Also note that if you add the "quiet" option (without quotes) to the end of your line in cmdline.txt, you'll get a much less noisy and more pleasant boot sequence!
Im seeing some scrolling text on boot over OE splash even with "quiet" in cmdline.txt
Can you take a picture? What's your cmdline.txt? You should have no scrolling text with quiet unless you have an error during startup, or quiet isn't actually being applied...
Here's the booting sequence
video
boot=/dev/mmcblk0p1 disk=/dev/sda1 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 ssh quiet
PS. It's related to
if I remove it the boot sequence is normal.
PS2. SOLVED
There was a break in the line, probably from copy paste, now boot is normal, no text, and FSM enabled.
(2014-02-28, 00:11)MilhouseVH Wrote: [ -> ]OK, I've created a clean build, and there is no difference:
Without hifiberry.conf:
rpi512:~ # lsmod | sort
Module Size Used by
regmap_mmio 1921 1 snd_soc_bcm2708_i2s
snd_soc_bcm2708_i2s 5202 0
snd_soc_wm8731 9498 0
snd_soc_wm8804 6854 0
rpi512:~ # aplay -l
aplay: device_list:268: no soundcards found...
With hifiberry.conf:
rpi512:~ # cat .config/modules-load.d/hifiberry.conf
#snd_soc_bcm2708
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_pcm5102a
snd_soc_hifiberry_dac
Module Size Used by
snd_soc_hifiberry_dac 1740 0
snd_soc_pcm5102a 1058 0
rpi512:~ # aplay -l
rpi512:~ # systemctl status systemd-modules-load.service
systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static)
Active: active (exited) since Thu 1970-01-01 01:00:06 BST; 44 years 1 months ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 118 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=0/SUCCESS)
Main PID: 118 (code=exited, status=0/SUCCESS)
CGroup: /system.slice/systemd-modules-load.service
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Note that systemd-modules-load.service will fail if snd_soc_bcm2708 is uncommented as this module can't be found.
Maybe Popcornmix can help out(He got it working once so maybe another Time
I currently running the official 3.2.4 with USB install. How can i install the MilhouseVH build? Can i just copy files in Target folder to the Update folder on my Pi? or do I have to do from beginning, if so how?
(2014-02-28, 16:55)ichibanrhino Wrote: [ -> ]I currently running the official 3.2.4 with USB install. How can i install the MilhouseVH build? Can i just copy files in Target folder to the Update folder on my Pi? or do I have to do from beginning, if so how?
Just copy the 4 files from the target folder into the Update folder on the Pi. Once you're on a Gotham build you only need to copy the entire tar into the Update folder, no need to extract the 4 files yourself.
Hi milhouse,
I am really enjoying your build an appreciate the work but there is one little issue.
Since i installed your test build ( i had standard openelec 3.2.4 ) the subwoofer of my
2.1.sony ht-ct260h soundbar is doing nothing :\
Do you have any idea how i can make the subwoofer work with your build?
Oh btw. my pi is connected to my Philips TV via HDMI and the soundbar gets the sound
data via optical cable from the TV.
Thanks and Cheers
Thais
(2014-02-28, 18:23)thais666 Wrote: [ -> ]I am really enjoying your build an appreciate the work but there is one little issue.
Make sure speaker configuration is set to 2.0. Your setup won't support multichannel PCM.
You should enable DTS and AC3 passthrough (if your equipment supports them), then you will get subwoofer output.
Thanks for the feedback
How do i enable DTS and ac3 passthrough? Did not find it in the options...
Cheers
Thais
(2014-02-28, 19:17)thais666 Wrote: [ -> ]How do i enable DTS and ac3 passthrough? Did not find it in the options...
In settings/system/audio output.
You may need to change the settings level to advanced or expert (the bottom entry of left hand list).
popcornmix
Could you have a look on my posts
#3163
#3166
#3168
regarding the issue that I have change the screen resolution or play with OMXPlayer (but not every time) to get the sound
(2014-02-28, 19:32)MrNice Wrote: [ -> ]Could you have a look on my posts
#3163
#3166
#3168
No ideas so far. I haven't seen this issue reported by anyone else. All you can do is try to gather more information.
Is this problem new? Did the Frodo stable work correctly? Did any previous gotham builds work?
Can you test with a different hdmi audio device? If that works reliably it rules out a problem with you Pi/install/settings.
Do any options in settings/system/audio and video make it work? i.e. forcing a different resolution, setting 2 channels etc?
Have you tried a different hdmi cable? config_hdmi_boost? Measured voltage?
