Hi Gade,
you are doing a great job keeping this skin alive, really appreciate it! Couldn't live without it
That said, there was one thing bugging me for a while now- the "Thumbs Info" View (TV Shows), especially the "Clear Logo" and "Clear Art" styles. These seem to be broken since (if i remember correctly) a later alpha of frodo. At first i hoped it was because of the alpha-state, and that it would miraculously fix itself sooner or later. Alpha, beta, RC, final, nothing. Then you took up rapier, but still no clearart. Didn't want to whine about it here either, since is was not THAT important. Kinda...
Well today i just took a shot at it, and i think i was able to fix it. I would be glad if you could double-check it, since i have no experience in skinning, and don't want to break anything else. If everything works out, maybe you could include the changes in your next release?
So here are the changed files
https://www.dropbox.com/s/ehzt8y73kt3zap...rapier.zip
...and here's roughly what i did:
I added 2 new variables in Views.xml, LogoThumb and ClearArtThumb. Depending on UseTVShowLocalCovers and IsEmpty they either point to ListItem.Icon, the local clearart.png/logo.png or ListItem.Art (like the other variables).
Next i (re-?)added TVShowsThumbsInfoClearArtStyle in ViewsTVShows.xml, which is basically a copy of TVShowsThumbsInfoLogoStyle. These two, along with TVShowsThumbsInfoDefaultStyle, get included in TVShowsThumbsInfoView depending on the setting "ThumbsInfoTVShowStyle".
The rest was just tinkering around with the sizes to make it look good again (3x4 layout for logo, 3x3 for clearart, this is negotiable but seems to fit most of the downloaded artwork
), and replacing the references to logo.png/clearart.png with the $VARs. I also took the liberty of commenting out the dim.png in LogoThumbsStyleCoverImage and ClearArtThumbsStyleCoverImage, since this caused a black background, and i saw no point in having clearart on solid ground.
So, as i said before, i would be happy if these changes found their way into one of your upcoming releases, provided they don't mess up anything else of course. If you have any questions or comments, please feel free to PM me.
past
PS. Of course, only minutes after this post i discovered a slight error:
ViewsTVShows.xml, Line 3379 should read
<focusedlayout width="258" height="172" condition="Container.Column(2) + !Container.Row(2)">
Updated the file and re-uploaded to dropbox
