xaffiliate>
<title>Berserk</title>
<showtitle>Svengoolie</showtitle>
<season>1</season>
<episode>88/episode>
<plot>A scheming circus owner finds her authority challenged when the show is targeted by a vicious killer.</plot>
<thumb />
<mpaa />
<actor>
<name>Rich Koz</name>
</actor>
<genre>other</genre>
<genre>anthology</genre>
<premiered />
<aired>2020-01-25</aired>
<studio>WGAL MeTV</studio>
<fileinfo>
<streamdetails>
<audio>
<channels>2</channels>
<codec>ac3</codec>
</audio>
<video>
<codec>mpeg2video</codec>
<durationinseconds>6850</durationinseconds>
<height>480</height>
<language />
<longlanguage><Default></longlanguage>
<width>704</width>
</video>
</streamdetails>
</fileinfo>
</episodedetails>
Here is the nfo
<episodedetails>
<season>1</season>
<thumb />
<mpaa />
<actor>
</actor>
<premiered />
<fileinfo>
<streamdetails>
<audio>
<codec>ac3</codec>
</audio>
<video>
<language />
<width>704</width>
</video>
</streamdetails>
</fileinfo>
</episodedetails>
2020-05-01, 23:33
(2020-05-01, 20:52)Rickt1962 Wrote: [ -> ]when I put in Svengoolie-S01E88-Berserk - thumb.jpg manually in the same folder KODI doesnt show the PosterYou have to press F5 in Ember so that the poster will be recognized. If you use the Kodi Interafec the poster can be synced. If you don^t use the KI then you have to manually reload the episode via Information dialog in Kodi.
2020-05-03, 03:50
2020-05-03, 05:05
(2020-05-03, 03:50)ping182nz Wrote: [ -> ]Is it because of the ' in Can't?Yes. The DavesTrailerPage scraper has this bug atm.
2020-05-03, 07:23
I'm new to this program so forgive me about this question, ISO file scanning can only be done with VCDmount and DTAgent executables? What do they do? Are they only used to mount the ISO files?
Edit: I also want to make a request, can you please add Spanish-MX to the supported languages? TMDB has two separate languages for Spanish, one for Spain and the other for Latin America (which is ES-MX).
Thank you!
Thank you!
