I'm not going to guarantee that all Gotham plugins will work, but I think most should.
Yes things will break and are broken, we already know that some skins have problems with the audio/video OSD setting pages, and skin.widgets is choking on string splits() (due to PR4677) but most other things seem OK given my very limited testing. That could all change with the next build of course, who really knows...
One thing to note is that the
music db version has been bumped in Helix to v48, so if you have a music library and subsequently revert back to Gotham (v46) you will find that any music changes will have been "lost". Should you then upgrade to Helix again in future I would recommend dropping the v48 music db prior to upgrading so that your Gotham music db can be upgraded using the latest Helix database upgrade code. Hope this makes sense...
Thanks. Sounds fairly safe, then, if I stick to confluence and don't use XBMC for music.
Anyone using the new builds with MythTV?
Good evening,
anonimo2001 wrote:
Quote:Good evening. In the last few builds I've had problems with dvdplayer: the image freezes for a few seconds when playing a file (just tried mkv), audio is fine (I've been downgrading and OpenELEC-RPi.arm-Milhouse-20140426044857-r18266-g36251c3 is the last that works fine, OpenELEC_Helix-RPi.arm-Milhouse-20140503235917-r18335-gb2d3626 is quite good but the former goes better)
I have a similar - or maybe the same - issue too. HD-video playback from nfs-share with omxplayer is fine - but without alsa.
Video playback with dvdplayer stutters. Video output freezes for a second or so a few times a minute, sound freezes one time a minute or so. The issue is independent from the video-file, I found no one running smothly.
Yesterday I made a fresh installation of openELEC 4.0.1. Updated via samba-update to OpenELEC_Helix-RPi.arm-Milhouse-20140515053245-r18389-gd25aaa7. Both show the same issue. I think, it was the same with all the builds I tried with enabeled alsa-support. For instance OpenELEC-RPi.arm-3.95.3 still works fine, but has no alsa.
My setup:
RPi 2, videos on wired nfs-share,
video-output via s-video to crt-tv (Yes, it still works fine, so I still have no HDMI-flat-...)
audio via analogue-jack to stereo amp / via hifiberry-dac to stereo amp (that's why alsa needed).
Here is the xbmc.log, the same video first played with omxplayer, than with dvdplayer.
# ... output of cat /storage/.xbmc/temp/xbmc.log
# OpenELEC release: RPi.arm-devel-20140515053245-r18389-gd25aaa7
# OpenELEC_Helix git: d25aaa7273911dbf12975cd2bd5eb4f7ae4be56d
20:36:11 23.095684 T:3058479104 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:36:11 23.096361 T:3058479104 NOTICE: -----------------------------------------------------------------------
20:36:11 23.096605 T:3058479104 NOTICE: Starting XBMC (14.0-ALPHA1 Git:f7649b9). Platform: Linux ARM 32-bit
20:36:11 23.100574 T:3058479104 NOTICE: Using Release XBMC x32 build, compiled May 15 2014 by GCC 4.9.0 for Linux ARM 32-bit 3.14.4
20:36:11 23.142191 T:3058479104 NOTICE: Running on Linux ARM 32-bit (OpenELEC_Helix (Milhouse) - Version: devel-20140515053245-r18389-gd25aaa7, 3.14.4 armv6l)
20:36:11 23.142534 T:3058479104 NOTICE: FFmpeg version: 2.2.1, statically linked: 1
20:36:11 23.142725 T:3058479104 NOTICE: WARNING: unsupported ffmpeg version detected
20:36:11 23.142914 T:3058479104 NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
20:36:11 23.143093 T:3058479104 NOTICE: ARM Features: Neon disabled
20:36:11 23.143284 T:3058479104 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
20:36:11 23.143719 T:3058479104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
20:36:11 23.143986 T:3058479104 NOTICE: special://masterprofile/ is mapped to: /storage/.xbmc/userdata
20:36:11 23.144188 T:3058479104 NOTICE: special://home/ is mapped to: /storage/.xbmc
20:36:11 23.144381 T:3058479104 NOTICE: special://temp/ is mapped to: /storage/.xbmc/temp
20:36:11 23.144703 T:3058479104 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
20:36:11 23.145077 T:3058479104 NOTICE: Local hostname: OpenELEC
20:36:11 23.145290 T:3058479104 NOTICE: Log File is located: /storage/.xbmc/temp/xbmc.log
20:36:11 23.145590 T:3058479104 NOTICE: -----------------------------------------------------------------------
20:36:11 23.650291 T:3058479104 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
20:36:12 23.703150 T:3058479104 NOTICE: load settings...
20:36:12 24.574984 T:3058479104 NOTICE: Found 2 Lists of Devices
20:36:12 24.575325 T:3058479104 NOTICE: Enumerated PI devices:
20:36:12 24.575605 T:3058479104 NOTICE: Device 1
20:36:12 24.581835 T:3058479104 NOTICE: m_deviceName : HDMI
20:36:12 24.582159 T:3058479104 NOTICE: m_displayName : HDMI
20:36:12 24.582373 T:3058479104 NOTICE: m_displayNameExtra:
20:36:12 24.582582 T:3058479104 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:36:12 24.582783 T:3058479104 NOTICE: m_channels : FL,FR
20:36:12 24.582998 T:3058479104 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,41400,48000,88200,96000,176400,192000
20:36:12 24.583210 T:3058479104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
20:36:12 24.585407 T:3058479104 NOTICE: Device 2
20:36:12 24.586000 T:3058479104 NOTICE: m_deviceName : Analogue
20:36:12 24.586237 T:3058479104 NOTICE: m_displayName : Analogue
20:36:12 24.586447 T:3058479104 NOTICE: m_displayNameExtra:
20:36:12 24.586651 T:3058479104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:36:12 24.589632 T:3058479104 NOTICE: m_channels : FL,FR
20:36:12 24.589922 T:3058479104 NOTICE: m_sampleRates : 48000
20:36:12 24.590359 T:3058479104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE
20:36:12 24.590601 T:3058479104 NOTICE: Enumerated ALSA devices:
20:36:12 24.590805 T:3058479104 NOTICE: Device 1
20:36:12 24.591204 T:3058479104 NOTICE: m_deviceName : @
20:36:12 24.591490 T:3058479104 NOTICE: m_displayName : Default (snd_rpi_hifiberry_dac Analog)
20:36:12 24.591724 T:3058479104 NOTICE: m_displayNameExtra:
20:36:12 24.591978 T:3058479104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:36:12 24.592192 T:3058479104 NOTICE: m_channels : FL,FR
20:36:12 24.592400 T:3058479104 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
20:36:12 24.592714 T:3058479104 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
20:36:13 24.758202 T:3058479104 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
20:36:13 24.758780 T:3058479104 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<showexitbutton>false</showexitbutton>
<fanartres>720</fanartres>
<imageres>540</imageres>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>dvdplayer</defaultdvdplayer>
<busydialogdelayms>750</busydialogdelayms>
</video>
<network>
<cachemembuffersize>20971520</cachemembuffersize>
</network>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<readbufferfactor>4.0</readbufferfactor>
</network>
</advancedsettings>
20:36:13 24.778502 T:3058479104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:36:13 24.778814 T:3058479104 NOTICE: Default DVD Player: dvdplayer
20:36:13 24.779005 T:3058479104 NOTICE: Default Video Player: omxplayer
20:36:13 24.779192 T:3058479104 NOTICE: Default Audio Player: paplayer
20:36:13 24.779486 T:3058479104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:36:13 24.779749 T:3058479104 NOTICE: Log level changed to 0
20:36:13 24.784445 T:3058479104 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:36:13 24.802135 T:3058479104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:36:13 24.823315 T:3058479104 NOTICE: Loaded playercorefactory configuration
20:36:13 24.828512 T:3058479104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:36:13 24.829298 T:3058479104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:36:14 25.768272 T:3058463824 NOTICE: Thread ActiveAE start, auto delete: false
20:36:14 25.774187 T:3048207440 NOTICE: Thread AESink start, auto delete: false
20:36:14 25.964367 T:2987390032 NOTICE: Thread CRBPWorker start, auto delete: false
20:36:14 26.221331 T:3058479104 NOTICE: Running database version Addons16
20:36:16 27.923151 T:3058479104 NOTICE: ADDONS: Using repository repository.xbmc.org
20:36:16 27.926983 T:3058479104 NOTICE: ADDONS: Using repository repository.openelec.tv
20:36:16 28.351206 T:3058479104 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
20:36:16 28.353731 T:2978391120 NOTICE: Thread CECAdapter start, auto delete: false
20:36:16 28.357088 T:2970002512 NOTICE: Thread PeripBusCEC start, auto delete: false
20:36:16 28.380562 T:2978391120 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(E) returned invalid arg (8)
20:36:16 28.380907 T:2978391120 ERROR: CecLogMessage - Open - vc_cec could not be initialised
20:36:16 28.397923 T:2978391120 ERROR: CecLogMessage - RegisterLogicalAddress - vc_cec_set_logical_address(1) returned invalid arg (8)
20:36:16 28.421423 T:2944836688 NOTICE: Thread CECAdapterUpdate start, auto delete: false
20:36:16 28.672915 T:2936448080 NOTICE: Thread PeripBusUSBUdev start, auto delete: false
20:36:17 28.713665 T:3058479104 NOTICE: Raspberry PI firmware version: May 12 2014 23:41:30
Copyright (c) 2012 Broadcom
version ce12e2f2879f47298fb1ea434386c2e29787ebec (clean) (release)
20:36:17 28.714046 T:3058479104 NOTICE: ARM mem: 384MB GPU mem: 128MB MPG2:0 WVC1:0
20:36:17 28.717115 T:3058479104 NOTICE: Config:
program_serial_random=1
config_hdmi_boost=2
emmc_pll_core=1
hdmi_ignore_cec_init=1
hdmi_force_cec_address=65535
temp_limit=85
force_pwm_open=1
pause_burst_frames=1
avoid_fix_ts=1
20:36:17 28.717794 T:3058479104 NOTICE: Config:
20:36:17 28.718470 T:3058479104 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
20:36:17 28.762838 T:3058479104 NOTICE: Found resolution 720 x 480 for display 0 with 720 x 480i @ 60.000000 Hz
20:36:17 28.763140 T:3058479104 NOTICE: Found ([email protected]) at 16, setting to RES_DESKTOP at 16
20:36:17 28.763708 T:3058479104 NOTICE: Checking resolution 16
20:36:17 28.779213 T:3058479104 NOTICE: GL_VENDOR = Broadcom
20:36:17 28.779631 T:3058479104 NOTICE: GL_RENDERER = VideoCore IV HW
20:36:17 28.779898 T:3058479104 NOTICE: GL_VERSION = OpenGL ES 2.0
20:36:17 28.783747 T:3058479104 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
20:36:17 28.784122 T:3058479104 NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
20:36:19 30.713226 T:3058479104 NOTICE: No Joystick name specified, loading default map
20:36:19 31.624725 T:3058479104 NOTICE: Previous line repeats 35 times.
20:36:19 31.624725 T:3058479104 NOTICE: Running database version Addons16
20:36:19 31.642372 T:3058479104 NOTICE: Running database version ViewModes6
20:36:19 31.666050 T:3058479104 NOTICE: Running database version Textures13
20:36:20 31.725338 T:3058479104 NOTICE: Running database version MyMusic48
20:36:20 31.838966 T:3058479104 NOTICE: Running database version MyVideos78
20:36:20 31.863312 T:3058479104 NOTICE: Running database version TV23
20:36:20 31.881144 T:3058479104 NOTICE: Running database version Epg7
20:36:20 31.882137 T:3058479104 NOTICE: start dvd mediatype detection
20:36:20 31.882761 T:3058479104 NOTICE: initializing playlistplayer
20:36:20 31.883127 T:3058479104 NOTICE: DONE initializing playlistplayer
20:36:20 31.889568 T:3038909520 NOTICE: Thread DetectDVDMedia start, auto delete: false
20:36:22 34.572334 T:3058479104 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:36:22 34.609913 T:3058479104 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:36:23 35.015862 T:3058479104 NOTICE: initialize done
20:36:23 35.016205 T:3058479104 NOTICE: Running the application...
20:36:23 35.020317 T:2924942416 NOTICE: Thread LanguageInvoker start, auto delete: false
20:36:25 37.583721 T:2912941136 NOTICE: Thread JobWorker start, auto delete: true
20:36:26 38.055134 T:3058479104 NOTICE: starting zeroconf publishing
20:36:26 38.056015 T:3058479104 NOTICE: Webserver: Starting...
20:36:26 38.058674 T:3058479104 NOTICE: WebServer: Started the webserver
20:36:26 38.064255 T:2896163920 NOTICE: Thread JobWorker start, auto delete: true
20:36:26 38.072159 T:3058479104 NOTICE: ES: Starting event server
20:36:26 38.084618 T:2862609488 NOTICE: Thread EventServer start, auto delete: false
20:36:26 38.085125 T:2862609488 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:36:26 38.085602 T:2862609488 NOTICE: UDP: Listening on port 9777
20:36:26 38.086987 T:2870998096 NOTICE: Thread JobWorker start, auto delete: true
20:36:26 38.093700 T:2854220880 NOTICE: Thread TCPServer start, auto delete: false
20:36:26 38.201672 T:2837443664 NOTICE: Thread AirPlayServer start, auto delete: false
20:36:26 38.438286 T:2924942416 NOTICE: -->Python Interpreter Initialized<--
20:36:30 42.234379 T:2924942416 NOTICE: ## OpenELEC Addon ## 0.3.16
20:37:39 110.949707 T:2912941136 NOTICE: Thread BackgroundLoader start, auto delete: false
20:37:42 114.447830 T:2912941136 NOTICE: Thread JobWorker start, auto delete: true
20:37:42 114.494324 T:2896163920 NOTICE: Thread BackgroundLoader start, auto delete: false
20:37:55 127.114975 T:3058479104 NOTICE: Previous line repeats 2 times.
20:37:55 127.114975 T:3058479104 NOTICE: COMXPlayer: Opening: /storage/videos/Musik/Pop/Eric Clapton live in Basel 2013.mkv
20:37:55 127.115425 T:3058479104 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:37:55 127.116486 T:2896163920 NOTICE: Thread OMXPlayer start, auto delete: false
20:37:55 127.117348 T:2896163920 NOTICE: Creating InputStream
20:37:55 127.199379 T:2896163920 NOTICE: Creating Demuxer
20:37:56 127.794357 T:2896163920 NOTICE: Opening video stream: 0 source: 256
20:37:56 127.859123 T:2896163920 NOTICE: Creating video thread
20:37:56 127.859940 T:2870998096 NOTICE: Thread OMXPlayerVideo start, auto delete: false
20:37:56 127.860657 T:2896163920 NOTICE: Opening audio stream: 1 source: 256
20:37:56 127.861961 T:2896163920 NOTICE: Creating audio thread
20:37:56 127.862946 T:2779771984 NOTICE: Thread OMXPlayerAudio start, auto delete: false
20:37:56 128.084579 T:2896163920 NOTICE: OMXClock using audio as reference
20:37:56 128.114746 T:2870998096 NOTICE: Display resolution ADJUST : 720x480 (720x480) @ 60.00i - Full Screen (16) (weight: 0.000)
20:37:56 128.626617 T:3058479104 NOTICE: Using GL_TEXTURE_2D
20:37:56 128.633057 T:3058479104 NOTICE: GL: Using BYPASS render method
20:37:56 128.633514 T:3058479104 NOTICE: GL: NPOT texture support detected
20:38:30 161.901276 T:2896163920 NOTICE: COMXPlayer::OnExit()
20:38:30 161.902863 T:2896163920 NOTICE: OMXPlayer: closing audio stream
20:38:30 161.903229 T:2896163920 NOTICE: Closing audio stream
20:38:30 161.908600 T:2779771984 NOTICE: thread end: OMXPlayerAudio::OnExit()
20:38:30 161.986588 T:2896163920 NOTICE: OMXPlayer: closing video stream
20:38:30 161.987000 T:2896163920 NOTICE: Closing video stream
20:38:30 161.987961 T:2870998096 NOTICE: thread end: video_thread
20:38:30 162.085907 T:2896163920 NOTICE: COMXPlayer::OnExit() deleting demuxer
20:38:30 162.092667 T:2896163920 NOTICE: COMXPlayer::OnExit() deleting input stream
20:38:30 162.097595 T:3058479104 NOTICE: COMXPlayer: finished waiting
20:38:30 162.389664 T:2896163920 NOTICE: Thread BackgroundLoader start, auto delete: false
20:38:31 163.263260 T:3058479104 NOTICE: COMXPlayer: finished waiting
20:38:31 163.528564 T:3058463824 NOTICE: Previous line repeats 1 times.
20:38:31 163.528564 T:3058463824 NOTICE: Found 2 Lists of Devices
20:38:31 163.528992 T:3058463824 NOTICE: Enumerated PI devices:
20:38:31 163.529205 T:3058463824 NOTICE: Device 1
20:38:31 163.529633 T:3058463824 NOTICE: m_deviceName : HDMI
20:38:31 163.529938 T:3058463824 NOTICE: m_displayName : HDMI
20:38:31 163.534027 T:3058463824 NOTICE: m_displayNameExtra:
20:38:31 163.534332 T:3058463824 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:38:31 163.534607 T:3058463824 NOTICE: m_channels : FL,FR
20:38:31 163.534836 T:3058463824 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,41400,48000,88200,96000,176400,192000
20:38:31 163.535065 T:3058463824 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
20:38:31 163.537003 T:3058463824 NOTICE: Device 2
20:38:31 163.537460 T:3058463824 NOTICE: m_deviceName : Analogue
20:38:31 163.537689 T:3058463824 NOTICE: m_displayName : Analogue
20:38:31 163.537979 T:3058463824 NOTICE: m_displayNameExtra:
20:38:31 163.538254 T:3058463824 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:38:31 163.538544 T:3058463824 NOTICE: m_channels : FL,FR
20:38:31 163.538757 T:3058463824 NOTICE: m_sampleRates : 48000
20:38:31 163.538971 T:3058463824 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE
20:38:31 163.539185 T:3058463824 NOTICE: Enumerated ALSA devices:
20:38:31 163.539383 T:3058463824 NOTICE: Device 1
20:38:31 163.539764 T:3058463824 NOTICE: m_deviceName : @
20:38:31 163.543671 T:3058463824 NOTICE: m_displayName : Default (snd_rpi_hifiberry_dac Analog)
20:38:31 163.544022 T:3058463824 NOTICE: m_displayNameExtra:
20:38:31 163.544632 T:3058463824 NOTICE: m_deviceType : AE_DEVTYPE_PCM
20:38:31 163.544922 T:3058463824 NOTICE: m_channels : FL,FR
20:38:31 163.545135 T:3058463824 NOTICE: m_sampleRates : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
20:38:31 163.545349 T:3058463824 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
20:38:31 163.633652 T:2870998096 NOTICE: Thread JobWorker start, auto delete: true
20:38:42 173.990662 T:3058479104 NOTICE: DVDPlayer: Opening: /storage/videos/Musik/Pop/Eric Clapton live in Basel 2013.mkv
20:38:42 173.991028 T:3058479104 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:38:42 173.992020 T:2896163920 NOTICE: Thread DVDPlayer start, auto delete: false
20:38:42 173.992828 T:2896163920 NOTICE: Creating InputStream
20:38:42 174.027237 T:2896163920 NOTICE: Creating Demuxer
20:38:42 174.225571 T:2896163920 NOTICE: Opening video stream: 0 source: 256
20:38:42 174.226166 T:2896163920 NOTICE: Creating video codec with codec id: 28
20:38:42 174.245117 T:2779771984 NOTICE: Thread VideoReferenceClock start, auto delete: false
20:38:42 174.245575 T:2896163920 NOTICE: Creating video thread
20:38:42 174.246552 T:2912941136 NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:38:42 174.247086 T:2896163920 NOTICE: Opening audio stream: 1 source: 256
20:38:42 174.247360 T:2896163920 NOTICE: Finding audio codec for: 86017
20:38:42 174.248993 T:2896163920 NOTICE: Creating audio thread
20:38:42 174.249542 T:2912941136 NOTICE: running thread: video_thread
20:38:42 174.250275 T:2779771984 NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:38:42 174.256866 T:2779771984 NOTICE: running thread: CDVDPlayerAudio::Process()
20:38:42 174.327148 T:2779771984 NOTICE: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
20:38:42 174.413010 T:2912941136 NOTICE: fps: 30.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
20:38:42 174.413589 T:2912941136 NOTICE: Display resolution ADJUST : 720x480 (720x480) @ 60.00i - Full Screen (16) (weight: 0.000)
20:38:42 174.528763 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.000000, free buffers: 0
20:38:42 174.663666 T:3058479104 NOTICE: Using GL_TEXTURE_2D
20:38:42 174.671738 T:3058479104 NOTICE: GL: Using OMXEGL RGBA render method
20:38:42 174.672348 T:3058479104 NOTICE: GL: NPOT texture support detected
20:38:43 174.730484 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.000000, free buffers: 0
20:38:43 175.204971 T:2912941136 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:38:43 175.338699 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.400000, free buffers: 0
20:39:09 200.765411 T:2912941136 WARNING: Previous line repeats 1 times.
20:39:09 200.765411 T:2912941136 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:39:10 201.683792 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.400000, free buffers: 0
20:39:17 209.558243 T:2912941136 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:39:18 210.212509 T:2779771984 WARNING: Previous line repeats 2 times.
20:39:18 210.212509 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.450000, free buffers: 0
20:39:31 223.518127 T:2912941136 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:39:32 224.151138 T:2779771984 WARNING: CActiveAEStream::AddData - timeout waiting for buffer, paused: 0, cache time: 0.400000, free buffers: 0
20:39:39 231.512680 T:3058479104 NOTICE: CDVDPlayer::CloseFile()
20:39:39 231.513123 T:3058479104 NOTICE: DVDPlayer: waiting for threads to exit
20:39:39 231.518051 T:2896163920 NOTICE: CDVDPlayer::OnExit()
20:39:39 231.518433 T:2896163920 NOTICE: DVDPlayer: closing audio stream
20:39:39 231.518707 T:2896163920 NOTICE: Closing audio stream
20:39:39 231.518921 T:2896163920 NOTICE: Waiting for audio thread to exit
20:39:39 231.537506 T:2779771984 NOTICE: thread end: CDVDPlayerAudio::OnExit()
20:39:39 231.538834 T:2896163920 NOTICE: Closing audio device
20:39:39 231.590729 T:2896163920 NOTICE: Deleting audio codec
20:39:39 231.593582 T:2896163920 NOTICE: DVDPlayer: closing video stream
20:39:39 231.593887 T:2896163920 NOTICE: Closing video stream
20:39:39 231.594177 T:2896163920 NOTICE: waiting for video thread to exit
20:39:39 231.612228 T:2912941136 NOTICE: thread end: video_thread
20:39:39 231.615570 T:2896163920 NOTICE: deleting video codec
20:39:39 231.615936 T:2896163920 NOTICE: CDVDPlayer::OnExit() deleting demuxer
20:39:39 231.622986 T:2896163920 NOTICE: CDVDPlayer::OnExit() deleting input stream
20:39:39 231.627121 T:3058479104 NOTICE: DVDPlayer: finished waiting
20:39:40 232.021149 T:2896163920 NOTICE: Thread BackgroundLoader start, auto delete: false
20:39:41 232.934097 T:3058479104 NOTICE: CDVDPlayer::CloseFile()
20:39:41 232.936981 T:3058479104 NOTICE: DVDPlayer: waiting for threads to exit
20:39:41 232.937744 T:3058479104 NOTICE: DVDPlayer: finished waiting
20:39:41 232.938232 T:3058479104 NOTICE: CDVDPlayer::CloseFile()
20:39:41 232.938507 T:3058479104 NOTICE: DVDPlayer: waiting for threads to exit
20:39:41 232.939133 T:3058479104 NOTICE: DVDPlayer: finished waiting
20:39:41 232.996964 T:2912941136 NOTICE: Thread JobWorker start, auto delete: true
The dvdplayer playback shows a lot of buffer-problems, and so it looks like on the screen.
I hope this can help to identify the problem. Btw. thank You very much for this brilliant work on openELEC. The current GUI runs very fluency. And my old telly is nearly a smart-tv.
greetings
thomas
popcorn
I skipped build r18277, my fault. It almost works, I mean, the image doesn't freezes, just stops for 1/10 second. It's the same as in build r18335. r18266 works better and any build between r18277 an r18335 works worse. I'm going to test latest build.
I can upload a sample but happens in every mkv I've tried...
Edit: r18411 works fine, at least as fine as 18277 :-) Some "script skin widget whatever error" now but probably nothing to worry about.
Thanks both of you, pocornmix and MilhouseVH.
Edit2: probably it has something to do with this :-)
http://forum.xbmc.org/showthread.php?tid=142389&page=43
nevermind. problem seems to be resolved after resetting.
(2014-05-16, 21:11)MilhouseVH Wrote: [ -> ]New OpenELEC Helix build: #0516
(Supercedes previous build)
With this version sometimes it get stuck on openelec startlogo with milhouse release text on it, and other times i get a dirty startup with stuck on xbmc interface/layer or something text. Got back to previous release to see if happens.
Dont know how to provide log for that cases.
Try removing "quiet" from cmdline.txt - this should show the startup units as they're loaded, see if it's the same unit each time. Does it get far enough to start ssh?
I like your builds, because they are the only Helix builds around, and i like to see the development and improvements.
But i have a strange issue, i think.
After starting your build, i have a high utilization between 60 and 80%, without doing anything. Usually are 20-30% on my RPi (on OE)
Maybe its just me, the SDCard, or whatever else, but i'll attach the debug-log, just to be sure.
http://xbmclogs.com/show.php?id=204256
Edit: I didnt see that an update is available, i updated, and its the same behaviour.
On my 1GHz Pi, it takes XBMC about 2 minutes to settle down to 20% load - during the first two minutes the Pi is maxed out by addons starting up.
Or are you saying it stays at 60-80% load several minutes after starting, with no obvious activity, and with just the main menu selected? Make sure you don't have any scrolling text on screen, as that will send the CPU load through the roof. It could be a rogue addon, try starting with a fresh .xbmc, then add your addons one by one until you identify which is causing the high load.
(2014-05-18, 10:20)RaVeNV1 Wrote: [ -> ]After starting your build, i have a high utilization between 60 and 80%, without doing anything. Usually are 20-30% on my RPi (on OE)
Just after startup, or permanently?
It is usual to have high cpu for the first minute or two (all the add-ons initialise and try to update).
If it stays high continuously then try booting with .xbmc renamed.
That will disable the add-ons and custom settings and you can tell if it's core xbmc taking the CPU or your add-ons/settings.
(2014-05-18, 11:54)MilhouseVH Wrote: [ -> ]Or are you saying it stays at 60-80% load several minutes after starting, with no obvious activity, and with just the main menu selected?
Yep, thats what i meant.
2 or 3 builds ago, i was simply amazed, how "speedy" and responsive your builds are, in comparison to Gotham/OE4.
And i hadn't this behaviour.
I havn't changed anything since this, no new addons installed or anything like this. Just updated your builds via OpenELEC Dev Update.
(2014-05-18, 12:05)RaVeNV1 Wrote: [ -> ]2 or 3 builds ago, i was simply amazed, how "speedy" and responsive your builds are, in comparison to Gotham/OE4.
Can you still do the test of renaming .xbmc. We need to know if the busy cpu is part of core xbmc or an add-on.
(2014-05-18, 12:39)popcornmix Wrote: [ -> ]Can you still do the test of renaming .xbmc. We need to know if the busy cpu is part of core xbmc or an add-on.
Can you give me any advice how to do that?
Via smb i'm not able to do that, and well, i'm searching for a solution myself, but no luck so far.
I'm using Win 8.1, if this matters.
You'll need to connect with ssh - download
PuTTY for Windows then login to your OpenELEC client as user root, password openelec and run the following commands:
systemctl stop xbmc
mv .xbmc .xbmc.bak
sync
reboot
This will now restart your Pi without any third-party XBMC addons (or advancedsettings.xml, or media library).
Confirm if the idle load is reduced - if it is, then it's being caused by an addon. You could now reconfigure your system and add addons one by one monitoring the CPU load until it stays high, then you know which addon is causing the problem.
Or, to revert back to your old settings:
systemctl stop xbmc
rm -fr .xbmc
mv .xbmc.bak .xbmc
sync
reboot
(2014-05-18, 10:20)RaVeNV1 Wrote: [ -> ]But i have a strange issue, i think.
Seeing the same as RaVeNV1, cpu 70-80% with no activity.
This is with a new xbmc folder.
