(2014-10-29, 21:52)swehawk Wrote: [ -> ]@Todde and Pezlin: Are you guys having the same problems as I describe in my post above?
@Pezlin: Where exactly did you put the svt.py file?
I get a script error similar to the one mentioned above. I followed the instructions from the post in this thread offering the updated svt.py file.
Found the error and corrected the svt.py
This is not an official update, since I'm not a developer of the plugin.
Just wanted to fix it.
Download link:
http://wikisend.com/download/138282/svt.py
Changed line 332
From: attrs = { "class": "[^\"']*play_videolist__thumbnail[^\"']*" },
To: attrs = { "class": "[^\"']*play_videolist-element__thumbnail-image[^\"']*" },
Thanks, this fixed the problem in "PROGRAM A-Ö", I can now enter this list and start programs from it.
Of course I have not checked all but a sample of the list and it seems to work OK now.
I also checked the other items in the list and found the following to still have problems:
Top level script error:
- KANALER
- KATEGORIER
Script error on some of the sub-items:
- SISTA CHANSEN
For example the items VÄRLDSKRIGEN-* all have script errors
Note that I have not tried every single item in the lists so the above is a sample only...
What I did was to download the svt.py file from the link above, then transfer it to the pi at:
/home/pi/.xbmc/addons/plugin.video.svtplay/resources/lib
I also deleted the svt.pyc file (the compiled version) so it could be re-created on next use.
I have the same issue and i just get the folders or the categories and then script error.
I put the the file in: root/.xbmc/addons/plugin.video.svtplay
(2014-10-30, 16:07)ToddeSwe Wrote: [ -> ]I put the the file in: root/.xbmc/addons/plugin.video.svtplay
Wrong location...
You have to go two folders deeper:
resources/lib/
In effect, you have to find the folder that holds the svt.py file as well as the svt.pyc file (that is lib).
Then you
delete the pyc file and copy in your new svt.py file on top of the existing one.
Note that In my system (RASPBMC) the .xbmc folder is located in /home/pi rather than in /root, but that may be a difference between distributions. I guess you are using OpenELEC, right?
(2014-10-30, 17:30)Bosse_B Wrote: [ -> ] (2014-10-30, 16:07)ToddeSwe Wrote: [ -> ]I put the the file in: root/.xbmc/addons/plugin.video.svtplay
Wrong location...
.xbmc/addons/plugin.video.svtplay/resources/lib/
Then you delete the pyc file and copy in your new svt.py file on top of the existing one.
YES now it works BUT i can't use the KATEGORIER to play my news it have to use PROGRAM. Just so you know! THANKS! You've made my day!
Updated svt.py
Just wanted to fix some of the issues.
Download link:
http://wikisend.com/download/253976/svt.py
Fixed:
Channels/Kanaler
Categories/Kategorier
Not fixed:
Problems with thumbnails because they moved them to Cascading Style Sheets (.css) & some to the svt.se webserver.
Some of the feeds/streams might not work, like "VÄRLDSKRIGEN" - because they changed the format to Flash Media Manifest (.f4m)
No quick fix, so leave these issues for the developers.
OOPS, did not see legostar's post.
I will now test the new svt.py.
---- TIME PASSES ---
Success as far as I can see.
The two top level items that triggered script errors are now working.
I hope you get in touch with the developers so your code can be included in mainline and be included in the next official release!
(2014-10-30, 16:07)ToddeSwe Wrote: [ -> ]I have the same issue and i just get the folders or the categories and then script error.
Did you really put it in root and not home/.xbmc?
(2014-10-31, 00:52)epoxy404 Wrote: [ -> ] (2014-10-30, 16:07)ToddeSwe Wrote: [ -> ]I have the same issue and i just get the folders or the categories and then script error.
Yes i did, i'm using a box called The Little Black Box. Maybe the path is slightly different?!
root/.xbmc/addons/plugin.video.svtplay/resources/lib
I'm starting to think that my problems playing from SVT-Play has actually nothing to do with the addon! I'm thinking that if the video starts playing, then the addon has done it's job and handed over playback to xmbc. Still, I'm only having problems playing online HD videos from SVT-Play (and Öppet arkiv as well). The pattern is always the same. First the playback freezes after some 20 sec for about 10 sec. Then playback resumes, but not from where it stopped. It kind of fast forwards to catch up (so it's not buffering)! Next it freezes again after some 30 sec. This time playback crashes and I'm returned back to the SVT-Play program list. Always the same. No problems playing 720/1080P video (mp4 or mkv) over SMB.
Am I the only one having this problem?
I have a 512MB Pi w lastest stable raspbmc. 50Mbit cable internet wired to the Pi.
Unfortunately it still does not work with the changes in svt.py above
Example from choosing "Program A-Ö" => Aktuellt => script failed
17:47:11 T:140709771319040 NOTICE: -->Python Interpreter Initialized<--
17:47:11 T:140709771319040 NOTICE: CommonFunctions-2.5.1
17:47:11 T:140709771319040 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "/storage/.xbmc/addons/plugin.video.svtplay/default.py", line 364, in <module>
viewEpisodes(ARG_URL)
File "/storage/.xbmc/addons/plugin.video.svtplay/default.py", line 172, in viewEpisodes
episodes = svt.getEpisodes(url)
File "/storage/.xbmc/addons/plugin.video.svtplay/resources/lib/svt.py", line 280, in getEpisodes
return getArticles(SECTION_EPISODES, url)
File "/storage/.xbmc/addons/plugin.video.svtplay/resources/lib/svt.py", line 329, in getArticles
ret = "href")[0]
IndexError: list index out of range
17:47:11 T:140711083140928 ERROR: GetDirectory - Error getting plugin://plugin.video.svtplay/?mode=pr&url=%2faktuellt
17:47:11 T:140711083140928 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.svtplay/?mode=pr&url=%2faktuellt) failed
17:47:11 T:140709771319040 NOTICE: Thread BackgroundLoader start, auto delete: false
Any hints?
Hi
Today it's not working again. What ARE they doing to SVTPlay every week?!
Don't they want us to use it?
Oups, did not noticed the new 4.0.9 update that seems to have fixed it.
THANKS!
It appears that the latest update to SVTplay causes ITVplayer to stop working with TV catch up.
