2016-04-24, 12:57
BTW Extended Info Script. Is it already implemented in reFocus Jarvis skin? Sorry for dumb question, but I've installed it and don't see any button for it.
(2016-04-22, 23:13)Jeroen Wrote: [ -> ]Actor info is definitely showing for meNothing.
What happens when you try to access it ?
(2016-04-25, 10:29)lstar337 Wrote: [ -> ](2016-04-22, 23:13)Jeroen Wrote: [ -> ]Actor info is definitely showing for meNothing.
I assume I am using it right?
Press cast, highlight actor, hit context button, nothing happens.
This is how it has always been for me.
I can load extended info using the addon ok.
Does anybody else have it working?
(2016-04-25, 10:46)lstar337 Wrote: [ -> ]Jeroen, will we see the watchlist widget working properly again soon?
I miss it so much!
(2016-04-25, 10:44)Jeroen Wrote: [ -> ]it is accessible from the library, not from the movie / tv show info dialog. There is no context menu within those windows. Clicking it from within the info dialog will open the library for that actor.Oh really?
(2016-04-25, 10:48)Jeroen Wrote: [ -> ]It is working but using a different source. You probably just have to remove the widget and then add it again. Only then, that triggers a rebuild of the widget.OK, thanks!
(2016-04-25, 10:52)lstar337 Wrote: [ -> ](2016-04-25, 10:44)Jeroen Wrote: [ -> ]it is accessible from the library, not from the movie / tv show info dialog. There is no context menu within those windows. Clicking it from within the info dialog will open the library for that actor.Oh really?
That doesn't seem very intuitive. Would it not be possible to have it accessible from the info dialog?
I have only been into the actor section of the library once, and I doubt I will ever do it again as there are literally hundreds of thousands of actors in there and it takes so much time to find somebody specific.
(2016-04-25, 11:03)Jeroen Wrote: [ -> ]Is it a limitation of Kodi then?(2016-04-25, 10:52)lstar337 Wrote: [ -> ](2016-04-25, 10:44)Jeroen Wrote: [ -> ]it is accessible from the library, not from the movie / tv show info dialog. There is no context menu within those windows. Clicking it from within the info dialog will open the library for that actor.Oh really?
Impossible, sorry.
(2016-04-23, 14:22)Jeroen Wrote: [ -> ]Forgot to get back at you about this, sorry. A video would be helpful yes. Even though it looks mostly the same the entire widget implementation was rewritten completely for 3.0 so it's totally possible some things behave differently, intended or not.
(2016-04-25, 11:09)lstar337 Wrote: [ -> ](2016-04-25, 11:03)Jeroen Wrote: [ -> ]Is it a limitation of Kodi then?(2016-04-25, 10:52)lstar337 Wrote: [ -> ]Oh really?
Impossible, sorry.
I'm sure I have seen this functionality in other skins.
