2017-02-26, 20:45
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56
2017-02-26, 22:04
Got a aggrevating problem with kodi....how do I put pics in the post box...perhaps someone can help me ??
Scott
Scott
2017-02-27, 00:22
(2017-02-26, 20:36)johnjohnny77 Wrote: [ -> ](2017-02-26, 11:56)emiralles Wrote: [ -> ]I feel happy with layout 4, I don't need. more.
ok, no problem... thanks anyway.
I will use your music layout 5 (it's the most suitable for my needs).
May you help me with a couple of things I don't understand?
Sometimes I can display fanart and logo, but no cd art:
Sometimes I can display cd art and logo, but no fanart:
Sometimes I can display cd art, but no logo and no fanart:
Sometimes I can't display anything...
a) Is it normal or there's something wrong with my settings? Can you explain me what I should do?
b) Is it possible to display a disc if cd art doesn't exist? As you can see, in the first screenshot there is no disc.
c) Is it possible to display a fanart set by me if the artist's fanart doesn't exist? If it is, how?
Thank you very much!
jj77: In Layout 5 you will only see cd art animation when there is actual cd art associated with that cd. It will not display the default cd art by coded-design. I know this because a few months ago I provided the Layout to emiralles for inclusion in the musicvisualization.xml file. I did this on purpose because the default, gray cd art was causing burn-in on my plasma TV.
Layout 5 is a tweaked, slightly-amped version of Layout 2, which I wanted the graphics to be a bit lower, more symmetrical and include the info you too want to know when playing a track. It's had a couple of minor tweaks since by the team.
2017-02-27, 00:53
I've got exactly the same problem John....sometimes it displays the banner...sometimes it doesn't......sometimes it displays the fanart...sometimes it doesn't..................cant seem to work out why !
I have all the banners, cd arts etc......some work, some dont
Very puzzling
Scott
Very puzzling
Scott
2017-02-27, 18:01
(2017-02-27, 00:53)scottywhu Wrote: [ -> ]I've got exactly the same problem John....sometimes it displays the banner...sometimes it doesn't......sometimes it displays the fanart...sometimes it doesn't..................cant seem to work out why !
Very puzzling
Scott
Are you have installed artwork downloader addon? this is the first, and many films don't have banners or logos, I can't do miracles, I try but .... nothing..
2017-02-27, 19:23
(2017-02-26, 20:45)Ruk12345 Wrote: [ -> ]Can I extract the update zip on just overwrite files? Or is it better to install from zip?
Up to you!!! it's the same in the second time, the first time you need install from zip always.
2017-02-27, 19:24
(2017-02-26, 13:08)chrisk2305 Wrote: [ -> ]does this version also work with Leia?
I don't know,
you can try, install from zip.
https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
Please, tell us your experiences!!!
2017-02-27, 19:26
(2017-02-26, 17:00)scottywhu Wrote: [ -> ]Hi Emiralles ,
Firstly, thanks for the skin....I love it...very smooth and modern looking !
I've read through all the posts- I have the pause screen issue....doesn't display banner/poster or disk....now I see that you have told people to put your fix in the 1080i folder, but I cant find that folder !!
I'm using Android Nvidia Shield....is that why ?
Thanks for any help you can provide
Scottywhu
I think that
Android/data/org.xbmc.kodi/files/.kodi/addon/skin.aeonmq7.krypton.mod/1080i
2017-02-27, 19:42
(2017-02-26, 11:52)emiralles Wrote: [ -> ](2017-02-26, 01:14)nomnom27 Wrote: [ -> ]I have a follow up question. Why do some record labels show up in some albums and in others don't?
By the way record label for As I lay dying album is Pluto Records and it's in the Textures.xbt but it won't appear.
It's the same http://forum.kodi.tv/showthread.php?tid=...pid2534573
Yes you are right. Sorry. I figured it out. Thank for the help
2017-02-27, 19:50
2017-02-27, 20:04
Hi Emiralles,
Yes I've got the artwork downloaded add on......I've got all the files, just for some reason it won't display them.......for example : Bruno mars plays with fanart,banner etc.......yet Marian Carey (with same file set as Bruno mars) won't display......I'm not doing anything different, can't work it out !!
Its only when I play music, all films display correct information.
Also, the skin is fantastic, this is a very minor problem which Is more frustrating than anything.
Really appreciate the work you have put in.
Scottywhu
Scottywhu
2017-02-27, 20:28
(2017-02-27, 19:24)emiralles Wrote: [ -> ](2017-02-26, 13:08)chrisk2305 Wrote: [ -> ]does this version also work with Leia?
I don't know,
Its install by editing addon.xml xbmc.gui ver.
It mainly works fine except access to any addons skin links -my addons,install
from zip etc (addons themself work fine)
2017-02-27, 20:53
Regarding johnjohnny77's requests to modify Layout 5, since I was the orginal author I have re-tweeked the code FOR LAYOUT 5 ONLY to address his thoughts:
1. Scroll Artist;
2. Scroll Track title
3. Show default cd art in the absence of actual cdart; and
4. Change the language of the Next song info.
Here is the code for a revised musicvisualization.xml file that can be found in the skins 1080i folder:
You can create a new musicvisualization.xml file using this code, create and replace the original file (change the name to ORIGINALmusicvisualization.xml).
emiralles, if you agree with these changes you could incorporate them into a future version, otherwise they will be lost to future upgrades. PM me if you'd like.
Fanart issues should not be related to any of these tweaks. It may instead be that no fanart exists for the particular artist or you do not have the settng correct to seek fanart online.
1. Scroll Artist;
<?xml version="1.0" encoding="UTF-8"?>
<window>
<!-- Aeon MQ 7 -->
<onload condition="System.HasAddon(script.artistslideshow)">RunScript(script.artistslideshow)</onload>
<onload condition="Skin.HasSetting(nolyrics_on) + ![String.IsEmpty(MusicPlayer.offset(1).Artist) | Skin.HasSetting(novisfurniture) | Skin.HasSetting(nonexttracks_on)]">ActivateWindow(5600)</onload>
<onunload>Dialog.Close(5600)</onunload>
<controls>
<control type="image">
<left>0</left>
<top>0</top>
<width>1920</width>
<height>1080</height>
<texture>special://skin/backgrounds/extras/default.jpg</texture>
</control>
<control type="visualisation" id="2">
<left>0</left>
<top>0</top>
<width>1920</width>
<animation effect="fade" start="0" end="100" time="400">Visible</animation>
<animation effect="fade" start="100" end="0" time="200">Hidden</animation>
<visible>Skin.String(vis_bg,fanartmix) | Skin.String(vis_bg,slideshowmix) | Skin.String(vis_bg,slideshowmosaicmix) | Skin.String(vis_bg,vis)</visible>
</control>
<!-- Fanart -->
<include>WindowBG</include>
<texture background="true">$INFO[MusicPlayer.Property(fanart_image)]</texture>
<animation effect="fade" start="100" end="50" time="400" condition="Skin.String(vis_bg,fanartmix)">Conditional</animation>
<visible>[Skin.String(vis_bg,fanart) | Skin.String(vis_bg,fanartmix)] + String.IsEmpty(Control.GetLabel(5043)) + String.IsEmpty(Control.GetLabel(5044)) | [Skin.String(vis_bg,slideshow) | Skin.String(vis_bg,slideshowmix)] + String.IsEmpty(Control.GetLabel(5045)) | [Skin.String(vis_bg,slideshowmosaic) | Skin.String(vis_bg,slideshowmosaicmix)] + String.IsEmpty(Control.GetLabel(5046)) + String.IsEmpty(Control.GetLabel(5047)) + String.IsEmpty(Control.GetLabel(5048)) + String.IsEmpty(Control.GetLabel(5049)) + String.IsEmpty(Control.GetLabel(5050)) + String.IsEmpty(Control.GetLabel(5051))</visible>
</control>
<!-- Extra Fanart Song -->
<control type="multiimage" id="5043">
<imagepath background="true">$INFO[Player.FolderPath,,../extrafanart/]</imagepath>
<visible>[Skin.String(vis_bg,fanart) | Skin.String(vis_bg,fanartmix)] + String.Contains(skin.string(musicfanart),extra)</visible>
</control>
<!-- Extra Fanart Artist -->
<control type="multiimage" id="5044">
<imagepath background="true">$INFO[Skin.String(CustomMusicLogoPath)]$INFO[MusicPlayer.Artist,,/extrafanart/]</imagepath>
<visible>[Skin.String(vis_bg,fanart) | Skin.String(vis_bg,fanartmix)] + String.Contains(skin.string(musicfanart),extra) + String.IsEmpty(Control.GetLabel(5043))</visible>
</control>
<!-- Artist SlideShow -->
<control type="multiimage" id="5045">
<aspectratio>keep</aspectratio>
<imagepath background="true">$INFO[Window(Visualisation).Property(ArtistSlideshow)]</imagepath>
<animation effect="zoom" start="0" end="100" center="auto" easing="out" tween="sine" time="700" delay="1000">WindowOpen</animation>
<animation effect="zoom" start="0" end="100" center="auto" easing="out" tween="sine" time="700" delay="1000">Visible</animation>
<animation effect="zoom" start="100" end="0" center="auto" easing="in" tween="sine" time="300">WindowClose</animation>
<animation effect="zoom" start="100" end="0" center="auto" easing="in" tween="sine" time="300">Hidden</animation>
<animation effect="fade" start="100" end="50" time="400" condition="Skin.String(vis_bg,slideshowmix)">Conditional</animation>
<visible>Skin.String(vis_bg,slideshow) | Skin.String(vis_bg,slideshowmix)</visible>
</control>
<!-- Artist SlideShow Mosaico -->
<control type="multiimage" id="5046">
<include>MosaicBG</include>
<left>0</left>
<top>0</top>
<visible>Skin.String(vis_bg,slideshowmosaic) | Skin.String(vis_bg,slideshowmosaicmix)</visible>
</control>
<control type="multiimage" id="5047">
<left>640</left>
<top>0</top>
</control>
<control type="multiimage" id="5048">
<left>1280</left>
<top>0</top>
</control>
<control type="multiimage" id="5049">
<left>0</left>
<top>540</top>
</control>
<control type="multiimage" id="5050">
<left>640</left>
<top>540</top>
</control>
<control type="multiimage" id="5051">
<left>1280</left>
<top>540</top>
</control>
<!-- Pasta pessoal -->
<control type="multiimage">
<imagepath fallback="special://skin/backgrounds/music.jpg" background="true">$INFO[skin.string(musicviz.bg)]</imagepath>
<visible>Skin.String(vis_bg,custom)</visible>
</control>
<imagepath fallback="special://skin/backgrounds/music.jpg" background="true">$INFO[Window(Home).Property(SkinHelper.Player.Art.ExtraFanArt)]</imagepath>
<visible>Skin.String(vis_bg,skinhelp)</visible>
</control>
<!-- poner la hora en la parte derecha arriba -->
<control type="label">
<left>1390</left>
<top>3</top>
<width>500</width>
<height>34</height>
<align>right</align>
<aligny>top</aligny>
<font>Font_time_big</font>
<textcolor>FFFFFAF0</textcolor>
<label>[B]$INFO[System.Time][/B]</label>
<scroll>true</scroll>
<scrollout>false</scrollout>
<shadowcolor>grey</shadowcolor>
<animation type="Conditional" condition="Skin.HasSetting(Similar_Artist_JohnyBee) + !Skin.HasSetting(Original_slide_JohnyBee)" loop="true">
<effect type="slide" start="0,0" end="-320,0" time="1900" tween="cubic" delay="20500"/>
<!-- delay - czas do pokazania panela (musi byc powiększony o czas ukrycia i zwłoki) end="0,430" -->
<effect type="slide" start="0,0" end="320,0" time="1900" tween="cubic" delay="50300"/>
<!-- delay - czas do ukrycia panela (musi byc powiększony o czas zjazdu i zwłoki) end="0,-430" -->
</animation>
<animation type="Conditional" condition="Skin.HasSetting(Similar_Artist_JohnyBee) + Skin.HasSetting(Original_slide_JohnyBee)">
<effect type="slide" start="0,0" end="-320,0" time="1900" tween="cubic" delay="10500"/>
</animation>
</control>
<!-- layout estilo 1 -->
<control type="group">
<left>0</left>
<top>1160</top>
<animation effect="slide" start="0,0" end="-600,0" time="400" tween="cubic" easing="inout" condition="String.IsEmpty(Window(Visualisation).Property(ArtistSlideshow))">Conditional</animation>
<animation effect="slide" start="0,0" end="0,-200" time="400" tween="cubic" easing="inout" condition="Window.IsVisible(120)">Conditional</animation>
<animation effect="slide" start="0,0" end="0,450" time="700" tween="cubic" easing="out" condition="Skin.HasSetting(novisfurniture)">Conditional</animation>
<animation effect="slide" start="0,0" end="-1350,0" time="400" tween="cubic" easing="inout" condition="Skin.HasSetting(furniture_cdart)">Conditional</animation>
<animation effect="slide" start="0,1080" end="0,-450" time="700" tween="cubic" easing="out" delay="400">WindowOpen</animation>
<animation effect="slide" start="0,-450" end="0,0" time="400" tween="cubic" easing="in" delay="400">WindowClose</animation>
<visible>Skin.String(vis_layout,style1)</visible>
<left>0</left>
<top>-123</top>
<height>555</height>
<width>2520</width>
<texture>details_back.png</texture>
<colordiffuse>$INFO[Skin.String(colortexture)]</colordiffuse>
</control>
<left>1230</left>
<visible>Player.HasAudio</visible>
<animation effect="slide" start="0,0" end="210,0" time="800" delay="3000" tween="sine" easing="inout" condition="Player.HasAudio">Conditional</animation>
<animation effect="slide" end="-210,0" time="800" tween="sine" easing="inout" condition="Skin.HasSetting(noviscdart)">Conditional</animation>
<animation effect="fade" start="100" end="0,0" time="300" delay="500" condition="Skin.HasSetting(noviscdart)">Conditional</animation>
<include>Animation_CDart</include>
<left>60</left>
<top>-30</top>
<width>366</width>
<height>366</height>
<texture diffuse="cdart_diffuse.png" background="true">$VAR[value_audiodisc]</texture>
<aspectratio align="center" aligny="center">keep</aspectratio>
</control>
<left>60</left>
<top>-30</top>
<width>366</width>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Player.FolderPath]cdart.png</texture>
</control>
</control>
<!-- reflexo -->
<left>1335</left>
<top>340</top>
<width>525</width>
<fadetime>200</fadetime>
<texture flipy="true" fallback="DefaultAudio.png" diffuse="thumb_reflect.png" background="true">$INFO[MusicPlayer.Cover]</texture>
<aspectratio align="left" aligny="top">keep</aspectratio>
</control>
<left>1335</left>
<top>-30</top>
<width>525</width>
<texture fallback="DefaultAudio.png" diffuse="thumb_cdcover_mask_cdart.png" background="true">$INFO[MusicPlayer.Cover]</texture>
<aspectratio align="left">keep</aspectratio>
</control>
<left>21</left>
<top>-38</top>
<width>585</width>
<height>405</height>
<texture>musicframe.png</texture>
</control>
<left>44</left>
<top>-8</top>
<width>540</width>
<height>360</height>
<timeperimage>5000</timeperimage>
<randomize>true</randomize>
<imagepath fallback="DefaultExtraThumbs.png" background="true">$VAR[value_playerthumb]</imagepath>
<fadetime>FanartCrossFadeTime</fadetime>
</control>
<left>0</left>
<top>-15</top>
<width>300</width>
<height>90</height>
<texture background="true">$INFO[Skin.String(CustomMusicLogoPath)]$INFO[MusicPlayer.Artist,,/logo.png]</texture>
<fadetime>300</fadetime>
<aspectratio align="center">keep</aspectratio>
<animation effect="fade" end="60" condition="true">Conditional</animation>
</control>
<left>622</left>
<top>-30</top>
<width>690</width>
<height>45</height>
<align>left</align>
<font>Font_titlesettings</font>
<label>$INFO[MusicPlayer.Artist]</label>
</control>
<left>622</left>
<top>26</top>
<width>690</width>
<height>30</height>
<align>left</align>
<font>Font_subtitle</font>
<label>$INFO[MusicPlayer.Album][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.TrackNumber,, : ]$INFO[MusicPlayer.Title][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.Year][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.Genre]</label>
</control>
<left>622</left>
<top>72</top>
<width>690</width>
<height>3</height>
<texture>divider.png</texture>
</control>
<control type="textbox">
<left>622</left>
<top>84</top>
<width>690</width>
<height>198</height>
<font>Font_plot</font>
<label>$VAR[value_playerplot]</label>
<autoscroll delay="20000" time="6000" repeat="20000">!Skin.HasSetting(noallowscroll)</autoscroll>
</control>
<left>622</left>
<top>288</top>
<width>666</width>
<height>3</height>
</control>
<left>622</left>
<top>278</top>
<width>120</width>
<height>98</height>
<aspectratio align="left" aligny="bottom">keep</aspectratio>
<texture>$VAR[value_mediaicons_path]musiccodec/$INFO[MusicPlayer.Codec,,.png]</texture>
</control>
<left>758</left>
<top>294</top>
<width>600</width>
<height>36</height>
<align>left</align>
<font>Font_header</font>
<label>$LOCALIZE[31333] $INFO[MusicPlayer.Channels][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.SampleRate,,KHZ][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitRate,,Kbps][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitsPerSample,,Bits]</label>
</control>
<!-- Barra de cache -->
<control type="progress">
<left>758</left>
<top>328</top>
<width>554</width>
<height>34</height>
<info>Player.ProgressCache</info>
<midtexture>progress_mid0.png</midtexture>
<colordiffuse>$INFO[Skin.String(colorheader)]</colordiffuse>
<animation effect="fade" end="80" condition="true">Conditional</animation>
</control>
<!-- Barra de progresso -->
<left>758</left>
<top>328</top>
<width>554</width>
<height>34</height>
<info>Player.Progress</info>
</control>
<left>975</left>
<top>327</top>
<width>600</width>
<height>36</height>
<align>left</align>
<label>$INFO[MusicPlayer.Time] / $INFO[MusicPlayer.Duration]</label>
</control>
</control>
<!-- layout estilo 2 -->
<left>0</left>
<top>1160</top>
<animation effect="slide" start="0,0" end="0,405" time="400" tween="cubic" easing="inout" condition="Window.IsVisible(120)">Conditional</animation>
<visible>Skin.String(vis_layout,style2)</visible>
<left>0</left>
<top>-123</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>58</left>
<top>-33</top>
<height>330</height>
<texture>details_back_c.png</texture>
<aspectratio align="left">stretch</aspectratio>
</control>
<left>0</left>
<top>-30</top>
<width>450</width>
<height>321</height>
</control>
<left>0</left>
<top>-30</top>
<width>450</width>
</control>
</control>
<!-- reflexo -->
<left>30</left>
<top>262</top>
<width>450</width>
</control>
<left>30</left>
<top>-60</top>
<width>450</width>
</control>
<left>1545</left>
<top>15</top>
<width>330</width>
<height>142</height>
<animation effect="fade" end="100" condition="true">Conditional</animation>
</control>
<!-- Nome do artista -->
<left>518</left>
<top>-15</top>
<width>1290</width>
<height>45</height>
<align>left</align>
<font>Font_titleviews</font>
<scroll>false</scroll>
</control>
<left>495</left>
<top>54</top>
<width>690</width>
<height>3</height>
</control>
<!-- Nome da faixa -->
<left>518</left>
<top>82</top>
<width>1290</width>
<height>30</height>
<align>left</align>
<font>Font_virtualmenu3</font>
<textcolor>50FFFAF0</textcolor>
<label>$INFO[MusicPlayer.Title]</label>
</control>
<!-- Nome do album -->
<left>518</left>
<top>153</top>
<width>1290</width>
<height>30</height>
<align>left</align>
<label>$INFO[MusicPlayer.Album]</label>
</control>
<left>518</left>
<top>192</top>
<width>600</width>
<height>36</height>
<align>left</align>
</control>
<!-- Duracao -->
<left>1215</left>
<top>195</top>
<width>690</width>
<height>30</height>
<font>Font_menu3</font>
</control>
<left>1526</left>
<top>303</top>
<width>375</width>
<height>8</height>
</control>
<left>1526</left>
<top>303</top>
<width>375</width>
<height>8</height>
</control>
<!-- Proxima faixa - proximo artista -->
<left>990</left>
<top>333</top>
<width>915</width>
<height>45</height>
<label>$LOCALIZE[31525]: [COLOR=50FFFAF0]$INFO[MusicPlayer.offset(1).Title] ($INFO[MusicPlayer.offset(1).Artist])[/COLOR]</label>
</control>
</control>
<!-- Layout 3 -->
<left>0</left>
<top>1160</top>
<visible>Skin.String(vis_layout,style3)</visible>
<left>0</left>
<top>-60</top>
<height>750</height>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>50</left>
<top>-80</top>
<width>632</width>
<height>450</height>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
</control>
<left>30</left>
<top>-110</top>
<width>632</width>
</control>
<!-- reflexo -->
<left>30</left>
<top>345</top>
<width>632</width>
</control>
<control type="multiimage" id="5052">
<include>InvisibleButton</include>
<imagepath background="true">$INFO[Skin.String(CustomMusicLogoPath)]$INFO[MusicPlayer.Artist,,/logo.png]</imagepath>
</control>
<!-- logo artista -->
<left>698</left>
<top>-120</top>
<width>1192</width>
<height>150</height>
<aspectratio align="right" aligny="bottom">keep</aspectratio>
<visible>!String.IsEmpty(Skin.String(CustomMusicLogoPath))</visible>
</control>
<left>698</left>
<top>-34</top>
<width>1192</width>
<height>45</height>
<textcolor>CCFFFFFF</textcolor>
<shadowcolor>AA000000</shadowcolor>
<visible>String.IsEmpty(Control.GetLabel(5052))</visible>
</control>
<left>698</left>
<top>75</top>
<width>1192</width>
<height>30</height>
<font>Font_title</font>
<label>[COLOR=$INFO[Skin.String(colorheader)]]$INFO[MusicPlayer.TrackNumber,,. ][/COLOR]$INFO[MusicPlayer.Title]</label>
<textcolor>88DDDDDD</textcolor>
</control>
<left>968</left>
<top>144</top>
<width>922</width>
<height>30</height>
<font>Font_list</font>
<label>$INFO[MusicPlayer.Album] $INFO[MusicPlayer.Year,| ,] $INFO[MusicPlayer.Genre,| ,]</label>
</control>
<left>705</left>
<top>315</top>
<width>300</width>
<height>36</height>
<align>left</align>
<font>Font_button</font>
<label>$INFO[MusicPlayer.SampleRate,, [COLOR=88DDDDDD]KHZ[/COLOR]][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitRate,, [COLOR=88DDDDDD]Kbps[/COLOR]][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitsPerSample,, [COLOR=88DDDDDD]Bits[/COLOR]]</label>
<textcolor>$INFO[Skin.String(colorheader)]</textcolor>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
<animation effect="fade" end="70" condition="true">Conditional</animation>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<!-- Duracao -->
<left>705</left>
<top>255</top>
<width>300</width>
<height>27</height>
<align>left</align>
</control>
<left>1200</left>
<top>201</top>
<width>525</width>
<height>45</height>
<label>$LOCALIZE[31525]:</label>
</control>
<left>1011</left>
<top>240</top>
<width>712</width>
<height>45</height>
<label>[COLOR=$INFO[Skin.String(colorheader)]]$INFO[MusicPlayer.offset(1).TrackNumber,,. ][/COLOR]$INFO[MusicPlayer.offset(1).Title]</label>
</control>
<left>1275</left>
<top>274</top>
<width>450</width>
<height>45</height>
<label>$INFO[MusicPlayer.offset(1).Artist]</label>
</control>
<left>1682</left>
<top>316</top>
<width>45</width>
<height>30</height>
<texture colordiffuse="AA000000">arrow_right.png</texture>
</control>
<left>1680</left>
<top>315</top>
<width>45</width>
<height>30</height>
<texture colordiffuse="AADDDDDD">arrow_right.png</texture>
</control>
<left>705</left>
<top>135</top>
<width>230</width>
<height>98</height>
<texture colordiffuse="88DDDDDD">$VAR[value_mediaicons_path]recordlabel/$INFO[MusicPlayer.Property(Album_Label),,.png]</texture>
<colordiffuse>88DDDDDD</colordiffuse>
</control>
<left>1023</left>
<top>278</top>
<width>135</width>
<height>98</height>
</control>
<left>1160</left>
<top>282</top>
<width>135</width>
<height>98</height>
<align>center</align>
<font>Font_channels</font>
<label>$INFO[MusicPlayer.Channels,,CH]</label>
</control>
<left>1302</left>
<top>310</top>
<width>300</width>
<height>38</height>
<texture fallback="subtitle_rating_0.png">$INFO[MusicPlayer.UserRating]</texture>
</control>
<left>1748</left>
<top>208</top>
<width>135</width>
<height>135</height>
<texture fallback="DefaultAudio.png" background="true">$INFO[MusicPlayer.offset(1).Cover]</texture>
</control>
</control>
<!-- Layout 4 -->
<left>0</left>
<top>1160</top>
<visible>Skin.String(vis_layout,style4)</visible>
<include>VisibleFadeEffect</include>
<left>0</left>
<top>-60</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<include>Animation_CDart1</include>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
<texture diffuse="cdart_diffuse.png" background="true">cd-blank.png</texture>
</control>
<control type="group" id="99990">
<left>50</left>
<top>-80</top>
<width>632</width>
<left>220</left>
<top>40</top>
<width>200</width>
<height>128</height>
<texture background="true">$INFO[Window(Home).Property(SkinHelper.Player.Art.ClearLogo)]</texture>
<aspectratio align="center" aligny="top">keep</aspectratio>
<visible>Skin.HasSetting(Logo_CD)</visible>
</control>
<left>220</left>
<top>40</top>
<width>200</width>
<font>fontCDartist</font>
<textcolor>black</textcolor>
<wrapmultiline>true</wrapmultiline>
<visible>[String.IsEmpty(Control.GetLabel(99991)) + [String.IsEmpty(Window(Home).Property(SkinHelper.Player.Art.ClearLogo)) | !Skin.HasSetting(Logo_CD)]]</visible>
</control>
<left>220</left>
<top>320</top>
<width>200</width>
<font>fontCDalbum</font>
</control>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
<texture diffuse="cdart_diffuse.png" background="true">$INFO[Window(Home).Property(SkinHelper.Player.Art.DiscArt)]</texture>
</control>
</control>
<!-- cover -->
<left>30</left>
<top>-110</top>
<width>632</width>
<!-- <texture fallback="DefaultAudio.png" diffuse="thumb_cdcover_mask_cdart.png" background="true">$INFO[MusicPlayer.Cover]</texture>-->
<texture fallback="DefaultAudio.png" background="true">$INFO[MusicPlayer.Cover]</texture>
</control>
<!--** reflexo ** -->
<left>30</left>
<top>345</top>
<width>632</width>
</control>
<control type="multiimage" id="99991">
<!-- <include>InvisibleButton</include>-->
<left>698</left>
<top>-120</top>
<width>1192</width>
<imagepath background="false">$INFO[Window(Home).Property(SkinHelper.Player.Art.ClearLogos)]</imagepath>
<timeperimage>20000</timeperimage>
</control>
<left>698</left>
<top>-120</top>
<width>1192</width>
<visible>String.IsEmpty(Control.GetLabel(99991))</visible>
</control>
<left>698</left>
<top>-34</top>
<width>1192</width>
<height>45</height>
<visible>[String.IsEmpty(Control.GetLabel(99991)) + String.IsEmpty(Window(Home).Property(SkinHelper.Player.Art.ClearLogo))]</visible>
</control>
<left>698</left>
<top>75</top>
<width>1192</width>
<height>30</height>
</control>
<left>968</left>
<top>144</top>
<width>922</width>
<height>30</height>
</control>
<left>705</left>
<top>315</top>
<width>300</width>
<height>36</height>
<align>left</align>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<!-- Duracao -->
<left>705</left>
<top>255</top>
<width>300</width>
<height>27</height>
<align>left</align>
</control>
<left>1200</left>
<top>201</top>
<width>525</width>
<height>45</height>
</control>
<left>1011</left>
<top>240</top>
<width>712</width>
<height>45</height>
</control>
<left>1275</left>
<top>274</top>
<width>450</width>
<height>45</height>
</control>
<left>1682</left>
<top>316</top>
<width>45</width>
<height>30</height>
</control>
<left>1680</left>
<top>315</top>
<width>45</width>
<height>30</height>
</control>
<left>705</left>
<top>135</top>
<width>230</width>
<height>98</height>
<!-- <texture colordiffuse="88DDDDDD">$VAR[value_mediaicons_path]recordlabel/$INFO[MusicPlayer.Property(Album_Label),,.png]</texture>-->
</control>
<left>1023</left>
<top>278</top>
<width>135</width>
<height>98</height>
<!-- <texture>$VAR[value_mediaicons_path]musiccodec/$INFO[MusicPlayer.Codec,,.png]</texture>-->
<texture>$VAR[value_mediaicons_path]audiocodec/$INFO[MusicPlayer.Codec,,.png]</texture>
</control>
<left>1160</left>
<top>282</top>
<width>135</width>
<height>98</height>
</control>
<left>1302</left>
<top>310</top>
<width>300</width>
<height>38</height>
</control>
<left>1748</left>
<top>208</top>
<width>135</width>
</control>
</control>
<!-- layout estilo 5 -->
<left>0</left>
<top>1160</top>
<animation effect="slide" start="0,0" end="-600,0" time="400" tween="cubic" easing="inout" condition="IsEmpty(Window(Visualisation).Property(ArtistSlideshow))">Conditional</animation>
<visible>StringCompare(skin.string(vis_layout),style5)</visible>
<left>0</left>
<top>0</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>0</left>
<top>30</top>
</control>
<left>0</left>
<top>45</top>
<width>450</width>
</control>
<left>0</left>
<top>45</top>
<width>450</width>
<!-- <texture diffuse="cdart_diffuse.png" background="true">$INFO[Player.FolderPath]cdart.png</texture>-->
</control>
</control>
<!-- reflexo -->
<left>30</left>
<top>262</top>
<width>450</width>
</control>
<left>30</left>
<top>15</top>
<width>450</width>
</control>
<left>1400</left>
<top>-650</top>
<width>430</width>
<height>200</height>
<!-- <texture background="true">$INFO[Skin.String(CustomMusicLogoPath)]$INFO[MusicPlayer.Artist,,/logo.png]</texture>-->
<effect type="slide" start="0,0" end="0,300" time="1900" tween="circle" easing="out" delay="20500"/>
<effect type="slide" start="0,0" end="0,-300" time="1900" tween="circle" easing="in" delay="50300"/>
</animation>
<effect type="slide" start="0,0" end="0,300" time="1900" tween="cubic" easing="out" delay="10500"/>
</animation>
</control>
<left>518</left>
<top>70</top>
<width>1290</width>
<height>45</height>
<align>left</align>
</control>
<left>430</left>
<top>122</top>
<width>690</width>
<height>3</height>
</control>
<left>518</left>
<top>105</top>
<width>1290</width>
<height>105</height>
<align>left</align>
</control>
<left>430</left>
<top>185</top>
<width>690</width>
<height>3</height>
</control>
<!-- Nome do album and anos-->
<left>518</left>
<top>194</top>
<width>1290</width>
<height>30</height>
<align>left</align>
<label>$INFO[MusicPlayer.Album] ($INFO[MusicPlayer.Year])</label>
</control>
<left>516</left>
<top>232</top>
<width>275</width>
<height>30</height>
<texture fallback="subtitle_rating_0.png">$INFO[Player.StarRating]</texture>
</control>
<left>600</left>
<top>278</top>
<width>600</width>
<height>36</height>
<align>left</align>
<font>Font_26</font>
<label>$INFO[MusicPlayer.SampleRate,, kHZ][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitRate,, kbps][COLOR=50FFFAF0] | [/COLOR]$INFO[MusicPlayer.BitsPerSample,,Bits]</label>
</control>
<left>510</left>
<top>262</top>
<width>95</width>
<height>60</height>
</control>
<!-- Duracao -->
<left>1210</left>
<top>260</top>
<width>690</width>
<height>30</height>
</control>
<left>1528</left>
<top>313</top>
<width>370</width>
<height>8</height>
</control>
<left>1528</left>
<top>313</top>
<width>370</width>
<height>8</height>
</control>
<left>990</left>
<top>323</top>
<width>915</width>
<height>45</height>
<label>Track $INFO[MusicPlayer.PlaylistPosition] of $INFO[MusicPlayer.PlaylistLength] [COLOR=50FFFAF0]|[/COLOR] Next: $INFO[MusicPlayer.offset(1).Title] ($INFO[MusicPlayer.offset(1).Artist])</label>
<scrollout>true</scrollout>
</control>
</control>
<include condition="Skin.HasSetting(Similar_Artist_JohnyBee)">JB_PodobniArtysci</include>
<include>BGBlack</include>
</controls>
</window>
2017-02-27, 23:58
(2017-02-27, 20:53)jasn Wrote: [ -> ]Regarding johnjohnny77's requests to modify Layout 5, since I was the orginal author I have re-tweeked the code FOR LAYOUT 5 ONLY to address his thoughts:
1. Scroll Artist;
Code:<?xml version="1.0" encoding="UTF-8"?>
<window>
<!-- Aeon MQ 7 -->
<controls>
<left>0</left>
<top>0</top>
<width>1920</width>
</control>
<left>0</left>
<top>0</top>
<width>1920</width>
</control>
<!-- Fanart -->
</control>
</control>
</control>
</control>
<left>0</left>
<top>0</top>
</control>
<left>640</left>
<top>0</top>
</control>
<left>1280</left>
<top>0</top>
</control>
<left>0</left>
<top>540</top>
</control>
<left>640</left>
<top>540</top>
</control>
<left>1280</left>
<top>540</top>
</control>
</control>
</control>
<left>1390</left>
<top>3</top>
<width>500</width>
<height>34</height>
</animation>
</animation>
</control>
<left>0</left>
<top>1160</top>
<left>0</left>
<top>-123</top>
<width>2520</width>
</control>
<left>1230</left>
<left>60</left>
<top>-30</top>
<width>366</width>
</control>
<left>60</left>
<top>-30</top>
<width>366</width>
</control>
</control>
<!-- reflexo -->
<left>1335</left>
<top>340</top>
<width>525</width>
</control>
<left>1335</left>
<top>-30</top>
<width>525</width>
</control>
<left>21</left>
<top>-38</top>
<width>585</width>
</control>
<left>44</left>
<top>-8</top>
<width>540</width>
</control>
<left>0</left>
<top>-15</top>
<width>300</width>
<height>90</height>
</control>
<left>622</left>
<top>-30</top>
<width>690</width>
<height>45</height>
<align>left</align>
</control>
<left>622</left>
<top>26</top>
<width>690</width>
<height>30</height>
<align>left</align>
</control>
<left>622</left>
<top>72</top>
<width>690</width>
<height>3</height>
</control>
<left>622</left>
<top>84</top>
<width>690</width>
</control>
<left>622</left>
<top>288</top>
<width>666</width>
<height>3</height>
</control>
<left>622</left>
<top>278</top>
<width>120</width>
<height>98</height>
</control>
<left>758</left>
<top>294</top>
<width>600</width>
<height>36</height>
<align>left</align>
</control>
<left>758</left>
<top>328</top>
<width>554</width>
<height>34</height>
</control>
<left>758</left>
<top>328</top>
<width>554</width>
<height>34</height>
</control>
<left>975</left>
<top>327</top>
<width>600</width>
<height>36</height>
<align>left</align>
</control>
</control>
<left>0</left>
<top>1160</top>
<left>0</left>
<top>-123</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>58</left>
<top>-33</top>
</control>
<left>0</left>
<top>-30</top>
<width>450</width>
</control>
<left>0</left>
<top>-30</top>
<width>450</width>
</control>
</control>
<!-- reflexo -->
<left>30</left>
<top>262</top>
<width>450</width>
</control>
<left>30</left>
<top>-60</top>
<width>450</width>
</control>
<left>1545</left>
<top>15</top>
<width>330</width>
</control>
<left>518</left>
<top>-15</top>
<width>1290</width>
<height>45</height>
<align>left</align>
</control>
<left>495</left>
<top>54</top>
<width>690</width>
<height>3</height>
</control>
<left>518</left>
<top>82</top>
<width>1290</width>
<height>30</height>
<align>left</align>
</control>
<left>518</left>
<top>153</top>
<width>1290</width>
<height>30</height>
<align>left</align>
</control>
<left>518</left>
<top>192</top>
<width>600</width>
<height>36</height>
<align>left</align>
</control>
<!-- Duracao -->
<left>1215</left>
<top>195</top>
<width>690</width>
<height>30</height>
</control>
<left>1526</left>
<top>303</top>
<width>375</width>
<height>8</height>
</control>
<left>1526</left>
<top>303</top>
<width>375</width>
<height>8</height>
</control>
<left>990</left>
<top>333</top>
<width>915</width>
<height>45</height>
</control>
</control>
<!-- Layout 3 -->
<left>0</left>
<top>1160</top>
<left>0</left>
<top>-60</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
</control>
<left>30</left>
<top>-110</top>
<width>632</width>
</control>
<!-- reflexo -->
<left>30</left>
<top>345</top>
<width>632</width>
</control>
</control>
<left>698</left>
<top>-120</top>
<width>1192</width>
</control>
<left>698</left>
<top>-34</top>
<width>1192</width>
<height>45</height>
</control>
<left>698</left>
<top>75</top>
<width>1192</width>
<height>30</height>
</control>
<left>968</left>
<top>144</top>
<width>922</width>
<height>30</height>
</control>
<left>705</left>
<top>315</top>
<width>300</width>
<height>36</height>
<align>left</align>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<!-- Duracao -->
<left>705</left>
<top>255</top>
<width>300</width>
<height>27</height>
<align>left</align>
</control>
<left>1200</left>
<top>201</top>
<width>525</width>
<height>45</height>
</control>
<left>1011</left>
<top>240</top>
<width>712</width>
<height>45</height>
</control>
<left>1275</left>
<top>274</top>
<width>450</width>
<height>45</height>
</control>
<left>1682</left>
<top>316</top>
<width>45</width>
<height>30</height>
</control>
<left>1680</left>
<top>315</top>
<width>45</width>
<height>30</height>
</control>
<left>705</left>
<top>135</top>
<width>230</width>
<height>98</height>
</control>
<left>1023</left>
<top>278</top>
<width>135</width>
<height>98</height>
</control>
<left>1160</left>
<top>282</top>
<width>135</width>
<height>98</height>
</control>
<left>1302</left>
<top>310</top>
<width>300</width>
<height>38</height>
</control>
<left>1748</left>
<top>208</top>
<width>135</width>
</control>
</control>
<!-- Layout 4 -->
<left>0</left>
<top>1160</top>
<left>0</left>
<top>-60</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
<left>220</left>
<top>40</top>
<width>200</width>
</control>
<left>220</left>
<top>40</top>
<width>200</width>
</control>
<left>220</left>
<top>320</top>
<width>200</width>
</control>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
<left>50</left>
<top>-80</top>
<width>632</width>
</control>
</control>
<!-- cover -->
<left>30</left>
<top>-110</top>
<width>632</width>
</control>
<left>30</left>
<top>345</top>
<width>632</width>
</control>
<left>698</left>
<top>-120</top>
<width>1192</width>
</control>
<left>698</left>
<top>-120</top>
<width>1192</width>
</control>
<left>698</left>
<top>-34</top>
<width>1192</width>
<height>45</height>
</control>
<left>698</left>
<top>75</top>
<width>1192</width>
<height>30</height>
</control>
<left>968</left>
<top>144</top>
<width>922</width>
<height>30</height>
</control>
<left>705</left>
<top>315</top>
<width>300</width>
<height>36</height>
<align>left</align>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<left>705</left>
<top>300</top>
<width>255</width>
<height>8</height>
</control>
<!-- Duracao -->
<left>705</left>
<top>255</top>
<width>300</width>
<height>27</height>
<align>left</align>
</control>
<left>1200</left>
<top>201</top>
<width>525</width>
<height>45</height>
</control>
<left>1011</left>
<top>240</top>
<width>712</width>
<height>45</height>
</control>
<left>1275</left>
<top>274</top>
<width>450</width>
<height>45</height>
</control>
<left>1682</left>
<top>316</top>
<width>45</width>
<height>30</height>
</control>
<left>1680</left>
<top>315</top>
<width>45</width>
<height>30</height>
</control>
<left>705</left>
<top>135</top>
<width>230</width>
<height>98</height>
</control>
<left>1023</left>
<top>278</top>
<width>135</width>
<height>98</height>
</control>
<left>1160</left>
<top>282</top>
<width>135</width>
<height>98</height>
</control>
<left>1302</left>
<top>310</top>
<width>300</width>
<height>38</height>
</control>
<left>1748</left>
<top>208</top>
<width>135</width>
</control>
</control>
<left>0</left>
<top>1160</top>
<left>0</left>
<top>0</top>
<width>2520</width>
</control>
<left>-105</left>
<top>-30</top>
<left>0</left>
<top>30</top>
</control>
<left>0</left>
<top>45</top>
<width>450</width>
</control>
<left>0</left>
<top>45</top>
<width>450</width>
</control>
</control>
<!-- reflexo -->
<left>30</left>
<top>262</top>
<width>450</width>
</control>
<left>30</left>
<top>15</top>
<width>450</width>
</control>
<left>1400</left>
<top>-650</top>
<width>430</width>
</animation>
</animation>
</control>
<left>518</left>
<top>70</top>
<width>1290</width>
<height>45</height>
<align>left</align>
</control>
<left>430</left>
<top>122</top>
<width>690</width>
<height>3</height>
</control>
<left>518</left>
<top>105</top>
<width>1290</width>
<align>left</align>
</control>
<left>430</left>
<top>185</top>
<width>690</width>
<height>3</height>
</control>
<left>518</left>
<top>194</top>
<width>1290</width>
<height>30</height>
<align>left</align>
</control>
<left>516</left>
<top>232</top>
<width>275</width>
<height>30</height>
</control>
<left>600</left>
<top>278</top>
<width>600</width>
<height>36</height>
<align>left</align>
</control>
<left>510</left>
<top>262</top>
<width>95</width>
<height>60</height>
</control>
<!-- Duracao -->
<left>1210</left>
<top>260</top>
<width>690</width>
<height>30</height>
</control>
<left>1528</left>
<top>313</top>
<width>370</width>
<height>8</height>
</control>
<left>1528</left>
<top>313</top>
<width>370</width>
<height>8</height>
</control>
<left>990</left>
<top>323</top>
<width>915</width>
<height>45</height>
</control>
</control>
</controls>
</window>
Dear Jasn,
it all works perfectly!!! It's amazing and you are a very kind and helpful guy!
I'm sure that this is an essential improvement, not a personal fancy... and I hope that this change will be useful not only to me but to other people as well.
I really really thank you for accepting my suggestion and let it come true
2017-02-28, 00:05
(2017-02-27, 20:04)scottywhu Wrote: [ -> ]Hi Emiralles,
Scottywhu
You can active "skinhelper script" in settings music.
