Full Version: [RELEASE] Project xbmc-addons-chinese (Chinese addons for Kodi)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42
EDIT: Opps, nope its working fine - was my connection playing up XD
Tudou does not seem to work anymore =(
(2012-09-24, 02:54)kimmy2000 Wrote: [ -> ]EDIT: Opps, nope its working fine - was my connection playing up XD
The Sohu Tv live didn't work for me. (Only No.6 zhejiang worked but not the others)
Newest version.
No script error message,however, "buffer,waiting a minute" then nothing shows up.
(2012-08-28, 11:58)ailingcoot Wrote: [ -> ]First, thanks again for all the great plug-ins( the Yinyue Tai is actually much better)
Another question, is there any chance to add support to pptv.com( not p2p,just the website itself) . There are some stuffs can't be found elsewhere. It is also possible that XMBC could get their "HD" content directly.
Trying, but facing a major problem. The final media access link requires a key (believe to be MD5), so far unable to generate this.
Thanks for this great project. I tried both versions (Eden & Dharma) on my Rapsberry Pi (RaspBMC), they worked great. Only PPStream didn't work. I look forward to the future updates on this project.
Keep up the good work!!!!
has anyone got a reliable link to watch hong kong TVB?
I had a look at a new mediabox named TVPAD, it is a kind of Android box. It has two apps seems to be very good to show all the TVB channels. Unfortunately i has beend packaged with encryption wth file format as .pkg
anyone now how to get the link off those package?
http://www.tvpadzone.com/english/download/apps300.html
I keep getting the script failed error on plugin.video.youku. I am using the xios linux xbmc version 12.
here is the log file for the above script error when loading the show from Letv
02:07:58 T:1135809632 NOTICE: Thread Background Loader start, auto delete: false
02:07:59 T:1135809632 DEBUG: Thread Background Loader 1135809632 terminating
02:07:59 T:1241113696 NOTICE: getHttpData: http://www.flvcd.com/parse.php?kw=http:/...l&format=0
02:07:59 T:1093865120 DEBUG: ProcessMouse: trying mouse action leftclick
02:07:59 T:1093865120 DEBUG: CGUIMediaWindow::GetDirectory (plugin://)
02:07:59 T:1093865120 DEBUG: ParentPath = []
02:07:59 T:1292977248 ERROR: Unable to find plugin
02:07:59 T:1093865120 ERROR: GetDirectory - Error getting plugin://
02:07:59 T:1093865120 ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
02:07:59 T:1093865120 DEBUG: CGUIMediaWindow::GetDirectory ()
02:07:59 T:1135809632 NOTICE: Thread Background Loader start, auto delete: false
02:08:00 T:1241113696 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnboundLocalError'>
Error Contents: local variable 'match' referenced before assignment
File "/root/.xbmc/addons/plugin.video.letv/default.py", line 1044, in <module>
PlayVideoLetv(name,url)
File "/root/.xbmc/addons/plugin.video.letv/default.py", line 876, in PlayVideoLetv
playVideo(name,url,videoRes)
I am having trouble with sohu addon in xbmc, I got script failed for plugin.video.sohuvideo all the time. It was working couple days ago but suddenly it stopped working
atv2 jailbreaked on 4.4
xbmc 11.0 eden
sohu addon 2.3.0
Anyone has the same issue? I have tried uninstall and re-install but nothing works. note that I have no problem with youku or other addon
Here are the log file when failed to load sohu addon, looks like a cookie issue. Any way to solve that?
21:07:59 T:208642048 NOTICE: -->Python Interpreter Initialized<--
21:08:00 T:208642048 NOTICE: getHttpData: http://pv.sohu.com/suv/?t?=1350619680866725_1920_1080?r?=
21:08:00 T:208642048 ERROR: Error Type: <class 'cookielib.LoadError'>
21:08:00 T:208642048 ERROR: Error Contents: '/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.video.sohuvideo/cookies.sohu' does not look like a Netscape format cookies file
21:08:00 T:208642048 ERROR: Traceback (most recent call last):
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.sohuvideo/default.py", line 1049, in <module>
rootList()
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.sohuvideo/default.py", line 176, in rootList
link = getHttpData(url_cookie)
File "/var/mobile/Library/Preferences/XBMC/addons/plugin.video.sohuvideo/default.py", line 63, in getHttpData
cj.load(ignore_discard=True, ignore_expires=True)
File "/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/cookielib.py", line 1758, in load
self._really_load(f, filename, ignore_discard, ignore_expires)
FilĀ­e "/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/_MozillaCookieJar.py", line 55, in _really_load
filename)
LoadError: '/var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.video.sohuvideo/cookies.sohu' does not look like a Netscape format cookies file
21:08:00 T:181219328 ERROR: GetDirectory - Error getting plugin://plugin.video.sohuvideo
21:08:00 T:181219328 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.sohuvideo) failed
I looked into the folder /var/mobile/Library/Preferences/XBMC/userdata/addon_data/plugin.video.sohuvideo and I do see a cookies.sohu, but it is 0 bytes. So this might be the issue? I didn't do anything on this cookie file. Any way to fix it or get a new cookie downloaded?
adding the following line into the empty cookies.sohu file partially solves the issue.
# Netscape HTTP Cookie File
Now it doesn't give me the script failed and can watch the movie and tv. But all LIVE TV channels are not working. maybe it does requires some cookie?
just tried another thing which is to watch the sohu live TV channels on my IE browser and it failed as well. I used chrome with unblock youku and it is working, so sohu seems to start blocking oversea ip address again? but I thought the sohu addon is using a proxy, isn't it?
Please advise how to proceed.
Added: plugin.video.kugoumv - Online MV form http://www.kugou.com, Thanks [email protected]
magically today all live TV channels start to working again....
Added: plugin.video.pptv - Online videos from www.pptv.com, Thanks Uranus Zhou
