There is a guide here to create Custom Home Items...
https://kodi.wiki/view/Custom_Home_Items
It is based on the Aeon Nox skin though. The procedure is the same, just need to find the appropriate screens in Aeon MQ
Use customize main menu option item in settings submenu, but first create smart playlists. When enter in customize main menu, you have replace option, and in right side select option Choose SmartPlaylist, now select one, rename and done, after incluse you have widget available selector too.
Been playing around with this skin and have to say its quite impressive. however if i wanted to add the addon auto completion to the keyboard how difficult would it be to include that ?
Thank you very much. It works fine. But I have one ohter question.
Since I have this skin, I have no more DTS sound. Does anyone have an idea?
I have a much bigger problem. The skin has completely reset for the second time. How can I prevent this?
Hello,
I'm new to the forum and still new to Kodi. I have this mod installed, I'm having an issue with the TV menu when I open up the TV menu I have blank screen have to click 3 dots then files the TV shows to access the TV show.library
Any ideas
How'd you get the epg to work
I have some home movies and I have SET content type to "Movies"
For the Information Provider ...I have set "Local information only"
I then set the Viewtype to "Fanart"
I have my own personal images (.jpg) for my home movies...so how do I get to see these images as Fanart? (when I scroll through my movies)
Appreciate any help.
Edit:
Solved it after a lot of reading.
I had to rename my images same as movie with "fanart" added eg: movie1.mp4 movie1-fanart.jpg
Hello,
I'm having a problem getting Movie Set/Collection information to display, using LibreElec with Kodi 17.6 and Aeon MQ7 2.0.7.6. This is a fresh install.
When I navigate to a movie set, no information (number of movies, years, genre, etc.) displays and no multiple discart. The Media Case shows "three discs" to indicate a movie set, but that's it. This is the same in every view.
When looking at individual movies (inside or outside a set) everything appears fine except that Director and Writer information isn't shown (in the views that attempt to).
I've tried many solutions to problems that seem similar to mine, but nothing has worked, hence the fresh install.
Thank you for any help anyone can provide.
Hello
i am testing this skin
Pretty satisfied except the bad display of logo Channel Live TV icons. They are displayed without keeping aspect ratio therefore they appears "deformed".
Is there a workaround?
Thx
Hello, after a clean wipe of Kodi and a re-install and setting things up with this skin I like. I am getting a error now with scanning files the error shows at the top, Artworkdownloader 0 and makes a beep sound.
https://paste.ubuntu.com/p/XGkCwxsQTZ/
I don't believe Artwork Downloader works anymore. I use Artwork Beef now and have been happy with it.
(2018-06-04, 16:56)cwebster Wrote: [ -> ]I don't believe Artwork Downloader works anymore. I use Artwork Beef now and have been happy with it.
I use Arwork Beef too but it is annoying to get the error every time I scan. Artwork Downloader can not be uninstalled or disabled.
i just installed Chrome Launcher Addon i created a menu shortcut for it, i need to edit the following path but i can't find it, can somebody help me with this please and tell me how can i edit that path
(2018-06-04, 18:34)Ices Wrote: [ -> ] (2018-06-04, 16:56)cwebster Wrote: [ -> ]I don't believe Artwork Downloader works anymore. I use Artwork Beef now and have been happy with it.
Artwork Downloader can (sort of) be disabled. Configure it to do nothing and it should do nothing.
Does artwork beef have context menu items like “GUI mode”. If so how do you enable them in this skin thank you
