(2012-10-19, 18:03)mlaggner Wrote: [ -> ]Hi Aenima99x,
it looks like your are trying to run it with an "incomplete" jre (UI libs are missing).
Consulting Google, there are several threads about this exception; maybe THIS thread will help you.
btw: my main computer is running an Arch Linux x64 and its working fine
Quote:#java -version
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.4) (ArchLinux-6.b24_1.11.4-1-x86_64)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
hth
manuel
Got it fixed by installing openjdk-jre. Thanks
Just uploaded Alpha 2 - see the changelog in my first post
Just a fast information for testers with Java7: there is a bug in Java7 (up to u10) which causes tmm to hang.
It is solved with Java7u10 (next update).
To test tmm until Java7u10 is released - just install Java6
just released Alpha 2 - r55 to the update server;
if you have already downloaded Alpha 2 the autoupdater will download the update;
all others have to download Alpha 2 from Google Code and then update.
Be aware: due to many changes in the code you will have to delete the tmm.odb and config.xml! (mac users: if you do not know how to delete files from within an app - just delete the whole app and redownload Alpha 2)
Excellent update , work great her on win 7
just updloaded Beta - r68
if you are updating from Alpha you have to download the Beta package due to massive changes in tinyMediaManager
Nice work on the new Beta version
This looks very nice. Will try it out tonight.
Thanks so much
Working great so far, just one question. Can it be set to look for local existing art when choosing thumbnails/fanart? I'm trying to avoid the movie.nfo pointing to a url instead of a local path for artwork. Thanks!
did I get you right: you wish to choose a local file as fanart/poster instead of the images from TMDB? (all chosen images from TMDB will be stored next to the movie)
or do you only want to have the local file written to the nfo?
i suppose you are talking about the following tag:
<thumb>http://cf2.imgobject.com/t/p/w342/mH6xazzfGdszadd1Xy9JgdZYvn1.jpg</thumb>
may i did not get it right from the xbmc speification: are there local paths allowed in this tag? If they are allowed, then its no problem to store the path of the downloaded poster in this tag!
hth
manuel
Beta - r73 have been released today:
Added experimental support for scraping IMDB (only english content is supported so far)
hi, i'm really looking forward to trying this.
anyone else having problems with downloading the update files? during first opening i get the error that i could not download the files after 5 attempts. I tried it on a different system as well with no succes.
I can reach the svn via my browser though...
any advice for me?
hi ,
try to update again ... v-r74 is on line ,that fix the issue with the update ...
sorry, i've messed up the updater with r73;
r74 is online and fixes it
no problem, it updates perfectly now, thank you!!!
the app works great, I use the imdb scraper for its votes, and at this moment I can only say that it works as it should. Thanks a lot!!
