2009-10-02, 13:07
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
2009-10-02, 13:13
Good to hear!
2009-10-02, 14:39
Got everything installed fine now, but once it restarts it goes straight into the terminal, why would it do this?
2009-10-02, 14:46
Have you downloaded xbmscript and installed xbmc? does /etc/init.d/xbmc-live exist? What kind of hardware do you have?
2009-10-02, 16:16
No worries all working now. Much better than it was before super smooth mkv playback excellent piece of work to make this so easy to do
2009-10-02, 19:56
UPDATE 10-02-2009
For this feature I would like to give a special shout out to:
walmis: for the ps3_pair program. Without him the ps3 remote pairing would be a lot more difficult! Be sure to check out http://blueman-project.org for the best bluetooth applet on GNOME!
kubax: for all the brainstorming and bluez headaches we shared together
ruff: ps3 remote powersaving and keymapping patches
For a technical explanation of his this (finally!) got working, see: http://forum.xbmc.org/showpost.php?p=412...tcount=168
- PS3 Bluetooth Remote support. A very special thanks to walmis (blueman developer)
- Fixed minor bugs and redesigned the questions asked on installation
2009-10-03, 11:32
Great script, but everytime i try to update to a svn i get a black screen after boot ... i changed the /usr/bin/xbmc/skin/PM3.HD/skin.xml to 3.0 but that doesnt help.
Any hints ?
Any hints ?
2009-10-04, 11:46
Hi!
Great work, but I have some noob-questions.
I made a fresh install and have chosen the stable release. But how can I upgrade to the latest release? Can I run your script again?
When I choose "Exit XBMC" I can write something, but nothing will happen. :/
*attention total linux noob*
Will I be able to add two HDDs later?
2009-10-04, 13:51
Use option 2 to upgrade to the latest svn version. If you exit xbmc, you have to hold ctrl+alt+F1 to go to a terminal that allows input
you can add hdd's later as long as you properly format and mount them in linux. There are a lot of guides online on how to do this.
2009-10-04, 14:07
flxfxp Wrote:If you exit xbmc, you have to hold ctrl+alt+F1 to go to a terminal that allows input
I thougt so, but it didn't do anything. Maybe it's because of my Apple-Keyboard. I started all over again, and have chosen an Mac-Keyboar. Maybe it will work.
One additional question:
Right at the beginning your script is asking me which NVIDIA drive should be installed.
1, Nvidia Linux Display Driver 180
2, Nvidia Linux Display Driver 185
3, Nvidia Linux Display Driver 190
And there is a link to the VDPAU-Article on Wikipedia.
But I have no clue which I should choose. I'm using an an ION-based Mainboard.
Is 180/185/190 referred to "NVIDIA Feature Set" A/B/C?
180 = A
185 = B
190 = C
2009-10-04, 14:43
This has todo with the feature sets. 190 is the latest and pretty stable, you should go with that. The other 2 I've kept in the list are mainly for compatibility reasons :-)
i don't know about the keyboard, try a regular one if in doubt.
Dennis
Dennis
2009-10-04, 20:55
Even if I wasted an entire Sunday... I solved my problem.
Before running the Script, I installed a desktop:
sudo aptitude -y install xserver-xorg-core xinit menu menu-xdg jwm fluxbox alsa-utils mrxvt gdebi-core synaptic logrotate localepurge
Then, I fixed the issue with the fn-Key on the Mac-Keyboard:
Opened a terminal: sudo nano /etc/modprobe.d/hid_apple.conf
Added this line to the opened file: options hid_apple fnmode=2 and saved it.
Terminal: sudo update-initramfs -u
Then I started your script and installed the stable build. Thanks to the previously fixed keyboardsetting I was able to start the terminal: (right) CTRL + (left) ALT + F2
Tomorrow I will reinstal everything with an normal PC-Kayboard. But I have defeated the ugly Apple-Linux-Dragon on my own. :lol:
2009-10-05, 11:03
How do I get all sound to output via spdif? Films output from this, but when I play music, it goes via the hdmi to the tv
2009-10-05, 19:46
do i really need to use
Ubuntu 9.04 “Jaunty Jackalope” Minimal CD
if i have xbmc live installd...cant i use it?
2009-10-05, 19:49
Nope, since xbmc-live is already pre-configured.
