(2013-10-29, 14:48)popcornmix Wrote: [ -> ] (2013-10-29, 14:17)teeces Wrote: [ -> ]Thanks, I was able to modify the file using a Linux PC with no problem. I'm now able to boot the Gotham alpha on the R-Pi, but so far I can't get any blu-ray rips to play audio+video; I get audio only. DVD rips play fine (video and audio). I double-checked my MPG and WVC keys in the config.txt. Any idea why blu's won't play back on the alpha?
FYI the above is true for both "raw" blu rips, and also ones that I re-encoded with Handbrake.
Can you post mediainfo (http://mediaarea.net/en/MediaInfo) for files that don't play.
This one plays audio only on the Gotham alpha. I have the latest release (Frodo) build of OpenElec on another SD card, and it plays fine on that (audio and video). Thanks for your help.
General
Unique ID :
Complete name : Z:\Shared Videos\movies\TheFileName.mkv
Format : Matroska
Format version : Version 2
File size : 5.12 GiB
Duration : 22mn 4s
Overall bit rate mode : Variable
Overall bit rate : 33.2 Mbps
Movie name : Movie Name Changed
Encoded date : UTC 2012-10-08 23:28:31
Writing application : MakeMKV v1.7.7 win(x64-release)
Writing library : libmakemkv v1.7.7 (1.2.0/1.1.0) win(x64-release)
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 4s
Bit rate mode : Variable
Bit rate : 31.1 Mbps
Maximum bit rate : 33.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.625
Stream size : 4.79 GiB (93%)
Language : English
Default : No
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 22mn 4s
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 238 MiB (5%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Chapter 00
00:05:24.515 : en:Chapter 01
00:09:13.785 : en:Chapter 02
00:10:35.158 : en:Chapter 03
00:15:44.968 : en:Chapter 04
00:18:25.545 : en:Chapter 05
