2017-09-21, 20:01
(2017-09-21, 11:30)Mowa Wrote: [ -> ]Dear Marcel,
Still waiting patiently for the release of the update.
Oops, something went wrong committing the new version.
It should now populate to the repo
(2017-09-18, 16:36)Meschugge Wrote: [ -> ]i have a short question. When i save a spotify-playlist local on libreelec and play the music, kodi doesn't show the artist or the titel of the song...only the last three digits from the http-address....in this example the number "219":
(2017-09-19, 16:32)bebox Wrote: [ -> ]Hi Marcel - thank you so much for this so long awaited Addon! Works really great (togehther with my Kindle App and ALEXA) hihihi For the moment just one Q: what about <Volume control? Did you see any solution to control volume on spotify connected devices from inside Kodi ?
Again! Thanks and all the best to you!
Cheers joerg
(2017-09-14, 23:03)a1rwulf Wrote: [ -> ](2017-09-03, 21:27)marcelveldt Wrote: [ -> ](2017-08-18, 15:16)a1rwulf Wrote: [ -> ]@marcelveldt now that the addon does not rely on libspotify anymore and is fully opensource (unless I missed something), have you considered submitting it to the official repo?
Yes I have but as far as I know it's not okay to include binaries in an add-on for the official repo.
Unless you're willing to accept that ;-)
That's indeed right and still the case afaik.
But does the addon still depend on a closed source binary?
Quote:The add-on had a major refactor and is now no longer relying on libspotify.
Instead it will now utilize a slightly modified version of librespot (open source spotify sdk) with a big thanks to @plietar for creating this custom spotify SDK.
Also, it's no longer needed to have a webbrowser installed on the pi.
Made me think that it's not depending on closed sources anymore.
(2017-09-21, 20:15)marcelveldt Wrote: [ -> ]Indeed, it's completely independent of closed source but I precompile the (opensource) librespot/spotty for each platform as a binary.
Don't know if thats acceptable ?
(2017-09-21, 13:07)moppi1988 Wrote: [ -> ](2017-08-20, 10:33)moppi1988 Wrote: [ -> ](2017-08-15, 07:55)moppi1988 Wrote: [ -> ]I've been using Spotify addon for a long time and I like it.
Now I use version 1.1.42 under Win10 on Kodi 17.3.
But since a while (several months) I see the following behavior:
When I awake my PC from suspend mode a system window pops up saying:
"spotty_64.exe funktioniert nicht mehr (doesn't work anymore)."
I have to close this window manually then everything works fine again. But I cannot close this window by
normal Kodi remote. I have to plugin a mouse which is annoying.
I have no idea where this message is coming from. There is no entry in Kodi logfile. Looks like
a Spotify own system message.
Does anyone else have this problem?
(2017-09-03, 21:22)marcelveldt Wrote: [ -> ](2017-08-20, 10:33)moppi1988 Wrote: [ -> ]Meanwhile this issue appears more often and not only during wakeup but within playing music. Yesterday this error window popped up every 10 minutes. Once Kodi crashed completely.
I have the feeling this is related to weak internet connection. Could that be?
I will post an updated version of the add-on on my repo later today. Please test if that fixes the issue as it has an updated version of the Spotty/Librespot binary included.
Unfortunately the story gets much worse now. After the latest Win10 update some days ago the error message pops up continuously, i.e. every about 10 seconds. It blocks not only the usage of the addon but blocks usage of whole Kodi now. The only way to get rid of the messages (which are system level messages, not coming from Kodi) is to deinstall the Spotify addon.
I removed the addon completely and reinstalled it. But same behavior again. I run a log with debug, but there are no Spotify related errors or warnings in it.
I have not clue why only me have this issue. This is probably related to a Win10 run time library version or so.
Can you help, please? It would be too bad to deinstall the addon permanently as only possible solution.
Thanks a lot!
(2017-09-21, 20:01)marcelveldt Wrote: [ -> ](2017-09-21, 11:30)Mowa Wrote: [ -> ]Dear Marcel,
(2017-08-15, 12:03)Saul in Oz Wrote: [ -> ]Hi Marcel
Thank you for your work on this. It gets a very great deal of use in our house!
The new version is working perfectly on a Libreelec Intel NUC but is causing significant problems on a Windows 7 platform (I3 NUC). Crashes at between 2:00 and 2:55 in any given song. Interestingly, on the same system, the previous implementation did not like anything over 7 minutes but that was a much rarer song and I do not have a log.
Hope this pastebin thing works...
https://pastebin.com/uWhY8E1i
(2017-09-22, 10:00)moppi1988 Wrote: [ -> ]For me i notice when there is no internet connection than i get this message every 10 sec. or so. I get also this message once after wake up. I think it comes from last wake up in the night and there was no internet connection.(2017-09-21, 13:07)moppi1988 Wrote: [ -> ](2017-08-20, 10:33)moppi1988 Wrote: [ -> ]For me i notice when i have no internet connection then i get this message every 10 sec. When i wake up my PC on next day i get this message once (maybe from one wake up in the night) then never so long i have a internet connection.
So it must have something to to with that.
(2017-09-03, 21:22)marcelveldt Wrote: [ -> ]I will post an updated version of the add-on on my repo later today. Please test if that fixes the issue as it has an updated version of the Spotty/Librespot binary included.
Thanks a lot!
Now version 1.1.44 is available. I immediately installed it and the permanent error messages about spotty_64.exe are gone!!!!
This is great news. But unfortunately now I'm back to the initial state: When I send the PC to sleep (suspend mode) and wake it up, the
error message comes back. But only once.
Any idea to get rid of this error message? Is it a time-out related issue within spotty_64.exe?
(2017-09-24, 10:46)tehax Wrote: [ -> ](2017-09-22, 10:00)moppi1988 Wrote: [ -> ]For me i notice when there is no internet connection than i get this message every 10 sec. or so. I get also this message once after wake up. I think it comes from last wake up in the night and there was no internet connection.(2017-09-21, 13:07)moppi1988 Wrote: [ -> ]For me i notice when i have no internet connection then i get this message every 10 sec. When i wake up my PC on next day i get this message once (maybe from one wake up in the night) then never so long i have a internet connection.
Thanks a lot!
So i think it must have something to do with internet connection.
(2017-09-03, 21:16)marcelveldt Wrote: [ -> ]Try this:
Code:http://login:[email protected]:8080/jsonrpc?request={"jsonrpc":"2.0","method":"Player.Open","params":{"item":{"file":"plugin://plugin.audio.spotify/?action=connect_playback&playlistid=SPOTIFYPLAYLISTID&ownerid=SPOTIFYOWNERID&offset=0"}},"id":"1"}
That way you should be able to start the playback of a playlist. You should be able to grab the playlistID and the ownerID from the spotify URI
{"error":{"code":-32700,"message":"Parse error."},"id":null,"jsonrpc":"2.0"}
14:41:37.930 T:140443292550912 DEBUG: CWebServer[8080]: request received for /jsonrpc?request={%22jsonrpc%22:%222.0%22,%22method%22:%22Player.Open%22,%22params%22:{%22item%22:{%22file%22:%22plugin://plugin.audio.spotify/?action=connect_playback&playlistid=4MnlMWuJ3fA2eJIgRBM0fU&ownerid=22gbe72j2xnlfzlxnzgoo72xi&offset=0%22}},%22id%22:%221%22}
14:41:37.930 T:140443292550912 ERROR: JSONRPC: Failed to parse '{"jsonrpc":"2.0","method":"Player.Open","params":{"item":{"file":"plugin://plugin.audio.spotify/?action=connect_playback'
(2017-09-22, 02:27)jurialmunkey Wrote: [ -> ](2017-09-21, 20:15)marcelveldt Wrote: [ -> ]Indeed, it's completely independent of closed source but I precompile the (opensource) librespot/spotty for each platform as a binary.
iirc, visualisations and pvr addons are binaries. The source has to be open, and I think the binary has to be built by the kodi cmake system rather than yourself. But afaik binaries are perfectly acceptable. I remember a few years ago there was a move to make standalone binary addons a thing explicitly for these types of scenarios.
EDIT: There is a specific repo for binary addons. See here:
https://github.com/xbmc/repo-binary-addons
