Any chance of getting the PPStream plugin to work under Linux?
I have PPStream running under Linux now - (Kubuntu Natty AMD64) - my wife's parents are enjoying the TV from home.
But, I have to run PPStream on it's own.. I'd love to run it from within XBMC.
any cantonese programing in this plugin?
Well, there are cantonese TV shows played via PPStream. (if that's what you mean)
can i install the plugin to appletv2 ??how do i do it ?
inalvi Wrote:can i install the plugin to appletv2 ??how do i do it ?
ok i got it to install but whenever i try to play a show, it will crash back to atv2 menu. how do i fix it guys ?
ok i installed everything already. but whenever i try to play a show, it will crash out to appletv menu ? any idea how can i fix it ??
inalvi Wrote:ok i installed everything already. but whenever i try to play a show, it will crash out to appletv menu ? any idea how can i fix it ??
Hellooo? Anyone able to help ??
inalvi Wrote:Hellooo? Anyone able to help ??
sorry, i haven't a atv to test. need your log file to find the bug.
added three video plugins, credit to wht3000 from bbs.htpc1.com:
plugin.video.ku6 - Online video from
http://www.juchang.com (Chinese)
plugin.video.wzipad - Online video from
http://www.wzipad.com (Chinese)
plugin.video.sina - Online video from video.sina.com.cn (Chinese)
need plugin.video.ppstream - PPS online tv and movies (Chinese) pls but i heard its not possible to make this add-on
also can someone update tv365? most of them are not working...
did someone came up with the PPTV add-on?
thanks for hard work whoever work on this
taxigps Wrote:added three video plugins, credit to wht3000 from bbs.htpc1.com:
plugin.video.ku6 - Online video from http://www.juchang.com (Chinese)
plugin.video.wzipad - Online video from http://www.wzipad.com (Chinese)
plugin.video.wzipad doesnt work...do i need to delete the chinese repo addon and install the new one again?
fabulous Wrote:plugin.video.wzipad doesnt work...do i need to delete the chinese repo addon and install the new one again?
plugin broken because the website(
http://www.wzipad.com) is closed
I have CCTV working however when in watching the video no matter what I do I cannot make the keyboard (apart from control-alt-delete) or the MCE Remote controller work (option I would like most to work).
So basically I have to click on Control-Alt-Delete to end the current stream in a very ungraceful manner.
I've tried to use the keymapset.exe program however I don't really know how to use it. I am setting this up for my wife who reads/speaks Chinese, I do not, and her ability to help out technically is limited.
Should I be storing the keymap.ini file in the same directory as cctvlive.exe or in a different directory?
If anyone could help it would be greatly appreciated....
Installed addon. It works great. Except for the following two problems:
1) How do you get ppstream to work?
2) CCTV Live works but once it starts streaming, my Xbox 360 controller, keyboard, or mouse will not be able to shut it down. I have to reboot the computer to exit the cctv program. How do you control CCTV Live?
Hi...just to be clear as maybe I wasn't on the previous post...
I have many of the Chinese TV channels working, including CCTV and CCTV Live...however the remote works in all the channels apart from CCTV Live. I have registered CCTVlive.exe etc. etc. and it all works in terms of streaming the content...but my remote (MCE) does not work once the stream starts...not one key on the MCE remote works and honestly I have no idea how to use the KeyMap program....so basically the remove works for ALL the Chinese TV channels apart from CCTV Live....when I start CCTVLive I cannot do anything to stop, pause or return to the XBMC interface once a stream has started. I have tried from a mouse and also a keyboard but nothing will respond once the stream in CCTV Live has started streaming.
If someone would please kindly explain or point me in the direction of how to use the KeyMap program it would be very greatly appreciated...however I think I have a bigger issue because not even the keyboard works to stop the stream...any help please?
