Major update available: Rapier v5.4.0
Changes include:
- Added support for IMDb Update (
http://forum.xbmc.org/showthread.php?tid=167754) in the skin settings.
- Fixed bugs in the Weather Notification.
- Added battery notification when using a laptop (can be enabled/disabled in the skin settings).
- Added power icon.
- Changed home screen top left XBMC logo to script.globalsearch button including full navigation support for this.
- Fixed global navigation from menus to make Home button (top left) work properly in all views.
- Fixed issues with the scrollbar in the settings (makes it easier with touch devices).
- Added full support for script.grab.fanart (
http://forum.xbmc.org/showthread.php?tid=166572) to replace the broken fanart backgrounds in the home screen.
- Script.grab.fanart can be configured in the Skin Settings under Backgrounds or Add-ons (no need to use the settings in the add-on itself).
- Added add-on shortcuts for the home screen. This can be enabled and configured in the Skin Settings under Home (enabling this will disable all category icons).
I have added a battery notification for when you are using a laptop, Ipad etc. I find this very usefull and missing in other skins (you can still see the normal indication in the system information).
I remember someone missing a global search script button in the home screen. I have added this to the XBMC logo top left.
I have solved the problems with the missing fanart backgrounds in the home screen. You need to manually install the script.grab.fanart (
http://forum.xbmc.org/showthread.php?tid=166572) to fix this. You don't need to change any settings in the script itself. If you have enabled the fanart backgrounds in the skin settings, they will automatically switch to the script when installed. You can choose Random or Recent fanart backgrounds in the skin settings both under Backgrounds and under Add-ons.
The biggest update is the add-on shortcuts in the home screen, which can be enabled and configured in the skin settings under Home. This makes you able to add up to 6 add-on shortcuts to the categories Videos, Movies, TV Shows, Pictures, Programs and General. This way you can have the library, playlist, views, settings etc etc in the home submenu and the add-on shortcuts above. Adding full navigation for all skin options was a real bitch, so please let me know if something is not working properly.
I have yet to fix some bugs including the custom categories + I am working on a lot of new features as well.
