2016-05-08, 00:24
(2016-05-06, 01:49)Gonzo12 Wrote: [ -> ]Why no In-App-Browser to verify the login? o_O
If you deliver me a Kodi compatible browser
(2016-05-05, 02:45)darkdays Wrote: [ -> ]Found something that might be a bug or weird behavior. I get "this track is not available in your country" quite a lot in my playlists, which is strange since they've always worked here before both in Spotimc and in the Spotify PC & android app. When I go to "artist top tracks" for Townes van Zandt all the songs the addons lists refuse to play with that message. But if I browse his albums I can play the same songs just fine in the addon. Seems odd.
(2016-05-08, 00:44)pike Wrote: [ -> ]Will this nice add-on support 'Connect to a device' (sorry translated from Swedish) from Spotify (ios)?
Maybe it's called Spotify Connect?
(2016-05-04, 12:32)Purge Wrote: [ -> ]ok, here is the log from today :
(2016-05-05, 01:19)darkdays Wrote: [ -> ]It is indeed, but it is still a bit unintuitive to me to get thrown back to the plugin root. I guess I expect to end up where I was just before I went off.I think it's Kodi's default behaviour for the context menu actions. I'm not sure if I can even fix that.
I guess my intuition would be a behaviour like this; if I'm in /root/my music/playlists/playlist/song/artists top tracks/ and press back I go one step down in the tree rather than all the way to root. Would this behaviour make any sense?
(2016-05-05, 01:19)darkdays Wrote: [ -> ]Sure is, but seems like it is called "Messages" in the Spotify apps and is hidden behind a strange icon next to the user icon. (Maybe it changed or maybe it has always been called that, my Spotify usage has been 99% Spotimc the last year or two ) It contains songs sent to you by your friends. In my Spotimc it is displayed at the top of the playlist list by default(?) along with Starred and Discover Weekly.Seems that Spotify has dropped that in their current API, also I don't see it in the native apps anymore. Both messages and starred are gone from the API. As Spotimc still uses the deprecated libspotify sdk it might explain why that still works.
(2016-05-05, 01:19)darkdays Wrote: [ -> ]ps. I'm going to try and write up some more suggestions regarding navigation, behaviour, etc later on.. Being able to add songs/albums to the queue would be nice for instance. But will take some time to figure out which strange behaviours are related to the addon and which are related to the skin or Kodi. ds.
(2016-05-05, 02:27)darkdays Wrote: [ -> ]Turn off/make optional(Spotimc handled this quite nicely)/separate "Appears on"-results from the actual artists albums when listing "All albums for
(2016-05-05, 13:31)darkdays Wrote: [ -> ]I think you only have to do it when there's certain updates that need new permissions(?), so I don't think it will happen that often.
(2016-05-06, 09:11)Njaynl Wrote: [ -> ]A nice option would be a shuffe playlist option is that possible ?
(2016-05-08, 11:15)debutanker Wrote: [ -> ]hi,
thx for the nice addon!
i wanted to test it with the actual x86 libreelec 8.0 milhouse-testbuild (kodi krypton).
added my login, opend the addon, got the succeded chromium browser window and after i wanted to close the browser kodi shows a black screen....
is the addon compatible with this krypton testbuild?
