2016-12-11, 12:19
(2016-12-09, 22:30)emiralles Wrote: [ -> ]Here is the solution
https://drive.google.com/file/d/0B7nL1Z3...sp=sharing
put in 1080i directory and copy the new smartplaylist files.
Thank you very much, it works now
(2016-12-11, 00:39)emiralles Wrote: [ -> ]Dave B.
Can you send a image with your "problems"
(2016-12-03, 17:04)emiralles Wrote: [ -> ](2016-12-03, 01:24)spudnutz Wrote: [ -> ](2016-12-03, 00:56)spudnutz Wrote: [ -> ]I'll add it back in....simples
ty sir
watch gallery
Props to MarcosQui and Emiralles!
great work!
You make a great work too, I like the video a lot !!!
I have a new version better than this, if you want I can give you the link by pm.
ty sir
watch gallery
great work!
(2016-12-11, 18:18)defleppard Wrote: [ -> ]Hi there, can´t get animated poster onmy movies. I delete script skin.helper.service and download it again,and nothing.
jhe situation is , i don´´t see under collection/change view ___cinemagraph arts poster and fanart
(2016-12-12, 13:55)tuareg Wrote: [ -> ]Thanks to Emiralles post, my widgets are ok now, in smart playlists, but on choosing a widget category as say "movie genres" and then selecting a genre widget, the listing for that genre does not appear
(2016-12-11, 15:50)Dave.B Wrote: [ -> ](2016-12-11, 00:39)emiralles Wrote: [ -> ]Dave B.
Sorry CTRL+S not working in this mod this is part of the problem (# 8 on my list).
If you have an idea how can i print screen i will be happy to do that.
By the way, found another problem: subtitle sync dosn't work.
(2016-12-11, 21:30)Dave.B Wrote: [ -> ](2016-12-11, 18:18)defleppard Wrote: [ -> ]Hi there, can´t get animated poster onmy movies. I delete script skin.helper.service and download it again,and nothing.
I have the same problem. see post #112 above.
Worked fine on Jarvis but not working on Krypton Mod among other things that needs to be fixed.
(2016-12-11, 17:52)spudnutz Wrote: [ -> ](2016-12-03, 17:04)emiralles Wrote: [ -> ](2016-12-03, 01:24)spudnutz Wrote: [ -> ]watch gallery
great work!
opps reread .... ya i would luv to try it out ... waiting patiently for a pm from you ....
thx again Emiralles (glad you liked the video)
(2016-12-12, 18:35)emiralles Wrote: [ -> ](2016-12-11, 21:30)Dave.B Wrote: [ -> ](2016-12-11, 18:18)defleppard Wrote: [ -> ]Hi there, can´t get animated poster onmy movies. I delete script skin.helper.service and download it again,and nothing.
I have animated poster without problems
Check your configuration.
