Take a look and i'll tell you anything about it
Hi Emiralles...
I have received your private message, but I can't reply you privately probably because I have just registered to this forum (Yes... I have complete the account activation...)
Can I email you directly?, please let me know your e-mail via a PM...
And thank you for looking into this...
Regards
Joe
spudnutz, please don´t remove name author skin in settings.
(2016-12-03, 00:16)Wanilton Wrote: [ -> ]@spudnutz, please don´t remove name author skin in settings.
I'll add it back in....simples
ty sir
(2016-12-03, 00:56)spudnutz Wrote: [ -> ] (2016-12-03, 00:16)Wanilton Wrote: [ -> ]@spudnutz, please don´t remove name author skin in settings.
ty sir
watch gallery
Props to MarcosQui and Emiralles!
great work!
(2016-12-03, 01:24)spudnutz Wrote: [ -> ] (2016-12-03, 00:56)spudnutz Wrote: [ -> ] (2016-12-03, 00:16)Wanilton Wrote: [ -> ]@spudnutz, please don´t remove name author skin in settings.
ty sir
watch gallery
great work!
You make a great work too, I like the video a lot !!!
I have a new version better than this, if you want I can give you the link by pm.
Thank you for this great mod!
Just one question (for now): I seem to not be able to get the information on an artist in the music library to popup. I hear a sound but nothing happens.
In the log I see it tries to open a file that indeed doesn't exist: "...kodi\portable_data\addons\skin.aeonmq7.krypton.mod\1080i\DialogMusicInfo.xml, Line 0
Failed to open file...
Was it ever the intention to make a separate info for the music, or is the pointing to a wrong file?
(2016-12-03, 18:35)Thugbear Wrote: [ -> ]Thank you for this great mod!
reinstall, this file exist and it's very important for me.
Thanks for your words.
I did reinstall the zip from the first page (unless I missed an update somewhere) and that didn't work.
If I manually unzip it and check it I cant find it either? I might be overlooking something...
ps Thanks for really quick response
(2016-12-03, 19:06)Thugbear Wrote: [ -> ]I did reinstall the zip from the first page (unless I missed an update somewhere) and that didn't work.
I send you a pm
Thank you very much for the hard work you did to mod this skin for krypton. It is working perfectly for me except for one issue. While watching a video I can not bring up the codec information screen. I tested it on the estuary skin and by pressing the o button it works but when i switch to your skin it does not?? Was wondering if you could fix this issue. Once again thank you for your work it is great.
(2016-12-03, 20:32)emiralles Wrote: [ -> ] (2016-12-03, 19:06)Thugbear Wrote: [ -> ]I did reinstall the zip from the first page (unless I missed an update somewhere) and that didn't work.
I send you a pm
Thank you! It works wonderfully...
(2016-12-03, 17:04)emiralles Wrote: [ -> ]You make a great work too, I like the video a lot !!!
Hi emiralles,
thanks alot for your mod
is that an updated version of your mod?
