(2020-03-03, 11:18)sanangel Wrote: [ -> ]Ok. My only intention is to help as little as I can ... I will look forward to the OSD, hehe ...
No, problem. Just pointed to the WIP/ alpha state.
(2020-03-15, 11:16)Butta97 Wrote: [ -> ]I've finally know how to use this skin and I've been enjoying it.. Only question I have is there's no Netflix view in the add-on just home menu?
Currently no 'Netflix Style View Type', yes.
'just' an inspired season viewtype and home .
not much time to get 'things' how i wanted them.
But progress goes on..
- add trailer preview windows (lists)
list 50 viewtype
info list 56 viewtype
- worked on videoinfo + add optional select actions to navigate from there [select movie/tv shows will either do 'play/go to seasons' or 'open info for selected items']
videoinfo
congratulations looks amazing i use a raspberry pi 3, Do you think it is light enough to run without braking?
(2020-03-20, 23:04)Castilho Wrote: [ -> ]congratulations looks amazing i use a raspberry pi 3, Do you think it is light enough to run without braking?
I think yes.
i tested it on a
android 5 system
Quad Core Cortex-A53 CPU + Mali-450 GPU;
RAM 2GB.which is not pretty good anymore.
and its usable, but not perfect.
what can be slow is
- music hub when searching with a huge musiclibrary
- the " first run " when using the optional blurred fanart background
- wiki link -
https://github.com/sualfred/script.embua...-you-start
- the opening of the shutdown menu when using blurred shutdown background
- user defined widgets without set a limit when widget container has a lot items to load espeacially pulled from addon (if there are load penaltys ,try set a limit )
- video info fanart container (using local extrafanart / extrathumbs container) as content can be slow to refresh/load items
mardukL, I would like to test the skin on kodi 18.6 on my PC. How to install?
(2020-03-26, 03:42)DoctorBR Wrote: [ -> ]@mardukL, I would like to test the skin on kodi 18.6 on my PC. How to install?
Currently no test version, because i 'test and experiment' alot for myself, which result in changes of layout and other things from time to time.
Therefore its not time for a real beta-publish.As i dont want bug report and or requests at this state.
(There is currently no proper video osd, and a the color settings are not well adjusted for easy usage and... more...)
But i saw you find the git branch,
you can
1. download the git version
2. unpack them and rename the unpacked folder
skin.swan-alpha-master
to
skin.swan
3. create zip
4. install from zip
(2020-03-26, 17:45)mardukL Wrote: [ -> ]But i saw you find the git branch .
Hi mardulkl , where it is mate? . If its hidden can you tell me in a private message? .
Forgive my english.
Thanks for your work , it looks amazing.
Thanks a lot !! Keep up the great work!
mardukL do you have plans to add support for the advanced emulator launcher with this?
(2020-03-27, 17:56)Hudson_Hawk04 Wrote: [ -> ]@mardukL do you have plans to add support for the advanced emulator launcher with this?
its on to list, but no time frame when i will get over the implemantion needs.
i getted help before by @
chrisism in the tittan mod, so i learned a bit about. ;-)
Ok cool glad it’s going to be in there, absolutely love your work can’t wait for a test release I’d be more than happy to help out your skin looks gorgeous.
Looks very nice, hopefully we can test soon as we need to stay home and getting bored
