2017-01-04, 14:43
Hi I dont know if someone has previously asked but I dont seem to see the media cases in dvd or bluray cases mine are all divx or h265 etc
is there a way to change this
(2017-01-04, 02:46)emiralles Wrote: [ -> ](2017-01-04, 00:13)Slayer1982 Wrote: [ -> ]Hi,
Is there a fix for the following issue
Thanx
test it this, download and put in 1080i folder.
https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
(2017-01-04, 15:04)Slayer1982 Wrote: [ -> ]Thanks, this solved the issue
Thanx
(2017-01-06, 05:23)Ruk12345 Wrote: [ -> ]Quick bug, when pausing a playing video the progress bar (lower left corner) that shows time into epsoide/movie and time remaining is empty.
Thanks bro
(2017-01-06, 09:25)emiralles Wrote: [ -> ](2017-01-06, 05:23)Ruk12345 Wrote: [ -> ]Quick bug, when pausing a playing video the progress bar (lower left corner) that shows time into epsoide/movie and time remaining is empty.
Thanks bro
Are you sure?
check your system.
(2017-01-07, 01:09)emiralles Wrote: [ -> ]Are you sure that this is my mod?
(2017-01-07, 01:11)Ruk12345 Wrote: [ -> ]I added the multi mod to it, bust aside from that it's your AWESOME Skin mod (latest version too)
(2017-01-07, 18:22)jasn Wrote: [ -> ]Am I the only one that cannot assign ratings to playing songs using Pg Up or Pg Down? It works in Estuary.
(2017-01-08, 14:49)Dave.B Wrote: [ -> ]emiralles I really love the new ver 1.4.0.5 and looking forward for more updates.
still few things that i would appreciate if you can fix.
1. Record label icon still don't show when playing songs from m3u playlist.
2. Video lyrics doesn't seem to work well, the font are really small and colored black. Sometimes not all the letters appear.
3. Any chance to add this feature to music mod ? https://www.youtube.com/watch?v=V70kgvzY...tion=share
thank you again for all your work.
Dave
(2017-01-08, 20:12)emiralles Wrote: [ -> ](2017-01-08, 14:49)Dave.B Wrote: [ -> ]emiralles I really love the new ver 1.4.0.5 and looking forward for more updates.
Dave
Hi Dave B and thanks for your words, but
1.- Record label icon depend from your music database, sometimes you have it with out problems in other no.
2.- I don't change any in the lyrics and yes sometimes it's dificult read it
3.- latts9923 it's working in it.
thanks
