2019-08-30, 15:21
Thanks... got the A2. You were right; very responsive, as good as the Amazon voice BT remote I was using. But, with added benefit of full keyboard on back.
(2019-08-30, 15:21)hdmkv Wrote: [ -> ]Thanks... got the A2. You were right; very responsive, as good as the Amazon voice BT remote I was using. But, with added benefit of full keyboard on back.
(2019-08-30, 15:40)lightsout Wrote: [ -> ]The remote is IR+RF. The IR is for power on and off control, the main HTPC control for navigation is RF (2.4GHz) to a USB RF receiver, not IR. Not Bluetooth, but similar. (A bit like RF keyboards that aren't Bluetooth)(2019-08-30, 15:21)hdmkv Wrote: [ -> ]Thanks... got the A2. You were right; very responsive, as good as the Amazon voice BT remote I was using. But, with added benefit of full keyboard on back.
But it's IR instead of Bluetooth?
(2019-08-30, 23:34)noggin Wrote: [ -> ](2019-08-30, 15:40)lightsout Wrote: [ -> ]The remote is IR+RF. The IR is for power on and off control, the main HTPC control for navigation is RF (2.4GHz) to a USB RF receiver, not IR. Not Bluetooth, but similar. (A bit like RF keyboards that aren't Bluetooth)(2019-08-30, 15:21)hdmkv Wrote: [ -> ]Thanks... got the A2. You were right; very responsive, as good as the Amazon voice BT remote I was using. But, with added benefit of full keyboard on back.
(2019-08-31, 10:16)wrxtasy Wrote: [ -> ]I do not have a HDR10+ TV to test with but I've been told that AMLogic's Android Pie 9.0 has HDR10+ support.
For those that can test flash an Android TV Pie image from THIS (click) thread.
Cannot quite remember but I may have had issue during initial setup with Android when using a 4K HDMI connected display. Had to use a 1080p one.
Was fine after I played around in Android TV > Display settings.
(2019-08-31, 18:14)lightsout Wrote: [ -> ](2019-08-31, 10:16)wrxtasy Wrote: [ -> ]I do not have a HDR10+ TV to test with but I've been told that AMLogic's Android Pie 9.0 has HDR10+ support.
I plan on flashing this build when I get my device. Seems to be the go to version of Android TV.
Do you have any limitations as far as apps go? I understand that Netflix won't support HD
Quote:But curious about the resolution other streaming apps play at.
Quote:And also the availability or lack thereof of apps on the play store. Sometimes Google likes to not allow certain devices to install certain apps.
(2019-09-02, 05:43)wrxtasy Wrote: [ -> ](2019-08-31, 18:14)lightsout Wrote: [ -> ](2019-08-31, 10:16)wrxtasy Wrote: [ -> ]I do not have a HDR10+ TV to test with but I've been told that AMLogic's Android Pie 9.0 has HDR10+ support.
Android Netflix will not even be available in the Google PlayStore on uncertified Android devices.
The Android Kodi Leia ATV Netflix Addon is not working for me either with the above linked ATV ROM. Works fine with CoreELEC.
I doubt any video streaming Apps that require any sort of Widevine L1 DRM or Microsoft Playready will work at all, if they do streaming will be SD only.
I do have my local subscription IPTV - Kayo sports App streaming in high quality 1080p h264
I don't think it uses DRM.
YouTube is 4K (HDR).
Google have changed their stance on 3rd party Android ROM's for usage with the Play Store - all you have to do now is register your uncertified device with them and the Play Store works normally:
See HERE
What I am impressed with is the snappiness of the above linked ATV Pie ROM, it's based on the LineageOS Android distribution (click).
(2019-09-03, 03:58)HomerJau Wrote: [ -> ]I have CoreElec installed on my N2’s emmc and would like to now use LibreElec builds.Did you think of asking for a proper solution on LibreElec forum ?
What’s the easiest way to do this as I read somewhere CoreElec uses a non compatible boot method?
(2019-09-04, 20:29)poofyhairguy Wrote: [ -> ]So Ameridroid and Hardkernel are offering a package deal for the N2:I also ordered. Good price and will sell my Minix to my neighbor but keep remote.
https://ameridroid.com/products/odroid-n...ec-edition
I have been holding off but that convinced me to get one and a 16GB eMMC to go with it.
