2020-09-07, 22:43
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
2020-09-08, 07:48
what exactly is not working? is the shortcut not triggering the action or are there no new values from mediainfo available?
is there anything visible in the error log?
just tested it on windows and it is working here
2020-09-10, 02:05
(2020-09-08, 07:48)mlaggner Wrote: [ -> ]what exactly is not working? is the shortcut not triggering the action or are there no new values from mediainfo available?The action (update media info) is not triggered when I press ctrl +shift + m
I dont see anything relevant in the log
2020-09-15, 18:51
I started to get this error this morning and I don't know why. No images will load from TMDB. Keeps popping up and giving me an error message. Any idea why?
org.tinymediamanager.scraper.exceptions.ScrapeException: javax.net.ssl.SSLException: Connection reset
at org.tinymediamanager.scraper.kyradb.KyradbMetadataProvider.getMovieArtwork(KyradbMetadataProvider.java:215)
at org.tinymediamanager.scraper.kyradb.KyradbMetadataProvider.getArtwork(KyradbMetadataProvider.java:122)
at org.tinymediamanager.ui.dialogs.ImageChooserDialog$DownloadTask.doInBackground(ImageChooserDialog.java:1016)
at org.tinymediamanager.ui.dialogs.ImageChooserDialog$DownloadTask.doInBackground(ImageChooserDialog.java:906)
at javax.swing.SwingWorker$1.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at javax.swing.SwingWorker.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: javax.net.ssl.SSLException: Connection reset
at sun.security.ssl.Alert.createSSLException(Unknown Source)
at sun.security.ssl.TransportContext.fatal(Unknown Source)
at sun.security.ssl.SSLTransport.decode(Unknown Source)
at sun.security.ssl.SSLSocketImpl.decode(Unknown Source)
at sun.security.ssl.SSLSocketImpl.readHandshakeRecord(Unknown Source)
at sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
at okhttp3.internal.connection.RealConnection.connectTls(RealConnection.java:319)
at okhttp3.internal.connection.RealConnection.establishProtocol(RealConnection.java:283)
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:168)
at okhttp3.internal.connection.StreamAllocation.findConnection(StreamAllocation.java:257)
at okhttp3.internal.connection.StreamAllocation.findHealthyConnection(StreamAllocation.java:135)
at okhttp3.internal.connection.StreamAllocation.newStream(StreamAllocation.java:114)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:42)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:126)
at org.tinymediamanager.scraper.kyradb.KyraApi$1.intercept(KyraApi.java:104)
at org.tinymediamanager.scraper.http.TmmHttpLoggingInterceptor.intercept(TmmHttpLoggingInterceptor.java:120)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:254)
at okhttp3.RealCall.execute(RealCall.java:92)
at retrofit2.OkHttpCall.execute(OkHttpCall.java:186)
at org.tinymediamanager.scraper.kyradb.KyradbMetadataProvider.getMovieArtwork(KyradbMetadataProvider.java:196)
... 9 more
Suppressed: java.net.SocketException: Connection reset by peer: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method)
at java.net.SocketOutputStream.socketWrite(Unknown Source)
at java.net.SocketOutputStream.write(Unknown Source)
at sun.security.ssl.SSLSocketOutputRecord.encodeAlert(Unknown Source)
... 44 more
Caused by: java.net.SocketException: Connection reset
at java.net.SocketInputStream.read(Unknown Source)
at sun.security.ssl.SSLSocketInputRecord.read(Unknown Source)
at sun.security.ssl.SSLSocketInputRecord.readHeader(Unknown Source)
at sun.security.ssl.SSLSocketInputRecord.decode(Unknown Source)
... 41 more
... 9 more
... 44 more
... 41 more
2020-09-15, 19:38
kyradb scraper is dead.. just uncheck this in the artwork scraper settings and everything should be fine
2020-09-15, 21:37
(2020-09-15, 19:38)mlaggner Wrote: [ -> ]kyradb scraper is dead.. just uncheck this in the artwork scraper settings and everything should be fine
Ok cool thank you
2020-09-18, 20:33
18.09.2020 - Version 3.1.9
x removed kyradb.com artwork provider
x take the correct artwork extension when using local files in the image chooser
x several enhancements to the AniDB scraper
2020-09-30, 09:52
30.09.2020 - Release 4.0.2
+ enhanced display of ratings
+ added action to re-fetch IMDB ratings #989
x set "Disable SSL certificate verification" to true per default to avoid connection problems
x cleanup of changed artwork extensions #1015
x show language names in UI language #1010
x added more rating providers to the settings
x re-added file size to the media files table
x preserve epbookmark tag in episode NFOs
x reworked the new indicator to use less space
x rebuild image cache when changing data source #1021
x writing/cleanup of downloaded subtitle files #993
Release 4.0.1
x fixed upgrade of v3 settings
Release 4.0
- bundled JRE and rewritten launcher (no installed Java needed any more)
- real HiDPI support (slightly changed look and feel to achieve correct UI scaling)
- mix in IMDB ratings for almost every scraper without the need of the universal scrapers
- universal TV show scraper
- completely reworked libmediainfo usage:
- full support of reading/writing mediainfo XML files
- better support of disc structures (.iso and VIDEO_TS/BDMV/HVDVD_TS folders)
- several fixes for reading data out of libmediainfo
- enhanced filter management
- new command line interface
- mediainfo integration for Trakt.tv
- support for Windows taskbar / macOS dock access
- added a true regular expression search for movies/movie set/TV show titles
- display missing episodes in the season overview panel
- provide artwork from TMDB for Trakt.tv search
- added showlink support for movies
- better performance in regular expression searches
- fixed handling of MP2/MP3 streams
- enhanced downloading of youtube trailers
- KodiRPC: improve matching
- and many more changes under the hood...
Release 4.0.1
Release 4.0
2020-10-04, 10:49
04.10.2020 - Version 4.0.3
+ added a year column in the TV show tree #1026
+ added a release date column in the movie table #1029
x do not cleanup episodes if the TV show has not been loaded
x several fixes for the universal TV show scraper #1024
x added second runtime column
x better movie detection when having them in 'reserved names' folders
x also respect current file names in the file name filter #1007
x show original image in original size #992
x several fixes to the command line interface
x universal TV show scraper uses less memory now
2020-10-04, 11:08
Version 3.1.10
+ added a file size renderer to the export templates
x added some changes to improve youtube trailer downloading
x included a search rate throttling for opensubtitles #988
x KodiRPC uri matching
x preserve epbookmark in episode NFOs
x (tvdb) also show the artwork on a second search
2020-10-07, 17:52
07.10.2020 - Version 4.0.4
+ added setting to suppress writing of <episodeguide> tag
x (image chooser) show original image always in original size
x errors when downloading images #1039
x (TV show) write trailer urls in Kodi compatible format into NFO #1040
x proper update of vote count for ratings
x fixed writing of the .desktop files in linux
x fixed restart of tinyMediaManager after upgrade to v4
2020-10-14, 18:22
How do you upgrade to v4 whilst maintaining all your data and settings? It looks like a completely new installation, and the docs on the website don't seem to cover this.
2020-10-14, 20:17
ideally just update to 3.1.10 and afterwards click the upgrade button on the right side of the toolbar
alternatively: https://www.tinymediamanager.org/docs/upgrade-v4
2020-10-15, 18:57
(2020-10-14, 20:17)mlaggner Wrote: [ -> ]ideally just update to 3.1.10 and afterwards click the upgrade button on the right side of the toolbar
Ah sorry, I did the upgrades, and expected on startup it would tell me a new version is available. i didn't see the huge green arrow ;-)
2020-10-26, 08:44
Version 4.0.5
+ added support for trailer download to /trailers #787
+ re-added tinyMediaManagerCMD.exe for Windows command line execution
+ added subtitle count filter for TV shows
+ updated libmediainfo to 20.09
x fixed reading hybrid DVD ISOs
x completely reworked trailer downloading to fix several issues #1060
x reworked aspect ratio calculation
x lowered memory consumption of the imdb rating fetching
x draw table/tree grid when multiple rows are selected
x improved loading time of large libraries
x more precise search results when searching for text only
x added an option to specify which actors should be fetched from IMDB #1062
x updated live calculation of movie set/movie count #1064
x inversion of media file filter for TV shows #1063
x prevent trailer from being renamed from within /trailer(s) folder
x support reading of the mediainfo.xml for unsupported files (.disc, .img, ...)
x fixed reading of mediainfo via UNC paths #1071
x fixed some updater issues
x fixed macOS dock pin issue
x MPAA tag in the NFO now also respects the certification style setting
