I pay for Sport Net Now. I've entered my login credentials in the app in kodi. It will not work. I keep being told that it can't authorise the login. The only way it'll work, is if I download the actual app from the play store, and install it on the home screen of the Android box. The repo app will not work in kodi itself.
Also, when I go into the settings of the app and do the updates, or try to open it from there, I'm still getting authorization errors.
Hey micahg, new to the Kodi forum. Won't let me send you a pm with my telus info. If you got some time can you message me pls. Thanks.
Hey micagh I tried to pm you about the Sportsnet now app and I could not send it as it said was not authorized to send a message.
Here is the issue. I added the Sportsnet now addon for my sister as she has MS and loves bluejays but lately she could not find link on castaway or the devil.
So I installed the app and added the shortcut to her sports folder.
I put my user and pass in and it worked for five innings then kicked her out and now get stupid authorization error.
Can you help?
She doesn't much have much but she loves her jays.
I'm having the same problem. Input my login credentials but when I select a channel I get an unable to authorize error. Any help would be appreciated.
Same problem here. App on my phone and tablet works fine, but app on kodi shows authentication failed. I turned on the debug log but dont see any issues. Not sure what the problem is.
17:23:25 T:139717900294080 DEBUG: OnKey: 11 (0x0b) pressed, action is Select
17:23:25 T:139717900294080 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.snnow/?abbr=SNOntario&id=3&menu=channel&name=Sportsnet%20Ontario&plot=Minnesota%20%40%20Detroit&title=Minnesota%20%40%20Detroit&tvshowtitle=MLB%20Baseball)
17:23:25 T:139717900294080 DEBUG: ParentPath = [plugin://plugin.video.snnow/]
17:23:25 T:139715882800896 DEBUG: StartScript - calling plugin Sportsnet Now('plugin://plugin.video.snnow/','27','?abbr=SNOntario&id=3&menu=channel&name=Sportsnet%20Ontario&plot=Minnesota%20%40%20Detroit&title=Minnesota%20%40%20Detroit&tvshowtitle=MLB%20Baseball')
17:23:25 T:139715882800896 DEBUG: WaitOnScriptResult - waiting on the Sportsnet Now (id=46) plugin...
17:23:25 T:139716653459200 NOTICE: Thread LanguageInvoker start, auto delete: false
17:23:25 T:139716653459200 INFO: initializing python engine.
17:23:25 T:139716653459200 DEBUG: CPythonInvoker(46, /home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py): start processing
17:23:25 T:139716653459200 NOTICE: -->Python Interpreter Initialized<--
17:23:25 T:139716653459200 DEBUG: CPythonInvoker(46, /home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py): the source file to load is "/home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py"
17:23:25 T:139716653459200 DEBUG: CPythonInvoker(46, /home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py): setting the Python path to /home/mediacenter/.kodi/addons/plugin.video.snnow-master:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
17:23:25 T:139716653459200 DEBUG: CPythonInvoker(46, /home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py): entering source directory /home/mediacenter/.kodi/addons/plugin.video.snnow-master
17:23:25 T:139716653459200 DEBUG: CPythonInvoker(46, /home/mediacenter/.kodi/addons/plugin.video.snnow-master/default.py): instantiating addon using automatically obtained id of "plugin.video.snnow" dependent on version 2.1.0 of the xbmc.python api
17:23:26 T:139717900294080 DEBUG: ------ Window Init (DialogBusy.xml) ------
17:23:27 T:139716653459200 NOTICE: ()
17:23:27 T:139716653459200 DEBUG: LocalizeStrings: no strings.po file exist at /home/mediacenter/.kodi/addons/plugin.video.snnow-master/resources/language/English, fallback to strings.xml
17:23:27 T:139717900294080 DEBUG: ------ Window Init (DialogOK.xml) ------
Having same problem as mentioned, I can see all the channels, but when I click any channel to play it, I get the error Unable to Authenticate the channel. I assume they changed something and broken the Kodi scraper. I hope OP can take a look and hopefully come up with a fix. Back to watching on the web for now.
I am also having issues with sportsnet now but now it will not even open at all.
Also having issues here. We normally had to reboot several times to stop getting the "Unable to authorize channel" message, but the last couple days, it doesn't work at all. Just a "Sportsnet Now error" message. Here's a section from my log file, if that helps
16:51:16 T:5856 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin Sportsnet Now('plugin://plugin.video.snnow/','4','')
16:51:16 T:5856 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the Sportsnet Now (id=5) plugin...
16:51:16 T:8636 DEBUG: Thread LanguageInvoker start, auto delete: false
16:51:16 T:8636 INFO: initializing python engine.
16:51:16 T:8636 DEBUG: CPythonInvoker(5, C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py): start processing
16:51:17 T:8636 DEBUG: -->Python Interpreter Initialized<--
16:51:17 T:8636 DEBUG: CPythonInvoker(5, C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py): the source file to load is "C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py"
16:51:17 T:8636 DEBUG: CPythonInvoker(5, C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py): setting the Python path to C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
16:51:17 T:8636 DEBUG: CPythonInvoker(5, C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py): entering source directory C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow
16:51:17 T:8636 DEBUG: CPythonInvoker(5, C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py): instantiating addon using automatically obtained id of "plugin.video.snnow" dependent on version 2.1.0 of the xbmc.python api
16:51:17 T:5804 DEBUG: ------ Window Init (DialogBusy.xml) ------
16:51:18 T:8636 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('ed',)
File "C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py", line 142, in <module>
createMainMenu()
File "C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py", line 50, in createMainMenu
guide = sn.getGuideData()
File "C:\Users\timv\AppData\Roaming\Kodi\addons\plugin.video.snnow\snnow.py", line 172, in getGuideData
description = curr_item.attributes['ed']
File "C:\Program Files (x86)\Kodi\system\python\Lib\xml\dom\minidom.py", line 522, in __getitem__
return self._attrs[attname_or_tuple]
KeyError: ('ed',)
16:51:18 T:8636 INFO: Python script stopped
16:51:18 T:8636 DEBUG: Thread LanguageInvoker 8636 terminating
16:51:18 T:5804 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
16:51:18 T:10060 INFO: CActiveAESink::OpenSink - initialize sink
16:51:18 T:10060 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
16:51:18 T:10060 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 000B0A5C
16:51:18 T:5856 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
16:51:18 T:10060 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
16:51:18 T:10060 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
16:51:18 T:10060 DEBUG: Audio Device : Speakers (High Definition Audio Device)
16:51:18 T:10060 DEBUG: Sample Rate : 44100
16:51:18 T:10060 DEBUG: Sample Format : AE_FMT_FLOAT
16:51:18 T:10060 DEBUG: Bits Per Sample : 32
16:51:18 T:10060 DEBUG: Valid Bits/Samp : 32
16:51:18 T:10060 DEBUG: Channel Count : 2
16:51:18 T:10060 DEBUG: Block Align : 8
16:51:18 T:10060 DEBUG: Avg. Bytes Sec : 352800
16:51:18 T:10060 DEBUG: Samples/Block : 32
16:51:18 T:10060 DEBUG: Format cBSize : 22
16:51:18 T:10060 DEBUG: Channel Layout : FL,FR
16:51:18 T:10060 DEBUG: Channel Mask : 3
16:51:18 T:10060 DEBUG: Frames : 661
16:51:18 T:10060 DEBUG: Frame Samples : 1322
16:51:18 T:10060 DEBUG: Frame Size : 8
16:51:18 T:10060 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
16:51:18 T:10060 DEBUG: Output Device : default
16:51:18 T:10060 DEBUG: Channel Layout: FL,FR
16:51:18 T:5804 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.snnow/
16:51:18 T:5804 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.snnow/) failed
16:51:18 T:5804 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video)
16:51:18 T:5804 DEBUG: ParentPath = [addons://sources/]
16:51:18 T:6412 DEBUG: Thread BackgroundLoader start, auto delete: false
16:51:18 T:6412 DEBUG: Thread BackgroundLoader 6412 terminating
16:51:18 T:10060 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
16:51:18 T:5804 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
Are there any fixes at all for this or not yet.
Yup I am getting the error as well, with Rogers credentials entered. No problem yesterday, just today. This is my go to app, especially with the World Cup tomorrow.
Please help!
I'll jump in and say that I'm having the same issue. My SN NOW section in the Sportsnet Android app works fine.
New to all this, can someone please help me to install sportsnet now. after install I cant get it to work.
[email protected]
Here's a quick fix for the KeyError:
13:20:00 T:11424 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
File "C:\Users\Mike\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py", line 142, in <module>
createMainMenu()
File "C:\Users\Mike\AppData\Roaming\Kodi\addons\plugin.video.snnow\default.py", line 50, in createMainMenu
File "C:\Users\Mike\AppData\Roaming\Kodi\addons\plugin.video.snnow\snnow.py", line 172, in getGuideData
KeyError: ('ed',)
index 021db23..86c0985 100644
--- a/snnow.py
+++ b/snnow.py
@@ -169,10 +169,16 @@ class SportsnetNow:
except:
title = curr_item.attributes['e']
episode = curr_item.attributes['e']
- description = curr_item.attributes['ed']
+ try:
+ description = curr_item.attibutes['ed']
+ show['plot'] = description.value.encode('utf-8').strip().decode('utf-8')
+ except:
+ show['plot'] = 'No description found'
show['tvshowtitle'] = title.value.encode('utf-8').strip().decode('utf-8')
show['title'] = episode.value.encode('utf-8').strip().decode('utf-8')
- show['plot'] = description.value.encode('utf-8').strip().decode('utf-8')
guide[cid] = show
(2016-09-17, 19:45)mifa Wrote: [ -> ]Here's a quick fix for the KeyError:
createMainMenu()
KeyError: ('ed',)
--- a/snnow.py
+++ b/snnow.py
except:
+ try:
+ except:
guide[cid] = show
Where do I put this fix?
I am so confused. Is there a fix and if so can someone please post in plain English?
