Full Version: OpenELEC Testbuilds for RaspberryPi Part 3 (Kodi 14.0)
New OpenELEC Helix build: #1111
(Supercedes previous build)
# uname -a
Linux rpi512 3.17.2 #1 PREEMPT Tue Nov 11 22:25:12 GMT 2014 armv6l GNU/Linux
# vcgencmd version
Nov  7 2014 17:01:00
Copyright (c) 2012 Broadcom
version 3bd41a132583ec90e4a0410a4aa631d1e4e2d8ea (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20141111222404-r19619-gc844e21 [Build #1111]
Based on tip of OpenELEC master (c844e210, changelog) and tip of XBMC master (bd7da380, changelog) with the following modifications:
  • Includes newclock4 patches
  • Excludes the OpenELEC fernetmenta patches due to conflicts with newclock4
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-3.17.y
  • Excludes the OpenELEC xbmc-001-newclock4 patch in favour of sourcing these and possibly more recent patches directly from newclock4 branch
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Adapted service.openelec.settings to take advantage of PR:5217 [patch details]
  • Includes latest libnfs master (4a58e614)
  • Includes latest libcec master (260df18a)
  • Includes latest xbmc-pvr-addons master (bd3f2de9)
  • Includes latest xbmc-addon-xvdr master (328fa653)
  • Includes CONFIG_COREDUMP=y to allow creation of coredumps (see here)
  • Includes additional ffmpeg codecs/muxers enabled for testing/benchmarking purposes (see patch)
  • Includes commits from libcec-2.2.0 (popcornmix)
  • Includes PR:373: Release v1.9.25 (kodi-pvr-addons)
  • Includes PR:374: [pvr.hts] Backported GetPlayingTime from pvr.tvh. (kodi-pvr-addons)
  • Includes PR:5573: webserver: improved caching control (see discussion)
  • Includes PR:5625: Fix library clean/scan after #5324 when started from a remote.
  • Includes PR:5629: [PVR] Timeshifting: Fixed EpgInfoTag::[IsActive|WasActive|InTheFuture]
  • Includes PR:5663: Add RunScript backwards compatibility
  • Includes PR:5688: fix 'action' type addon settings not executed if id attribute is missing
  • Reverted e502b099: Reason: may be responsible for ISO playback issues?
Build Highlights:
  1. "add canseek and drop unused rtmp options" - should fix hangs while watching live streams and accidentally seeking (see discussion, thanks wsnipex & popcornmix)
  2. Reduce threshold for resetting demuxer when audio/video out of sync from 2 seconds to 1 second
Build Details:
  1. OpenELEC:
    • projects/imx6/linux: enable RTC on TBS Matrix system (PR:3602, 1 commit, 2 files changed)
    • [SDL2] add patch for missing axes (PR:3593, 1 commit, 1 file changed)
    • tbs-linux-drivers: update to v141019 (PR:3586, 1 commit, 1 file changed)
    • update NVIDIA drivers to 340.58v (PR:3608, 1 commit, 1 file changed)
    • projects/imx6/patches/libcec: remove project based libcec patches (fcbbd034)
    • projects/imx6/patches/linux: update project based CEC driver patches (4af9f407)
    • libcec: update to libcec-2.2.0 for all plattforms, add updated patch to add support for iMX6 systems (ba41891f)
    • projects/imx6/patches/kodi: remove libcec-2.1 support patch (9a6b715f)
    • OpenELEC-settings: update to OpenELEC-settings-0.5.3 (b436b09f)
    • xorg-server: update to xorg-server-1.16.2 (9f20e71f)
    • lirc: specify localstatedir so /run/lirc is used for socket and pid files (ebd56774)
    • irserver: change lirc's runtime dir to /run/lirc (26d87ad0)
    • kodi: Add av.xml setting to set minimal sample rate (c844e210)
  2. XBMC:
    • binary addons: fix dependency handling for dependencies (PR:5680, 1 commit, 1 file changed)
    • AE: Some more coverity fixes this time for ActiveAE (PR:5668, 3 commits, 17 files changed)
    • [infomanager] only update a/v info if something has changed and only by ... (PR:5676, 1 commit, 15 files changed)
    • videorefclock: fix clock speed for D3D after refactoring (PR:5679, 1 commit, 6 files changed)
    • AE: Some fixes for the Cubox hardware (PR:5682, 2 commits, 2 files changed)
    • renderer: use 3 render buffers for sw decoding, restores bahavior after ... (PR:5689, 1 commit, 3 files changed)
    • dvdplayer: improved dropping control (PR:4639, 3 commits, 7 files changed)
    • [lang] update of internal addon language files (8e465155)
    • [lang] update of core language files (9425fba4)
    • [lang] update of skin.confluence language files (317683bc)
    • [lang] update of internal addon language files (c3dbcbbc)
    • [lang] update of core language files (98aad9ef)
    • [lang] update of skin.confluence language files (194c2cb6)
  3. kodi-pvr-addons:
    • [lang] update of language files from Transifex (c4071323)
    • [lang] remove old string.xml file from filmon addon (bd3f2de9)
  4. newclock4:
    • New commits in this build:
      • squash: try with 1 second threshold for resetting demuxer when audio/video out of sync (c4e6c0de)
      • add canseek and drop unused rtmp options (2e0fc979)
      • [resamplepi] Try to report the same numbers as ffmpeg (41d018ec)
      • [dvdplayer] New scheme for PLL adjustment for video clock (312dad90)
    • Commits no longer in build:
      • videoplayer: adapt lateness detection and dropping to buffering (83a43f13)
      • video player: present correct pts to user for a/v sync (after buffering in renderer) (cd8844cc)
      • videoplayer: update frametime, it might change due to fps detection (aa2d1a6b)
      • only update a/v info if something has changed and only by main thread (08519b63)
(2014-11-11, 20:00)Forage Wrote: [ -> ]This makes "Video info scanner fix: scan the entire subtree of path passed to scanner. (PR:5343, 1 commit, 2 files changed)" a likely suspect if you ask me.
I've uploaded an "experimental" build based on #1111 with PR5343 reverted: #1111b.
Can you test #1111b and let us know what difference it makes with your VOB scanning.
Hello,
I see a update for nvidea and cubebox.
Is that version not for raspi only?
(2014-11-11, 23:20)vbat99 Wrote: [ -> ]Just a question, are there only VOB files within the VIDEO_TS folder? Are there IFO and BUP files?
Yes, IFO and BUP files are present as well. I left them out of my post for simplicity's sake.
(2014-11-12, 00:03)Milhouse Wrote: [ -> ]Regarding the library scanning of VOB files, you probably need to create a separate thread for that in the general section as it's now merged and likely to be an issue for all platforms.
(2014-11-12, 06:20)Milhouse Wrote: [ -> ]
Thank you for creating this build! I'll test it later this afternoon and report my findings. I'll start a separate thread on the matter than as well.
(2014-11-12, 08:10)Heiko123 Wrote: [ -> ]Hello,
Yes, those updates apply to non-Pi builds however I now include all changes from OpenELEC master since the last build in the release notes so that nothing is overlooked when subsequently trying to track down bugs and regressions - in the past we had a Cubibox commit that caused a problem for Pi (even though it shouldn't) and because non-Pi changes were "filtered out" of the release notes tracking down this problem became harder than it should have been. Just ignore non-Pi changes, they're "for information only".
Although if there's too much noise from project-specific commits (eg. projects/imx6) I may try and filter those, which should be "safe".
@popcornmix noticed that you updated try with 1 second threshold for resetting demuxer when audio/video out of sync, seems to recover faster now Smile . Will you push this patch to master so that problem is also fixed on other platforms?
(2014-10-22, 09:42)platin Wrote: [ -> ]hi there, since version #1020 and #1021 the addon openelecdevupdate stop working, this is my log
05:21:53 47201.980469 T:2675962960 NOTICE: -->Python Interpreter Initialized<--
05:21:53 47202.234375 T:2675962960 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named bs4
File "/storage/.xbmc/addons/script.openelec.devupdate/service.py", line 12, in <module>
from resources.lib import builds
File "/storage/.xbmc/addons/script.openelec.devupdate/resources/lib/builds.py", line 10, in <module>
from bs4 import BeautifulSoup, SoupStrainer
ImportError: No module named bs4
maybe you can fix this...
rgds
I've fixed this in version 3.7.0. The periodic new build checks (every 3 hours) now work on the latest builds.
(2014-11-10, 14:19)popcornmix Wrote: [ -> ]
(2014-11-10, 05:47)sdsnyr94 Wrote: [ -> ]Everything is working great, except for when I use the NHL Gamecenter addon. Each feed that I play, the audio is a few seconds ahead of the video. The first Milhouse version I tried was a week ago and it existed, as well as the current build and the official beta build.
Here is the log: http://pastebin.com/cCxbZ1gb
I also just downgraded to stable 4.2.1 and the issue exists there also. This does not happen at all on my ION unit using either Gotham or Helix Beta, and it is connected using all the same cables as the Pi (I am swapping back and forth to test).
Can you try disabling omxplayer acceleration (in settings/video/acceleration)?
Sorry that I do not have a log to post, I will when I free up some time. I tried disabling OMXPlayer last night, and while the audio and video remained in sync, the video was a little jumpy... as if it was dropping/skipping video frames. With omxplayer on it video is a lot smoother but audio is a few seconds off.
There are a couple of people on the add-ons thread that are using Raspbmc... I may load that for comparison this weekend.
(2014-11-12, 11:08)gendo Wrote: [ -> ]@popcornmix noticed that you updated try with 1 second threshold for resetting demuxer when audio/video out of sync, seems to recover faster now Smile . Will you push this patch to master so that problem is also fixed on other platforms?
Still trying things. Next build will disable the demuxer reset and try a different patch (suggested here).
Whatever solution is determined to be right will be pushed to master.
(2014-11-12, 18:23)popcornmix Wrote: [ -> ]
Great will test new build and let you know.
(2014-11-07, 23:41)Milhouse Wrote: [ -> ]
(2014-11-07, 22:58)Bohlendach Wrote: [ -> ]reg. #1106
(2014-11-07, 00:36)Milhouse Wrote: [ -> ]PR:5660: Fix SMB files reading on POSIX platforms (no longer need to revert e502b099 to prevent ISO/IFO over SMB segfault)
The problem with iso's previously reported appears agian. I had no problem with previous build (#1105)
Ahk, it's been merged now. Do you have a sample of an ISO that doesn't play over SMB with #1106 but which does with #1105?
Can you also provide a debug log from #1105 AND #1107 (upload both to pastebin), to see the difference in behaviour. I've posted a note on PR:5660.
Milhouse, did this fix the problem? PR #5694! and PR #5700 Smile
Do you include it in the next build?
(2014-11-12, 12:13)Leopold Wrote: [ -> ]
rgds
thank you for your effort
Ooo, with the new version, I have trouble with video over lan.
I dont can skip or fast forward.
Its jump to the beginn or i get a freeze.
Im actually back to 19552.
Yes! That fixed it. Good to know.
What is the best way to proceed? Start a new thread about it in the general forum or comment on the PR?
(2014-11-12, 22:06)Bohlendach Wrote: [ -> ]Milhouse, did this fix the problem? PR #5694! and PR #5700 Smile
It appears to have fixed it, using your "NOT_OK" VIDEO_TS - it will be in the next build (uploading now...)
