(2017-04-09, 07:39)mlaggner Wrote: [ -> ]please check if the image in the folder is the right one - that might be a image caching problem inside tmm
If the image in the folder is correct - please try to clear/rebuild the image cache inside tmm
The image in folder is wrong (This Is Us) Have tried numerous time deleting it and getting all images and metadata again
but keep having same problem
Isnt just that movie is 1/2 dozen or others also
Opened it on my phone and I get This is Us
Sent from my HTC_M10h
okay, then the CDN mirror for fanart.tv at your side is faulty..
I get central intelligence. Nothing we can do here
How would I go about repairing the fault?
that's nothing you or I can do.
at max you could try to open a ticket directly at fanart.tv
I don't understand something, why if it's set in the tv settings not to scrape episode & season data, it's still ON every time i scrape a tvshow? So i have to untick the option..
Some reason it won't get thumbnails for into the badlands season 2 even though tvdb has them.
All other shows seem ok as far as I can see.
Error Log:
1:33:27.207 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_fanarttv.conf' - using defaults
21:33:27.297 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
21:33:27.301 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
21:33:27.305 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
21:33:27.309 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
21:33:27.311 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvshows.themoviedb.org.conf' - using defaults
21:33:27.316 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.universal.conf' - using defaults
21:33:27.318 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
21:33:27.320 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
21:33:27.323 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
21:33:27.325 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
21:33:27.401 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_moviemeter.conf' - using defaults
21:33:27.406 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_opensubtitles.conf' - using defaults
21:33:27.469 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_tmdb.conf' - using defaults
21:33:56.245 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/289079/all/en.xml, cause=XML document structures must start and end within the same entity.
i can confirm the issue reported by Glyde62. I get the same error with a lot of episodes and episode search unfortunately doesn't work. ->
14:25:44.302 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_fanarttv.conf' - using defaults
14:25:44.370 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_imdb.conf' - using defaults
14:25:44.485 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
14:25:44.500 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.album.universal.conf' - using defaults
14:25:44.516 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.artists.universal.conf' - using defaults
14:25:44.531 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.themoviedb.org.conf' - using defaults
14:25:44.543 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_metadata.tvdb.com.conf' - using defaults
14:25:44.665 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_moviemeter.conf' - using defaults
14:25:44.697 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_opensubtitles.conf' - using defaults
14:25:44.820 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data\scraper_tmdb.conf' - using defaults
14:27:24.925 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/295759/all/de.xml, cause=XML-Dokumentstrukturen müssen innerhalb derselben Entity beginnen und enden.
@tMM devs: Could you please take a look at this issue?
Best regards
Cavaradossi
I am getting thus when scraping Arrow's latest episode -
episodeNr=23, tvdb=257655, trakt=1403, seasonNr=5},type=TV_EPISODE,artworkType=THUMB,language=en,country=United States,fanartSize=Medium: ~1280x720px,posterSize=Medium: ~342x513px]
2017-05-27 00:02:51,241 INFO [tmmpool-unnamed-task-T19-G451] o.t.c.t.tasks.TvShowEpisodeScrapeTask:132 - =====================================================
2017-05-27 00:02:51,241 DEBUG [tmmpool-unnamed-task-T19-G451] o.t.s.thetvdb.TheTvDbMetadataProvider:109 - getting metadata: MediaScrapeOptions[result=<null>,ids={tmdb=1412, imdb=tt2193021, episodeNr=23, tvdb=257655, trakt=1403, seasonNr=5},type=TV_EPISODE,artworkType=THUMB,language=en,country=United States,fanartSize=Medium: ~1280x720px,posterSize=Medium: ~342x513px]
2017-05-27 00:02:51,241 DEBUG [tmmpool-unnamed-task-T19-G451] org.tinymediamanager.scraper.http.Url:241 - getting http://thetvdb.com/api/<API_KEY>/series/257655/all/en.xml
2017-05-27 00:02:51,479 WARN [tmmpool-unnamed-task-T19-G451] o.t.c.t.tasks.TvShowEpisodeScrapeTask:139 - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/257655/all/en.xml, cause=The element type "is_movie" must be terminated by the matching end-tag "</is_movie>".
TVDB has been acting weird lately. Is this tvdb's problem or TMM's?
Same problem here with latest version. Supergirl series found, but cannot scrape. Same error log like Cavaradossi has.
Same here with "The Flash" and Supergirl, last week no problems.
Edit: Ember has no problem to scrape the two ...
Sorry to pile on here, but I'm getting some TV shows not scraping from the TVDB.com too. When I go to the site, it's been operational and I can get the info manually. Using V2.9.3.1. Following is a log to scrape episodes 18, 19, and 20 of season 15 of Family Guy:
19:32:59.401 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_fanarttv.conf' - using defaults
19:32:59.575 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_metadata.album.universal.conf' - using defaults
19:32:59.598 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_metadata.artists.universal.conf' - using defaults
19:32:59.619 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_metadata.musicvideos.theaudiodb.com.conf' - using defaults
19:32:59.635 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_metadata.themoviedb.org.conf' - using defaults
19:32:59.650 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_metadata.tvdb.com.conf' - using defaults
19:32:59.854 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_moviemeter.conf' - using defaults
19:32:59.872 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_opensubtitles.conf' - using defaults
19:33:00.010 WARN org.tinymediamanager.scraper.config.MediaProviderConfig - Cannot load settings 'data/scraper_tmdb.conf' - using defaults
19:33:31.592 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:33:31.634 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:33:31.680 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:34:50.887 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:34:50.902 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:34:50.916 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:45:17.933 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:45:17.945 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:45:17.960 WARN o.tinymediamanager.core.tvshow.tasks.TvShowEpisodeScrapeTask - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
19:49:02.265 WARN o.t.ui.tvshows.dialogs.TvShowEpisodeEditorDialog - Error getting metadata ExceptionType=MAPPING_FAILED, ResponseCode=0, URL=http://thetvdb.com/api/<API_KEY>/series/75978/all/en.xml, cause=The element type "ProductionCode" must be terminated by the matching end-tag "</ProductionCode>".
looks like the tvdb api v1 is broken at the moment:
https://forums.thetvdb.com/viewtopic.php?f=17&t=37586
unfortunately we did not implement api v2 yet (since it has many drawbacks) and we do not have resources to do that quickly (well we have a real work, family, hobbies too
I'll put the rework for tvdb api on top of our priority list
(2017-05-27, 17:41)mlaggner Wrote: [ -> ]looks like the tvdb api v1 is broken at the moment: https://forums.thetvdb.com/viewtopic.php?f=17&t=37586
unfortunately we did not implement api v2 yet (since it has many drawbacks) and we do not have resources to do that quickly (well we have a real work, family, hobbies too )
Thanks for update, what are the drawback is the new API?
Appreciate your urgency on this also!
Thanks!!!!
