hi taxigps.. do you think you can add
www.letv.com into your repo as well? they do have some shows which your current repo do not provide. would greatly appreciate
Is there any chance to add support to
http://hd.tv189.com/ ? The website offers some video streams at 1080P.
taxigps Could you please make the Chinese input script
universal? The one right now only works in So-movie plug-in, which is fine but not great.
Users might have a difficult time to rename movie name or modify menu name in Chinese.
Actually, few knows how to do that.
I'm trying to get my PPstream running from XBMC but to no avail.
I have installed the latest repository and manage to get "PPstream" from the add-ons and also able to view the latest list of shows (Including TVB) but i'm not able to play any videos at all.
Whenever i click on a video, there is just no response and no sign of "working" on bottom right.
Hope to have someone kind enough to help me out.
Note: I'm using windows XP and able to run PPS normally if execute from windows.
Please refer to the below site to submit in the xbmc.log for the PPStream problem that you observed.
http://code.google.com/p/xbmc-addons-chi...eBugReport
General Info:
a. PPStream site tends to be overloaded during evening time. Access to the site may fail.
b. Ensure you do not have any proxy setup in your system.
c. Certain vidio item on PPStream is disallowed to playback on certain region due to copyright.
d. Try to use the search function (top item list on ppstream main menu) to see if you are able to playback any search video item at all.
Hi cmeng,
Thx for the response. I have logged the issue into the link provided as i have verified the 4 general checking already.
The PPStream is working, no proxy on my computer, able to stream video from search & not region restricted
And are there anyway to open videos from sugoideas.com thru xbmc?
Thanks a lot
(2012-04-06, 04:05)cmeng Wrote: [ -> ]Please refer to the below site to submit in the xbmc.log for the PPStream problem that you observed.
General Info:
One issue with sohu video plugin. After select backup server, it working. But whenever I select a video to play, it wait 20 to 30 seconds before "Working ..." appear. Is this normal?
thanks for the plugin. Just to make sure, with eden on linux, am I still supposed to do special hacks to get chinese characters instead of squares (which is indeed what I get)?
I already have the arial font, but sure enough, I get the squares.
Are the current instructions still on
http://code.google.com/p/xbox-remote/wik...torForXBMC ?
(I do want the font to show all characters, but I'd like the main interface to remain in English).
Thanks,
Marc
myth:~$ find /usr 2>&1 | grep -i arial
/usr/share/fonts/truetype/msttcorefonts/Arial_Black.ttf
/usr/share/fonts/truetype/msttcorefonts/Arial_Bold.ttf
/usr/share/fonts/truetype/msttcorefonts/arial.ttf
/usr/share/fonts/truetype/msttcorefonts/Arial_Bold_Italic.ttf
/usr/share/fonts/truetype/msttcorefonts/Arial.ttf
/usr/share/fonts/truetype/msttcorefonts/ariali.ttf
/usr/share/fonts/truetype/msttcorefonts/arialbd.ttf
/usr/share/fonts/truetype/msttcorefonts/arialbi.ttf
/usr/share/fonts/truetype/msttcorefonts/Arial_Italic.ttf
/usr/share/xbmc/media/Fonts/arial.ttf
(2012-04-18, 19:41)marcmerlin Wrote: [ -> ]thanks for the plugin. Just to make sure, with eden on linux, am I still supposed to do special hacks to get chinese characters instead of squares (which is indeed what I get)?
Are the current instructions still on http://code.google.com/p/xbox-remote/wik...torForXBMC ?
Thanks,
Marc
You may try the following method. It is for Windows. So you need to find where is the xbmc home directory on Linux. If I am not wrong, it should be under ~/.xbmc.
http://wiki.xbmc.org/index.php?title=XBM...ed_squares
Thank you. All I had to do on linux was to switch the font to 'arial based' instead of skin default since my linux system already came with Arial.
I wonder why Arial is not auto detected and used when it's present.
(2012-04-19, 16:50)marcmerlin Wrote: [ -> ]Thank you. All I had to do on linux was to switch the font to 'arial based' instead of skin default since my linux system already came with Arial.
Arial font in xbmc is a full range font, can support almost all language. But skinner like to use some other art font. So default font set not use arial.
Added plugin.video.tv189 - Online tv and movies from
http://www.tv189.com, support by China Telecom (Chinese)
Nice job for the new plug-in tv189! Thanks
BTW,please fix the Qiyi and PPTV IPAD.
tv189 plug-in not working any more!
It won't show any list!!!!!!
