2014-08-15, 17:11
Below the log file. I may be too impatient. Let me let it "sit" overnight and see whether it eventually work out.
https://www.paste.to/DKswLCG
<loglevel hide="true">2</loglevel>
<audio>
<defaultplayer>omxplayer</defaultplayer>
</audio>
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164540 wlan.N[1293] IO80211AWDLPeerManager::configureStrategy() AirPlay services:2, others:0 schedstate:Minimum insertInfraForAirplay(1), _useInfraOnSocialTimeslots(1), _setMasterChannelToInfra(1), dynamic_off(1)
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164605 wlan.N[1294] awdl-interfaceStateChange: Channel 36 is not allowed in this locale; default allowed channel 6
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164634 wlan.N[1295] awdl-interfaceStateChange: [reason: Mdns] ENABLE-AWDL (state 0x5 CONFIGURED QUIET _syncState 1 numservices 3 (valid 2) valid_infra 1 cur_infra_channel 36 awdl_solo 0 _mdns_trigger 1 AwdlStateMachine)
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164679 wlan.N[1296] awdl-interfaceStateChange get infra channel valid 1 infraChannel 36 flags 20 _stateFlags 5 strategy 1 masterChannel 36/0 syncConfigured channelConfigured
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164831 wlan.A[1297] AppleBCMWLANProximityInterface::setSYNC_ENABLED(): set AWDL->ON pm 8 minExt 7 MasterChan 36/0 step 7 [36 36 36 36]
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164854 wlan.A[1298] AppleBCMWLANProximityInterface::doSetSyncState(): Cancelled fAWDLOffTimer
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.164946 wlan.N[1299] awdl-interfaceStateChange did enable state 3
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.167752 wlan.N[1300] IO80211AWDLPeerManager::updateLocalRequests() Added Advertising Service
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.167830 wlan.N[1301] IO80211AWDLPeerManager::configureStrategy() AirPlay services:2, others:0 schedstate:MinimumFast insertInfraForAirplay(1), _useInfraOnSocialTimeslots(1), _setMasterChannelToInfra(1), dynamic_off(1)
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.167884 wlan.N[1302] awdl-interfaceStateChange: Channel 36 is not allowed in this locale; default allowed channel 6
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.167912 wlan.N[1303] awdl-interfaceStateChange: [reason: Mdns] ENABLE-AWDL (state 0x3 CONFIGURED SYNC-ACTIVE _syncState 1 numservices 3 (valid 2) valid_infra 1 cur_infra_channel 36 awdl_solo 0 _mdns_trigger 1 AwdlStateMachine)
Aug 15 18:40:55 mguillon-iPhone kernel[0] <Debug>: 104263.167954 wlan.N[1304] awdl-interfaceStateChange get infra channel valid 1 infraChannel 36 flags 20 _stateFlags 3 strategy 1 masterChannel 36/0 syncConfigured !channelConfigured
Aug 15 18:40:59 mguillon-iPhone kernel[0] <Debug>: AppleH6CamIn::setPowerStateGated: 0
Aug 15 18:40:59 mguillon-iPhone kernel[0] <Debug>: AppleH6CamIn::power_off_hardware
Aug 15 18:41:01 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:01.311830 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:03 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:03.355202 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:05 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:05.398542 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:05 mguillon-iPhone kernel[0] <Debug>: 104273.229386 wlan.A[1305] AppleBCMWLANProximityInterface::setSYNC_ENABLED(): set AWDL->OFF
Aug 15 18:41:07 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:07.441886 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:09 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:09.485273 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:11 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:11.528664 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:13 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:13.571982 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:15 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:15.615331 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:17 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:17.658704 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:19 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:19.702045 PM [AirPlay] ### Audio buffer full for get: 4096 > 0
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.356219 PM [AirPlay] ### Endpoint "XBMC (OpenELEC)" options error: -6722/0xFFFFE5BE kTimeoutErr
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.356604 PM [AirPlay] Start summary: TP=WiFi E=RSA L=2000 ms Bonjour=5 ms Connect=4 ms Auth=0 ms Ann=0 ms Setup=0 ms Rec=0 ms Total=30012 ms Err -6722/0xFFFFE5BE kTimeoutErr
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.356998 PM [AirPlay] Disconnected from 192.168.1.20:36666
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.357382 PM [AirPlay] ### Endpoint "XBMC (OpenELEC)" start failed: -6722/0xFFFFE5BE kTimeoutErr
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.357736 PM [BonjourBrowser] Reconfirming PTR for XBMC (OpenELEC)._airplay._tcp.local. on en0
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.358043 PM [BonjourBrowser] Reconfirming PTR for B827EBBC247C@XBMC (OpenELEC)._raop._tcp.local. on en0
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.358621 PM [AirPlay] Tore down for stream GeneralAudio
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.359081 PM [AirPlay] Posted 'com.apple.AirTunes.endpointStartError' with -6722/0xFFFFE5BE kTimeoutErr
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.359216 PM [AirPlay] Posting kAudioDevicePropertyDataSourceInfoForID: item 77 error: -6722/0xFFFFE5BE kTimeoutErr
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.359711 PM [AirPlay] Client stop finished
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.359901 PM [AirPlay] Quiescing endpoint 'XBMC (OpenELEC)'
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.360126 PM [AirPlay] Posting EndpointDeactivated on quiesce for item 77
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: >vad< ERROR: 18:41:21.361 [tid 0x1024a4000] [158]: CAException thrown from property listener: 4294960569.
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.371728 PM [AirPlay] Stopping HAL audio for AirPlay < Output >
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Notice>: 2014-08-15 06:41:21.375221 PM [AirPlay] Client stop finished
Aug 15 18:41:21 mguillon-iPhone mediaserverd[50] <Error>: 18:41:21.512 ERROR: [0x1029f4000] >aqme> 241: (0x1310825b0): scope 1, element 0, tag=0x0, 2 channel descriptions [L, R]: error -10851
(2014-08-15, 17:16)Milhouse Wrote: [ -> ]Yes, give it some time - it's got a few databases to update - it will need to upgrade the video database in sequence from v78 to 79 to 85 to 86 to 87 to 88 and finally to 89...
Once it finishes, check the log carefully for errors!
(2014-08-15, 20:03)goRt Wrote: [ -> ]Is that correct, I've done extensive DB testing and the logs I see show XBMC looking backwards from the version it hopes for and then doing a conversion from there for example directly from 78 to 89. SQL doesn't show the intermediate steps.
# uname -a
Linux openelec 3.16.1 #1 PREEMPT Fri Aug 15 22:12:41 BST 2014 armv6l GNU/Linux
# vcgencmd version
Aug 12 2014 18:21:28
Copyright (c) 2012 Broadcom
version f32b2bbfdea55d48c9a52b92e5c798f9aa5f47bc (tainted) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20140815221129-r19018-g3f60dde
/usr/bin/configrpi256.sh
popcornmix Wrote:There is a new sdcard driver in 3.16 tree.
Make sure these are in the kernel config:
CONFIG_DMA_BCM2708=y
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_MMC_BCM2835=y
CONFIG_MMC_BCM2835_DMA=y
CONFIG_MMC_PIO_DMA_BARRIER=2
By default you get the old driver, but you can choose the new driver with (added to cmdline.txt)
Code:bcm2708.bcm2835_mmc=1
This is expected to become the default sdcard driver in the future. It should avoid some of the issues of the old driver, like polling with interrupts disabled, and could improve performance and avoid interfering with other drivers (e.g. USB or LIRC).
Testers are encouraged, and backing up the sdcard before testing would be advisable.
I've been using it over the last week without any issues.
[ 1.544512] Load BCM2835 MMC driver
(2014-08-16, 03:35)Milhouse Wrote: [ -> ]@edwr: Have you tested build #0815? I don't have a current iOS device so can't really help with Air-* problems.
(2014-08-16, 08:35)darzur Wrote: [ -> ]Something is wrong with virtual keyboard and all text entry fields. I'm no longer able to input text using my remote's SMS like 0-9 buttons. It was possible in official builds.
