@marcelveldt
Would it be possible to adjust web browser authentification for xBian Web Viewer (linear web browser) please? <https://superrepo.org/kodi/addon/script.web.viewer/>
I was really astonished when I found out that SpotiLib will be supported again and I found your app when it was here for 1 or 2 days :). Since then I am impatient to try it. But there are some essential things running on my PI that are configured for xbian so it impossible to swap OS for me to have proper web browser there.
I would also like to test it upside down as tester is my profession :).
Do a install on your computer and then a install in rpi , copy user files from pc to rpi , reboot - done!
I have spotify running on my rpi with Openelec
Nice workaround, thanks for the advice, hopefully i will get time to try it tonight
Works, thanks Jonke. Just had to copy the file from addon-data instead of addons
marcelveldt: small request, can you update changelog in the add-on itself when you release new versions?
newphreak
How die you manage that the addon work with libreelec ?
Which web Browser did you use ?
Chromium, but it's not officially updated/fixed yet.
What system are you using Libreelec on?
(2016-04-09, 14:12)newphreak Wrote: [ -> ]Chromium, but it's not officially updated/fixed yet.
I get this error on Mac OSX:
Login error: ascii codec can't decode byte 0xf0 in position 1: ordinal not in range(128)
Somebody know what's happened?
(2016-04-11, 15:51)brahyam Wrote: [ -> ]I get this error on Mac OSX:
Hmmm, that's strange I should have made sure the app is unicode compliant.
Can you post the full error log snippet here please ?
I had that issue before on osx but not on latest ver . Have you updated the addon ?
(2016-04-11, 18:35)Jönke Wrote: [ -> ]I had that issue before on osx but not on latest ver . Have you updated the addon ?
Yes, I also tried with a previous version and get the same error
(2016-04-11, 16:51)marcelveldt Wrote: [ -> ]Hmmm, that's strange I should have made sure the app is unicode compliant.
Here is my log:
08:40:34 T:123145309356032 NOTICE: Thread PeripBusCEC start, auto delete: false
08:40:34 T:140735193767936 NOTICE: Running database version Addons19
08:40:34 T:140735193767936 NOTICE: Running database version ViewModes6
08:40:34 T:140735193767936 NOTICE: Running database version Textures13
08:40:34 T:140735193767936 NOTICE: Running database version MyMusic52
08:40:34 T:140735193767936 NOTICE: Running database version MyVideos93
08:40:34 T:140735193767936 NOTICE: Running database version TV29
08:40:34 T:140735193767936 NOTICE: Running database version Epg10
08:40:34 T:140735193767936 NOTICE: start dvd mediatype detection
08:40:34 T:123145309433856 NOTICE: Thread DetectDVDMedia start, auto delete: false
08:40:34 T:140735193767936 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
08:40:34 T:140735193767936 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
08:40:34 T:140735193767936 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
08:40:34 T:140735193767936 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
08:40:34 T:123145309970432 NOTICE: Thread LanguageInvoker start, auto delete: false
08:40:34 T:140735193767936 NOTICE: initialize done
08:40:34 T:140735193767936 NOTICE: Running the application...
08:40:34 T:123145309970432 NOTICE: -->Python Interpreter Initialized<--
08:40:34 T:123145310507008 NOTICE: Thread JobWorker start, auto delete: true
08:40:34 T:140735193767936 NOTICE: starting zeroconf publishing
08:40:34 T:140735193767936 NOTICE: starting upnp client
08:40:34 T:123145311043584 NOTICE: Thread JobWorker start, auto delete: true
08:40:34 T:140735193767936 NOTICE: ES: Starting event server
08:40:34 T:123145314263040 NOTICE: Thread EventServer start, auto delete: false
08:40:34 T:123145314263040 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
08:40:34 T:123145314799616 NOTICE: Thread TCPServer start, auto delete: false
08:40:34 T:123145314263040 NOTICE: UDP: Listening on port 9777
08:40:34 T:123145315336192 NOTICE: Thread JobWorker start, auto delete: true
08:40:34 T:123145315950592 NOTICE: Thread RSSReader start, auto delete: false
08:40:40 T:123145302839296 NOTICE: Thread BackgroundLoader start, auto delete: false
08:40:42 T:123145302839296 NOTICE: Previous line repeats 1 times.
08:40:42 T:123145302839296 NOTICE: Thread LanguageInvoker start, auto delete: false
08:40:42 T:123145302839296 NOTICE: -->Python Interpreter Initialized<--
08:40:43 T:123145306673152 NOTICE: Thread LanguageInvoker start, auto delete: false
08:40:43 T:123145306673152 NOTICE: -->Python Interpreter Initialized<--
08:40:43 T:123145306673152 NOTICE: Spotify --> Your platform (x86_64 System.Platform.OSX)
08:40:43 T:123145306673152 NOTICE: Spotify --> Starting background service...
08:40:43 T:123145306673152 NOTICE: Spotify --> Cached session found
08:40:43 T:123145318019072 NOTICE: Spotify --> logged in: 0
08:40:48 T:123145306673152 NOTICE: Spotify --> starting proxy at port 8080
08:40:48 T:123145306673152 NOTICE: Spotify --> ERROR in backgroundservice! 'ascii' codec can't decode byte 0xf0 in position 1: ordinal not in range(128)
08:40:48 T:123145306673152 NOTICE: Spotify --> Background service stopped
08:40:48 T:123145318019072 ERROR: Exception in thread Thread-1:
File "/Users/Shared/jenkins/workspace/OSX-64/tools/depends/xbmc-depends/macosx10.10_x86_64-target/lib/python2.6/threading.py", line 532, in __bootstrap_inner
File "/Users/Roldan/Library/Application Support/Kodi/addons/plugin.audio.spotify/resources/playbackservice.py", line 102, in run
self.__mainloop.loop(self.__session)
File "/Users/Roldan/Library/Application Support/Kodi/addons/plugin.audio.spotify/resources/libs/spotify/__init__.py", line 166, in loop
timeout = session.process_events()
ReferenceError: weakly-referenced object no longer exists
08:41:43 T:123145308282880 WARNING: DARWINOSX: underflow (0 vs 4096 bytes)
09:24:14 T:123145305063424 NOTICE: Thread BackgroundLoader start, auto delete: false
13:51:27 T:123145303453696 NOTICE: Thread Timer start, auto delete: false
Yes , right cant use username with åäö with Spotify addon on osx.
