(2021-09-18, 20:18)josavvyy Wrote: [ -> ]Any chance of adding Fantasy Massage and Bang? I think Fantasy Massage is by the people as girlsway
I've added these sites to my (not too short
) todo list, but they are absolutely possible.
(2021-09-19, 18:35)xbmcuser101 Wrote: [ -> ]I am new to ember and this scraper so excuse my ignorance, but is there a way to pull the actor image from imdb, tmdb, or iafd? Is there a way to set the scraper to use a specific site so with a large collection I don't have to keep selecting the site. For example I click re-scrape the file and I get the "The source of the video file cannot be auto detected, Please select the possible video sites with the blinking button on the left."
I also used IAFD with another scrapper (JavMovieScrapper) but since April 01 2021, IAFD only return the Year. All others field are left blank.
IAFD no longer let scraping using "robots". For now i did not find any ways to bypass this even playing with my VPN.
You can use it manually to copy image link. It is still a very good source for actors images and the web page search engine is good to find an actress with a dozen of variety of name for the same actress.
v0.8.0-BETA.1
ADD: Possibility to use Tor network for searching to avoid too many request errors.
I did not find how can i select Tor network via Ember Media. Is there an option somewhere ? Are it is done automatically ?
Can someone explain to me please ?
(2021-09-20, 00:03)slappy Wrote: [ -> ]v0.8.0-BETA.1
Hi @
slappy ,
AdultScraper starts the Tor proxy if needed: getting too many requests error, or a search result or a website doesn't accessible in your country.
If it doesn't work please, report it.
(2021-09-18, 20:17)josavvyy Wrote: [ -> ] (2021-09-18, 18:55)adultmm Wrote: [ -> ] (2021-09-18, 14:17)josavvyy Wrote: [ -> ]It has been fixed! The new beta works great great! The only issue I'm finding is Brazzers returns a "length cannot be less than zero" for every search for me. I then seaarch by actress and it works. I was getting this before the beta.
I can't reproduce the Brazzers error. Could you send me the search query that caused the error? Thanks
sexy-sneaky-stylist_1080p
Thank you, @
josavvyy,
The problem is that the search engine sees "With | Brazzers Official" as the title. (
Example.) I'll download the video info in these cases. It'll be fixed in the next version.
Did the Team Skeet sub sites (daughter swap, dad crush, sis loves me, etc.) change? I haven't been able to find a match in the last week or so.
(2021-09-20, 12:14)josavvyy Wrote: [ -> ]Did the Team Skeet sub sites (daughter swap, dad crush, sis loves me, etc.) change? I haven't been able to find a match in the last week or so.
As I see, these sites were removed from the TeamSkeet network:
https://www.teamskeet.com/series/original
update: If I selected the appropriate Scraper (eg. DaughterSwap) the new videos were also found (eg. cops and stepdaughters). Could you tell me more about the problem? Thanks
(2021-09-19, 19:56)adultmm Wrote: [ -> ] (2021-09-19, 18:35)xbmcuser101 Wrote: [ -> ]I am new to ember and this scraper so excuse my ignorance, but is there a way to pull the actor image from imdb, tmdb, or iafd?
I'm working on the TMDB actor image downloading.
(2021-09-19, 18:35)xbmcuser101 Wrote: [ -> ]Is there a way to set the scraper to use a specific site so with a large collection I don't have to keep selecting the site. For example I click re-scrape the file and I get the "The source of the video file cannot be auto detected, Please select the possible video sites with the blinking button on the left."
AdultScraper tries to detect the scraper from the path as well, so the easier way is to put your videos into a folder with the name of the studio (Brazzers, EvilAngel, etc). I hope it will help.
Thanks! that helped a lot!
Is there any way to add an option to give a link to a scene when the scraper cannot find the info?
for example Nubiles / My Family Pies site, When trying to scrape the scene name, see below, or just the actors name fails to yield accurate scene matches
Teasing My Step Brother On New Years
Let Me Get A Peek At Chu
Sneaking In To Fuck My Step Bro
Lick It Before You Stick It
(2021-09-20, 19:31)adultmm Wrote: [ -> ] (2021-09-20, 12:14)josavvyy Wrote: [ -> ]Did the Team Skeet sub sites (daughter swap, dad crush, sis loves me, etc.) change? I haven't been able to find a match in the last week or so.
As I see, these sites were removed from the TeamSkeet network: https://www.teamskeet.com/series/original
i got it working fine. Must have been something on my end. Thanks!
The Brazzers fix in beta 2 works well! Thanks
(2021-09-20, 23:53)xbmcuser101 Wrote: [ -> ] (2021-09-19, 19:56)adultmm Wrote: [ -> ] (2021-09-19, 18:35)xbmcuser101 Wrote: [ -> ]I am new to ember and this scraper so excuse my ignorance, but is there a way to pull the actor image from imdb, tmdb, or iafd?
It'd be possible to scrape the information from the links, but it'd require some work in every scraper, so it's not a small task.
The question is, why not found these videos on your side? I selected the "NubilesPorn" scraper, and all videos were found.
NSFW!
https://i.imgur.com/1EFyvfP.png
Could you send me the full path of a video? Thanks
(2021-09-21, 09:35)adultmm Wrote: [ -> ]It'd be possible to scrape the information from the links, but it'd require some work in every scraper, so it's not a small task.
NSFW!
User error!
Sorry was using ver 7.8. Tried with beta 2 and works. Double checked and 7.8 didnt pull the info but beta 1 and 2 do.
v0.8.0-BETA.2
ADD: AnalVids.com now supports studio information : Tested Work perfect !
Not sure if these have been asked for or on the "to do list" but would be nice to see scrapers for these sites added. All are .com except for jayspov is .net. Thanks again awesome scrapper!
lanewgirl
netvideogirls
casualteensex
cherrypimps
exploitedteens
exploitedcollegegirls
familyxxx
filthykings
filf
jayspov
lethalhardcore
loveherass
mypervyfamily
netgirl
atkgirlfriends
rodneymoore
dirtyflix
teenylovers
trueamateurs
tuktukpatrol
ultrafilms
watch4beauty
fit18
whiteghetto
wowporn
This may seem silly but, this scraper has been great for getting the metadata I like, but... and hopefully no one comes with the pitchforks... I'm a Plex user. I've tried a scraper that you can add as a bundle, but it really struggles for the individual scenes that may be part of a movie. So if there were say, 4 scenes for a Naughty Office 35 movie, but I only have one scene from it, the Plex scraper won't find the info from it. Your plugin has worked quite well there. Is there any way to include metadata that Plex could read so that it will pull in the artwork, metadata, etc?
