2014-01-27, 00:16
(2014-01-27, 00:15)zoydberg Wrote: [ -> ]Adjusting the refresh rate has made it worse when I tried, but yes, I've tried that as well. Maybe it's a problem specific to windows? I'm unsure as I've never tried Open ELEC(2014-01-26, 23:58)Quiksmage Wrote: [ -> ](2014-01-26, 11:45)zoydberg Wrote: [ -> ]i dont know if xbmc likes everything being stored on network locations, try removing everything between <pathsubstitution> and </pathsubstitution> in your advanced settings file, even on the wiki http://wiki.xbmc.org/index.php?title=Path_substitution they say "Note: This is considered an advanced (complicated) and experimental feature. Path substitution is not officially supported for settings files with the exception of playlists. It probably won't hurt anything, but some things might not always work right depending on what you are substituting."
or you could try removing <defaultplayer>dsplayer</defaultplayer> as it seems to not exist WARNING: CPlayerCoreFactory::GetPlayerCore(videodefaultplayer): no such core: dsplayer
but also try the suggestions in my previous post, make sure librtmp and your video drivers are up to date
I've tried on a completely clean install of xbmc 12.3 with no advancedsettings file (everything brand new). The issue persisted. I have the latest drivers of everything and this happens on multiple computers with different hardware, but the same OS.
Another example of a problem stream for me is the LCS NA Stream. when showing the options, if PC:2 is shown it appears smooth, if PC:none is showed it appears microstuttery, laggy, dropped frames, etc.
maybe try going to the xbmc settings>video>playback>set "adjust display refresh rate to match video" to "always", enable sync playback to display, then go to settings>system>video output>set "vertical blank sync" to "always enabled", then try it again
