(2015-02-14, 05:29)Joker4life Wrote: [ -> ]Awesome plugin, really enjoy watching our TFC.tv subscription on Kodi. Is there going to be a quality update to HD, the website now has the option to stream in High Definition? If not can you tell me how I can code the higher resolution as an option.
Hi Joker4Life,
Please, can you code for higher resolution? That would be awesome if you TFC addon can be played in HD.
I hope someone who knows how to do the coding would help
Hello @ todits...is TFC.TV down
Are they making any changes to the site..if they are you might need to update the add on thanks..
(2015-02-17, 17:38)warlock09 Wrote: [ -> ]Hello @ todits...is TFC.TV down Are they making any changes to the site..if they are you might need to update the add on thanks..
yep the add-on is getting script errors for me today, yesterday was fine,
We need todits to update the scripts
Checked and it seems to be working now. I'll see if I can add
http://tfctv2.cloudapp.net/ so we can switch between the 2 in case it happens again.
As for HD, the last time I checked (XBMC Gotham), there was no support for the type of stream TFC.tv uses for HD. I'll check again for Kodi.
(2015-02-21, 03:50)todits Wrote: [ -> ]Checked and it seems to be working now. I'll see if I can add http://tfctv2.cloudapp.net/ so we can switch between the 2 in case it happens again.
Thanks again todits!
Mabuhay!
It seems it is not working again.
It's working on and off it seems. Now I get the "Script failed : TFC.tv" error too. 14 hours ago it was working fine ...
The TFC.tv webpage is up and running though, and I can see the shows there, so that's not the problem right now. Hope that will help finding the problem.
But thank you for making this Add-On for us! I do hope though, that the streams HD can somehow be made to work.
Hello Todits, experiencing the same error "Script failed' and last night it was working fine. Tried tfc.tv on a browser and it's working fine. Hope you can release an update soon to correct this issue. Thanks.
Also experiencing the same error. I also hope todits will have the time to fix this... Have a great day everyone!
Hello Pareng todits,tfc.tv website might have been updated or change thats why tfc.tv add on is not working ,kindly check the add on pls. When you find time, thank you very much...
Hey Todits, still having issues with my TFC. Could you help us when you get a chance. Thanks!
brooo Todits , Could u please help us we are dying TFC is not working on XBMC please god bless you
Hi Todits, any new updates on the add on?
