(2021-03-10, 02:53)kow1234 Wrote: [ -> ]im sorry but i dont see any option anywhere to set color to none can u plz tell me where this setting is r u talking about the tag setting
Currently, you have to go into custom color section.
On right side scroll to the home colors,
you 'll should set booth of those colors to none
- Backgroundpanel-Color for Bottom Tags
unfocused Items(set to none for disable)
focused Items (set to none for disable)
You can do the same for the common library
Lookup for the same color buttons under "Nav Media Item" Custom Color Section
thank you it looks like it should now looks really good
do you have an eta on when maybe another alpha update or an rc release
i just got your titan mod liea running on matrix
swan doesn't seem to show unwarched episode count in corner some addons have option to show unwatched episode count in widgets. like vanom and seren. In your titan mod liea they show up same with auramod is there an adjustment i can make to get them to show up in the settings of venom it says that some skins and some setups might not show unwatched count. so i was hoping that maybe there is an adjustment i can make to fix this. Plz let me now. thx
(2021-03-09, 11:53)mardukL Wrote: [ -> ]@kow1234
@CiXel
@Zeule
The Home Menu Navigation is currently intented and will stay at Default (its My personal Preference )
- booth circular/non-cicular(default) have it's Pros/Cons
But i know about the issue that it can be confusing, and i have an optional navigation Option on my "To_Do_List".
No ETA.
Sure, I totally get the pros and cons. Alpha' the easiest time to think about it.
Are you planning on different widget views? The home view looks and works great. Was wondering if there's a thought for separate ones for say movies or TV that could be triggered from the side menu.
(2021-03-12, 01:33)kow1234 Wrote: [ -> ]some addons have option to show unwatched episode count in widgets. like vanom and seren.
You've joined this forum some 3 years ago, so you should know by now that there are certain add-ons that we do not want in Kodi setups, or even have them mentioned on this forum.
I suggest you familiarize yourself (again) with our
forum rules (wiki) and
piracy policy (wiki).
kow1234 Are you unfamiliar with how the quote function works..? Quoting a post without adding your reply is a bit confusing.
I'm having Nvidia Sheild and Plex Kodi connect. For some reason the subtitles offset button doesn't work at all. I can't even press it. Is it a common skin issue right now?
(2021-03-19, 21:23)Slobontan Wrote: [ -> ]I'm having Nvidia Sheild and Plex Kodi connect. For some reason the subtitles offset button doesn't work at all. I can't even press it. Is it a common skin issue right now?
Seems so,
i think dialogslider xml is used there, which isnt defined in the skin right now.
Hi mardukL,
Thanks for the great skin, I really like it!
I have a question, how do I get that in the movie/tv shows titles instead of the purple simple text Ill get movie/tv shows logos?
Sorry for the noob question
Thanks again
(2021-03-20, 14:42)doriezz123 Wrote: [ -> ]Hi mardukL,
Thanks again
unsure if i get you right.
clearlogo will be shown if exist, if not it'll show the title.(spotlight home, view58, view502)
there is no option to deactivate this behaviour, and it'll not come in future.
