emiralles, no problem in get features my mod skin, but please give credits authors mods
NextUp PostInfo - by Angelinas
PVR views - by Bumblebee
Music Visualization by Manfeed.
Regards,
(2017-02-07, 01:15)Ruk12345 Wrote: [ -> ] (2017-02-07, 01:02)emiralles Wrote: [ -> ]no 1.4.0.6 - 1/13/2016 ( oops error in year, it's 2017 sorry )
That's the version I downloaded this link : https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
After I installed it the version in Kodi is still showing .5 not .6
the link it's good but the version it's 1.4.0.6 you can see in settings
Thanks what was occurring is after I added @Latts awesome multi mod to new version the version number changed.
This could be a real newb question, but in customize main menu what does the "presets" do?
Can I change the default menu layout to 5 items vs 3? And can I have the submenu always visible?
Please point me to the right area, I looked all over skin settings unless I am blind and keep missing it
i'm new to kodi coming from last xbmc version.
The problem i have is how can i install the skin because i cant find the option to install from zip. I just canf find it!.
can anyone help me?
thanks in advance!!
(2017-02-08, 21:15)exyron Wrote: [ -> ]Hi,
can anyone help me?
thanks in advance!!
Need to change settings level to advanced or expert
http://kodi.wiki/view/settings
After that should be that option in the addons tab
thank you, it was insane...
finally i find the option in the addons "manager"
(2017-02-08, 21:28)exyron Wrote: [ -> ]thank you, it was insane...
Yeah a lot has changed setting wise since the XBMC days. Most your answers should be covered in the wiki
(2017-02-06, 15:47)Wanilton Wrote: [ -> ]@emiralles, I need talk with Marcos about, and I will answer asap....
And I have one question if maked, I donĀ“t know if area Aeon MQ was recreated...probably only when Marcos publish in repo will be.
Wanilton any word from Marcos yet? Would be nice to get it in the repo along with the forum fixed.
Tried this mod now for the first time after using MQ5 for the last years. Looks really nice. Thanks so far.
But with the PVR views I don't feel really happy. It was a little bit easier to read in MQ5.
And the tv-guide view seems to be completely broken. It doesn't show anything. Is there a chance to fix it?
I have try to install the version 1.4.0.6 and 1.4.0.5 but always get this error >
dependency on xbmc.python version 2.25.0 could not be satisfied
Using Kodi 16
Is there any thing i can do, to fix it?
Not sure, but Kodi 16 is Jarvis. This mod provides MQ7 for Krypton, which means Kodi 17.
