Hi everyone.
I'm total newbe here.
Just reporting the fact that the addon seems to not working on Kodi Krypton.
- Hardware : Raspberry pi 3 b
- OS : libreelec
- Kodi version : Krypton 17.3
- Addon version : latest available
The addon keep asking me my credentials, again and again and again. I've checked them, they works fine.
I've no clues of what i'm doing wrong.
(2017-07-28, 13:35)SgtBigSmoke Wrote: [ -> ]I'm getting this error in the log:
22:06:43.909 T:140645433444096 WARNING: plugin.audio.spotify --> Exception in plugin_content ! --> global name 'label' is not defined
Same issue here, also on a Pi 3
This issue will be fixed later today when I post an updated version on the repo. Sorry, it was a typo in the code.
(2017-07-28, 14:20)Scavendoa2 Wrote: [ -> ]Just reporting the fact that the addon seems to not working on Kodi Krypton.
- OS : libreelec
Lot's of users running the add-on on Krypton with pi3 so seems to be specific to your system.
Would it be possible for you to send me your Kodi logfile after you got this login issue ?
Sure, how i can get/find it ?
1.1.40 seems to have fixed the 2:40 problem that several of us encountered on LibreElec 8.0.2 on RPx. Good work!
Edit: Spoke too soon. On any song over 9:00 minutes, the audio cuts out between 8:45 and 8:55, and remains muted till end of song. The play clock continues to end of song, and the audio returns on the next song. Does not appear to create an error. Occurs consistently on LibreElec 8.0.2 X86 and RP3. Pink Floyd Echoes is a good test case!
Edit2: Upgraded my LibreElec X86 box to the latest Milhouse 18.0 nightly, and encountered the same problem.
(2017-07-28, 22:39)mazeeff Wrote: [ -> ]1.1.40 seems to have fixed the 2:40 problem that several of us encountered on LibreElec 8.0.2 on RPx. Good work!
Can you give 1.1.42 a try if that fixes the issue ?
@marcelveldt -- With 1.1.40 the Artist/Playlist issue is fixed, but I'm now getting a lot of the "Cannot allocate memory" errors where the rest of the album will be quickly skipped through.
Log:
https://pastebin.com/QRqaaEDu
(Also I can't see 1.1.42 in the repo -- latest I can see is 1.1.40)
(2017-07-30, 08:11)jurialmunkey Wrote: [ -> ]@marcelveldt -- With 1.1.40 the Artist/Playlist issue is fixed, but I'm now getting a lot of the "Cannot allocate memory" errors where the rest of the album will be quickly skipped through.
Log: https://pastebin.com/QRqaaEDu
Can you create that log again with debug logging enabled please ?
Looks like you're running low on memory somehow but the error could also be misleading.
1.1.41 should be available on the repo. .42 was a typo
(2017-07-30, 08:22)marcelveldt Wrote: [ -> ] (2017-07-30, 08:11)jurialmunkey Wrote: [ -> ]@marcelveldt -- With 1.1.40 the Artist/Playlist issue is fixed, but I'm now getting a lot of the "Cannot allocate memory" errors where the rest of the album will be quickly skipped through.
It is only happening intermittently, so of course now that I've turned on debug logging it's not doing it! It happened 3 or 4 times earlier today, so I'll keep debug logging on for the next few hours and see if I can catch it.
I'm using kodi 17.3 on my dm900 box with flash image openatv 6.1. When i'm exit from player its turning blank screen, no menu can see..so i've to reboot my box
Sent from my A1601
Theres also only the 40 for me, not 41.
indeed I can't find version 41 in the repo. But maybe Marcel is having some well deserved holidays now..
