2013/12/29 15:53:58:386 Infos m.a: ------------------ VM Info ------------------
2013/12/29 15:53:58:390 Infos m.a: -- OS Name: Linux
2013/12/29 15:53:58:390 Infos m.a: -- OS Arch: i386
2013/12/29 15:53:58:391 Infos m.a: -- OS Vers: 3.2.0-4-686-pae
2013/12/29 15:53:58:391 Infos m.a: -- Java Vers: 1.7.0_45
2013/12/29 15:53:58:391 Infos m.a: -- Java Home: /usr
2013/12/29 15:53:58:391 Infos m.a: -- User Name: rv
2013/12/29 15:53:58:391 Infos m.a: -- User Home: /home/rv
2013/12/29 15:53:58:391 Infos m.a: -- Cur dir: /home/rv/Vidéos/TMM
2013/12/29 15:53:58:392 Infos m.a: ---------------------------------------------
2013/12/29 15:53:58:453 Infos m.a: ---------------- Proxy Info -----------------
2013/12/29 15:53:58:454 Infos m.a: -- Proxy Host: null
2013/12/29 15:53:58:454 Infos m.a: -- Proxy Port: null
2013/12/29 15:53:58:454 Infos m.a: ---------------------------------------------
2013/12/29 15:53:58:457 Infos m.a: Skipping [quals=windows, osname=linux, osarch=i386, key=resource, value=[windows] tinyMediaManagerCMD.exe]
2013/12/29 15:53:58:462 Infos m.a: Skipping [quals=linux-amd64, osname=linux, osarch=i386, key=resource, value=[linux-amd64] native/linux-amd64/libmediainfo.so]
2013/12/29 15:53:58:462 Infos m.a: Skipping [quals=linux-amd64, osname=linux, osarch=i386, key=resource, value=[linux-amd64] native/linux-amd64/libzen.so]
2013/12/29 15:53:58:462 Infos m.a: Skipping [quals=linux-arm, osname=linux, osarch=i386, key=resource, value=[linux-arm] native/linux-arm/libmediainfo.so]
2013/12/29 15:53:58:463 Infos m.a: Skipping [quals=linux-arm, osname=linux, osarch=i386, key=resource, value=[linux-arm] native/linux-arm/libzen.so]
2013/12/29 15:53:58:463 Infos m.a: Skipping [quals=linux-i686, osname=linux, osarch=i386, key=resource, value=[linux-i686] native/linux-i686/libmediainfo.so]
2013/12/29 15:53:58:463 Infos m.a: Skipping [quals=linux-i686, osname=linux, osarch=i386, key=resource, value=[linux-i686] native/linux-i686/libzen.so]
2013/12/29 15:53:58:463 Infos m.a: Skipping [quals=mac os x, osname=linux, osarch=i386, key=resource, value=[mac os x] native/mac-x86_64/libmediainfo.dylib]
2013/12/29 15:53:58:464 Infos m.a: Skipping [quals=windows-amd64, osname=linux, osarch=i386, key=resource, value=[windows-amd64] native/windows-amd64/MediaInfo.dll]
2013/12/29 15:53:58:473 Infos m.a: Skipping [quals=windows-x64, osname=linux, osarch=i386, key=resource, value=[windows-x64] native/windows-x64/MediaInfo.dll]
2013/12/29 15:53:58:474 Infos m.a: Skipping [quals=windows-x86, osname=linux, osarch=i386, key=resource, value=[windows-x86] native/windows-x86/MediaInfo.dll]
2013/12/29 15:53:58:474 Infos m.a: Skipping [quals=windows-x86, osname=linux, osarch=i386, key=resource, value=[windows-x86] native/windows-x86/mingwm10.dll]
2013/12/29 15:53:58:475 Infos m.a: Skipping [quals=mac os x, osname=linux, osarch=i386, key=jvmarg, value=[mac os x] -Dapple.awt.graphics.UseQuartz=true]
2013/12/29 15:53:58:489 Infos m.a: Able to lock for updates: true
2013/12/29 15:53:58:561 Infos m.a: Verifying application: http://tinymediamanager.googlecode.com/svn/dist/
2013/12/29 15:53:58:562 Infos m.a: Version: -1
2013/12/29 15:53:58:562 Infos m.a: Class: org.tinymediamanager.TinyMediaManager
2013/12/29 15:53:58:563 Infos m.a: Dropping status 'm.validating'.
2013/12/29 15:53:58:630 Infos m.a: Attempting to refetch 'digest.txt' from 'http://tinymediamanager.googlecode.com/svn/dist/digest.txt'.
2013/12/29 15:53:58:970 Infos m.a: No signers, not verifying file [path=digest.txt]
2013/12/29 15:53:58:992 Infos m.a: Resources verified.
2013/12/29 15:53:59:006 Infos m.a: Environment LC_ALL=en_US.UTF-8
TERM=xterm
GNOME_KEYRING_CONTROL=/home/rv/.cache/keyring-1pb6Ht
SSH_AGENT_PID=3614
JAVA_HOME=/usr/lib/jvm/java-7-oracle
SHLVL=2
J2REDIR=/usr/lib/jvm/java-7-oracle/jre
XFILESEARCHPATH=/usr/dt/app-defaults/%L/Dt
J2SDKDIR=/usr/lib/jvm/java-7-oracle
SESSION_MANAGER=local/debianACER:@/tmp/.ICE-unix/3573,unix/debianACER:/tmp/.ICE-unix/3573
COLORTERM=gnome-terminal
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
XDG_SESSION_COOKIE=771ba8a059bb1188a8f4f7d652738be9-1388314458.467106-484172907
GDMSESSION=default
XDG_DATA_DIRS=/usr/share/gnome:/usr/local/share/:/usr/share/
PWD=/home/rv/Vidéos/TMM
WINDOWID=50335003
LOGNAME=rv
GPG_AGENT_INFO=/home/rv/.cache/keyring-1pb6Ht/gpg:0:1
GJS_DEBUG_TOPICS=JS ERROR;JS LOG
DERBY_HOME=/usr/lib/jvm/java-7-oracle/db
_=/usr/bin/java
SSH_AUTH_SOCK=/home/rv/.cache/keyring-1pb6Ht/ssh
NLSPATH=/usr/dt/lib/nls/msg/%L/%N.cat
SHELL=/bin/bash
DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-7hlRJ92nuS,guid=7a711f5f07c79d82722d2d1e52bfff5b
GNOME_KEYRING_PID=3555
PATH=/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games:/usr/lib/jvm/java-7-oracle/bin:/usr/lib/jvm/java-7-oracle/db/bin:/usr/lib/jvm/java-7-oracle/jre/bin
DESKTOP_SESSION=default
DISPLAY=:0
USER=rv
GJS_DEBUG_OUTPUT=stderr
HOME=/home/rv
XAUTHORITY=/var/run/gdm3/auth-for-rv-DY4SWm/database
WINDOWPATH=7
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:
USERNAME=rv
LANG=fr_FR.UTF-8
2013/12/29 15:53:59:007 Infos m.a: Running /usr/bin/java
-classpath
/home/rv/Vidéos/TMM/./tmm.jar:/home/rv/Vidéos/TMM/./lib/asm.jar:/home/rv/Vidéos/TMM/./lib/betterbeansbinding-core.jar:/home/rv/Vidéos/TMM/./lib/betterbeansbinding-el.jar:/home/rv/Vidéos/TMM/./lib/betterbeansbinding-swingbinding.jar:/home/rv/Vidéos/TMM/./lib/commons-codec.jar:/home/rv/Vidéos/TMM/./lib/commons-io.jar:/home/rv/Vidéos/TMM/./lib/commons-lang3.jar:/home/rv/Vidéos/TMM/./lib/core.jar:/home/rv/Vidéos/TMM/./lib/DJNativeSwing.jar:/home/rv/Vidéos/TMM/./lib/DJNativeSwing-SWT.jar:/home/rv/Vidéos/TMM/./lib/fanarttvapi.jar:/home/rv/Vidéos/TMM/./lib/forms.jar:/home/rv/Vidéos/TMM/./lib/glazedlists.jar:/home/rv/Vidéos/TMM/./lib/httpclient.jar:/home/rv/Vidéos/TMM/./lib/httpcore.jar:/home/rv/Vidéos/TMM/./lib/httpmime.jar:/home/rv/Vidéos/TMM/./lib/imgscalr-lib.jar:/home/rv/Vidéos/TMM/./lib/jackson-annotations.jar:/home/rv/Vidéos/TMM/./lib/jackson-core.jar:/home/rv/Vidéos/TMM/./lib/jackson-databind.jar:/home/rv/Vidéos/TMM/./lib/jcl-over-slf4j.jar:/home/rv/Vidéos/TMM/./lib/jdom.jar:/home/rv/Vidéos/TMM/./lib/jmte-unbundled.jar:/home/rv/Vidéos/TMM/./lib/jna.jar:/home/rv/Vidéos/TMM/./lib/jsoup.jar:/home/rv/Vidéos/TMM/./lib/JSplitButton.jar:/home/rv/Vidéos/TMM/./lib/JTattoo.jar:/home/rv/Vidéos/TMM/./lib/l2fprod-common-buttonbar.jar:/home/rv/Vidéos/TMM/./lib/l2fprod-common-shared.jar:/home/rv/Vidéos/TMM/./lib/log4j-over-slf4j.jar:/home/rv/Vidéos/TMM/./lib/logback-classic.jar:/home/rv/Vidéos/TMM/./lib/logback-core.jar:/home/rv/Vidéos/TMM/./lib/objectdb.jar:/home/rv/Vidéos/TMM/./lib/platform.jar:/home/rv/Vidéos/TMM/./lib/resources.jar:/home/rv/Vidéos/TMM/./lib/Scaling-bin.jar:/home/rv/Vidéos/TMM/./lib/slf4j-api.jar:/home/rv/Vidéos/TMM/./lib/themoviedbapi.jar:/home/rv/Vidéos/TMM/./lib/thetvdbapi.jar:/home/rv/Vidéos/TMM/./lib/twinkle.jar:/home/rv/Vidéos/TMM/./lib/xmlrpc-client.jar
-Dcom.threerings.getdown=true
-Xms64m
-Xmx512m
-Xss512k
-Djava.net.preferIPv4Stack=true
-Djna.nosys=true
Error: Could not find or load main class org.tinymediamanager.TinyMediaManager
