Just release PPS影音 version 1.1.3
The new version pps player can now be controlled via remote control with buttons as follow:
声音缩小:Volum down
声音放大:Volume up
静音: Mute
画面缩小:↓
画面放大:↑
播放暂停:Enter
上一章节:←
下一章节:→
关闭程序:Esc (Clear)
Please feedback if found problem
Hello seem Letv is not working for me,
A month ago it was on my old Eden Xbmc, but now I have the new frodo 12.1 its comming up with a script error.
I installed Eden again after a complete rebuild and then added the Add-on ( still no Joy)
is there a new version of the LeTv add-on? or I am I just missing a trick? please help if you can....
thanks
(2013-04-10, 18:26)REGEDIT32 Wrote: [ -> ]Hello seem Letv is not working for me,
thanks
I just upgraded my Eden to frodo 12.1 last week, and I do not have any problem running LeTV plugin. Just retest to reconfirm, LeTV server seems hevily loaded and reponse is slow. Many times script errors are due to server is heavily loaded and cannot reponse within the time specified.This leads to script error.
By the way which OS are you using to run xbmc?
If you continuous facing problem, try to uninstall LeTV and reinstall the LeTV addon again. Retest to see if the problem still persist.
Is there an add on that will get TVB from hong kong or Cantonese channels>?
thanks
I tried to install/search PPS on a new Raspbmc SD card today but failed.
I had one PPS working on Raspbmc. Is it removed from this repo?
Thank you.
Have released ppstream plugin v2.2.7. This version supports installation on Linux (Tested on XBMC 12.1 on Ubuntu 13.04).
To install:
a. Navigate to "System | Settings | Add-ons | Get Add-ons"
b. Right click "Chinese Add-on Repository"
c. Select "Force refresh"
d. Enter "Chinese Add-on Repository" and select "Video Add-ons"
e. Proceed to install PPS网络电视(PPStream)
(2013-01-09, 20:38)kimmy2000 Wrote: [ -> ]Can anyone help me with this please?
(2012-12-27, 17:05)kimmy2000 Wrote: [ -> ]My tudou don't seem to filter for Cantonese drama anymore, only list mandarine ones even when "Hong Kong" has been selected. Has anyone else got the same problem?
[plugin.video.tudou] v1.1.8 - added: language selection for 国语 and 粤语
[plugin.video.youku] 2.1.7 - added: language selection for 国语 and 粤语
added: plugin.audio.baidufm - Baidu online music (Chinese), thanks zhangyuanwei
Hi There,
Thank you so much for the setup guide, I have just installed xbmc on my Pi using Xbian and added the repository. repository.googlecode.xbmc-addons-chinese-eden.zip so my wife and her parents can watch TV and dramas, however CNTV Live add on is missing, I also have Xbmc on my PC and it is there.
Are you able to help please? Is it possible to add a video plug in manually at all?
Many thanks for your help
(2013-05-19, 22:43)PMetz Wrote: [ -> ]Hi There,
CNTV Live need to call a program only support under windows. so can't use on pi.
(2013-05-20, 01:58)taxigps Wrote: [ -> ] (2013-05-19, 22:43)PMetz Wrote: [ -> ]Hi There,
Many thanks, PC it is then, maybe on the future on the Pi.
I've been watching Korean TV show on LETV and YouKu without problems basically. However since Saturday(May 18,2013) I could not start any Korean TV show from Youku. Is this a geo code restriction enforced by the site ? I can still watch shows from mainland China.
Can someone help ?
(2013-05-21, 07:52)walkingwall168 Wrote: [ -> ]I've been watching Korean TV show on LETV and YouKu without problems basically. However since Saturday(May 18,2013) I could not start any Korean TV show from Youku. Is this a geo code restriction enforced by the site ? I can still watch shows from mainland China.
Can someone help ?
how about Tudou
