Hello all
is there any way to input my username and password for 奇艺视频(QIYI) addon so I can watch the VIP films etc?
I already have the paid account but cannot work out where to enter them into the addon (if possible at all)
Thanks for help
is the addon not maintained now?
(2017-01-10, 16:52)Argrock Wrote: [ -> ]Hello all
Thanks for help
I'm sorry. no plan to do this now.
(2017-02-08, 08:21)taxigps Wrote: [ -> ]I'm sorry. no plan to do this now.
What a pity, but thanks for the reply
Keep up the great work!
(2016-06-19, 19:37)steve1977 Wrote: [ -> ]Looks like Letv is yet again broken? Anyone in touch with the developer and can we expect a fix? Thanks!
乐视网 (LeTV) update to 1.6.0
Is there an add-on got more mandarin speaking movies than icdrama and azdrama? Thanks!!
(2017-04-10, 03:13)great-wall Wrote: [ -> ]Is there an add-on got more mandarin speaking movies than icdrama and azdrama? Thanks!!
Azdrama has not worked for months. Has it recovered or not ? My version is 29
having problems with the Youku plugins, if anyone could help would be appreciated.
Device - Amazon Fire TV Gen 1
Kodi - Krypton 17.1 stable
VPN - Pure VPN
DNS - 114.114.114.114
confirmed external ip as IP address from VPN server in china.
for plugin.video.youku, the following error is given when trying to launch:
14:00:33.623 T:18446744072519358112 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
14:00:43.651 T:18446744072550151440 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.AttributeError'>
Error Contents: 'NoneType' object has no attribute 'group'
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youku/default.py", line 647, in <module>
rootList()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youku/default.py", line 177, in rootList
match = re.compile('<li><a\s*href="/([^/]+)/([^\.]+)\.html"[^>]+>(.+?)</a></li>').findall(match0.group(1))
AttributeError: 'NoneType' object has no attribute 'group'
14:00:43.749 T:18446744072519358112 ERROR: GetDirectory - Error getting plugin://plugin.video.youku/
14:00:43.751 T:18446744072519358112 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youku/) failed
for plugin.video.youkutv, the following error message is given when attempting to watch a video:
"resolution address abnormal, unable to play" translation via google translate
(2017-04-15, 20:04)kasper19 Wrote: [ -> ]having problems with the Youku plugins, if anyone could help would be appreciated.
VPN - Pure VPN
rootList()
You should use YouKu TV plugin now. I'll update YouKu plugin when have time.
Youku plugins update to 2.2.5
having problem with Youku TV plugin. Am not sure if this is the right tread but would appreciate any help, else direct me to the right place?
I only recently got into Kodi ecosystem.
Device : Sony Bravia Android TV.
Kodi : Krypton 17.1
The issue I have with Youku TV is whenever I play any video, it will freeze and return to youku menu after 4 minutes. Each time it is the same with any video.
It was working fine a few days back then I suddenly encounter this issue. I tried reinstalling KODI, even start fresh by reformatting Android TV but to no avail.
I'm, wondering if this have anything to do with the recent update on 9/5/2017?
Also sometimes when installing Youku TV plugin, an error msg "commoncache failed to start". What is this?
Where do I get the log in order for me to share?
Thanks in advance.
(2017-05-12, 23:30)lurgoyf Wrote: [ -> ]having problem with Youku TV plugin. Am not sure if this is the right tread but would appreciate any help, else direct me to the right place?
Kodi : Krypton 17.1
Thanks in advance.
here is the link to the issues for YouKu TV plugin:
https://github.com/catro/plugin.video.youkutv/issues
Installed the latest Youku plugin, but now have the following error when trying to play a video.
Kodi 17.3
21:53:15.868 T:18446744072500436216 WARNING: Previous line repeats 2 times.
21:53:15.868 T:18446744072500436216 ERROR: Control 55 in window 10025 has been asked to focus, but it can't
21:53:44.334 T:18446744072527173400 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('stream',)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youku/default.py", line 643, in <module>
PlayVideo(name,id,thumb)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.youku/default.py", line 429, in PlayVideo
streamtypes = [stream['stream_type'].encode('utf-8') for stream in movdat['stream']]
KeyError: ('stream',)
21:53:50.038 T:18446744072500436216 ERROR: Control 55 in window 10001 has been asked to focus, but it can't
21:54:48.091 T:18446744072531854680 WARNING: Attempt to use invalid handle -1
(2017-05-27, 03:58)kasper19 Wrote: [ -> ]Installed the latest Youku plugin, but now have the following error when trying to play a video.
Kodi 17.3
update to 2.2.7
(2017-05-27, 10:47)taxigps Wrote: [ -> ] (2017-05-27, 03:58)kasper19 Wrote: [ -> ]Installed the latest Youku plugin, but now have the following error when trying to play a video.
Kodi 17.3
update to 2.2.7
updated, works fine now, thanks.
