Orclas
I had the same problem with stuttering, but it seems almost solved by setting "Adjust display refresh rate to match video" to "On start/stop" in System->Settings->Videos->Playback. WIth "almost" I mean that there seems to still be some stuttering right when the video starts, but it becomes smooth after a second or two.
I don't know if the setting has some negative effect somewhere else, but I have not seen any so far.
The change was a wild guess. I noticed in the OSD status display (the row starting with "P(fr: ...") that the framerate number fluctuated between about approx. 20 and 24 fps. Also in that row the drop figure was steadily increasing by approximately one every second. In the row starting with "W(fps:..." the framerate was steady at 25.00. I do not know much of what these figures really says, but they prompted me to try out some framerate settings.
The problem with the video stopping after some time I am also experiencing and have no solution for.
By the way, my system is a ASRock ION 330HT with OpenElec 3.0.3 on it.
Hej,
anybody knows how I can download
[u]this documentary[/u]? I can't even watch it, as I am not in Sweden (proxy servers don't help either)...
Hello
Playing from "Latest news..." always fails for Sydnytt, Västnytt etc.
Here is my log showing three failed starts (and first one successful, Rapport)
http://xbmclogs.com/show.php?id=36050
(2013-07-11, 11:54)Novin Wrote: [ -> ]Hello
This error is the same as (1) stated here:
https://github.com/nilzen/xbmc-svtplay/i...t-16158496
The error explained would be; there are no streams matching the BW setting you have applied.
Never got around to merge that fix it seems. If you have time, please test the branch (errorhandling) mentioned in the Issue report above and report your result to the Github issue tracker (not here).
Thank you!
I have xbmc V11 on Debian Wheezy
The SVTplay addon installed. when I try to run it, a pop-up informs me something like:
"Adress or network problem. It might get better by it..."
And then one can not see the rest of the text. Press ok is the option. Then the message in the right bottom corner informs that the python plugin script has failed.
I do have a running internet connection. I can watch svtplay videos through chromium with no problem. I have the Adobe flash plugin installed for browser.
Anybody know the remedy. Does it have to do something with the xbmc V11 to do? Do I need V12.
I saw on github that current version of svtplay addon is 3.2.2. I have 2.0.4 and the package was updated for Frodo by 3.0.0 - the step after my version. Does this mean it is doomed to fail as long as I stay with XBMC V11? Is there any work-around on my set-up.
(2013-07-24, 11:17)TompaDeb Wrote: [ -> ]I have xbmc V11 on Debian Wheezy
SVTPlay 2.x on XBMC 11 is not supported anymore. You need to upgrade to XBMC 12.x and install SVTPlay 3.x (through the built-in addon installer) to be able to view SVTPlay content on XBMC.
SvtPlay version 3.2.2 or latest pulled from github. Raspbmc with XBMC version 13 alpha 7.
Since last week i have trouble using SVTplay plugin. Using "Program A-Ö" lists all programms but nothing shows in any of the folders, for instance ABC.
Snippet of log:
4:24:21 T:2606445632 NOTICE: Thread LanguageInvoker start, auto delete: false
14:24:21 T:2606445632 NOTICE: -->Python Interpreter Initialized<--
14:24:23 T:2606445632 NOTICE: CommonFunctions-2.5.1
14:24:23 T:2606445632 NOTICE: [SVT Play 3] fetchPage : 'called for : {'link': 'http://www.svtplay.se/abc'}'
14:24:23 T:2606445632 NOTICE: [SVT Play 3] fetchPage : 'Got request'
14:24:23 T:2606445632 NOTICE: [SVT Play 3] fetchPage : 'connecting to server...'
14:24:24 T:2606445632 NOTICE: [SVT Play 3] fetchPage : 'Done'
14:24:24 T:2606445632 NOTICE: [SVT Play 3] createDirectory : 'Could not find tab clips on page with url /abc. Aborting!'
14:24:24 T:2598057024 NOTICE: Thread BackgroundLoader start, auto delete: false
Waiting for data... (interrupt to abort)
Searching for ABC yoelds results in subfolders Klipp and Avsnitt
(2013-08-26, 14:37)ulpa Wrote: [ -> ]Since last week i have trouble using SVTplay plugin. Using "Program A-Ö" lists all programms but nothing shows in any of the folders, for instance ABC.
Yep, SVT seems to have changed something, it's completely empty everywhere. Bastards...
/Daniel
Yeap, i have the same problem. It worked perfect until maybe mid of July 2013. Then I went for vacation and when try again
the other day it didi not work anymore. So I can not say exactly when it started to not work. Maybe beginning of July? I am not sure because I dont look every day.
Will there be a solution on this? I really hope because it is a very, very, nice app :-)
I cross my fingers..
Thanks in advance.
I forget to mention that I use Frodo 12.2 and the skin that comes with Frodo.
svtplay.se has translated some stuff.
fix is on its way
I also have this problem on raspbmc nightly build
Thx for info on this khoda:-)
(2013-08-27, 03:12)khoda Wrote: [ -> ]svtplay.se has translated some stuff.
fix is on its way
That sound very good! It is a very nice plugin and has always worked fine to me before.
I see forward the fix
Thanks in advance!
Hope the fix comes soon, really missing this plugin.
Thanks to you people working on it
