adultmm
You are correct in that IMDB requires one to sign in and enable Include Adult results. I have not seen any media manager or scraper that gets adult content from IMDB by default, some will do it if the IMDBid is entered.
Hi @
Juan Mortyme,
(2022-05-28, 05:46)Juan Mortyme Wrote: [ -> ]@adultmm
First off, thank you so very much for this wonderful program. I didn't think I'd ever get my adult series scraped, I was manually creating nfo files for them. Even though I have to scrape them as individual videos rather than TV Shows with a few quick edits they can be turned into TV episodes.
Is there a way to set TMDB as the default or first choice and IAFD second choice for actor thumbs for videos?
AdultScraper now uses all possible Actors' scrapers parallelly, so the order is not defined.
However, it's a good idea, so I created an
issue to implement it later.
(2022-05-28, 05:46)Juan Mortyme Wrote: [ -> ]Could you add Dirty Flix network and sites?
As I can see, Dirty Flix doesn't contain public video pages, only some of the latest updates are visible on the main page. So I cannot support it.
(2022-05-28, 05:46)Juan Mortyme Wrote: [ -> ]Thanks again.
adultmm
Ya, Dirty Flix is hard on to navigate. You can drill down to the individual sites by clicking on the sites link in small print below the scene on the home page. It's not that important since porndb scrapes them but porndb seems to hate me and always goes offline when I need it.
Thanks for looking into it.
(2022-01-29, 15:19)Johnson_Stgt Wrote: [ -> ]Hi,
would it be possible to implement a scraper for the following sites (NSFW!)?
https://www.scorevideos.com/
https://www.scoreland.com/
https://www.scoreland2.com/
Maybe also www.eboobstore.com/ As far as I know, all scenes (and movies) from the score group are listed there. However, some are named differently than on the individual sites.
Regarding the Jules Jordan Scraper:
I noticed that the "automatic (force best match)" method does not work there (even though it works for the other scrapers), but I coudn't figure out why. I use Version 0.9.0-BETA.1.
Kind regards
Hi @
Johnson_Stgt,
ScoreUniverse scrapers are now available in the
v0.11.0-BETA.2 version.
Regards
Having two major issues with a clean download of the 0.11.0-BETA.2 version (and every previous one)
1. Nothing I can do, including every bit of naming advice suggested in the last couple of pages, allows me to automatically detect the website for a given scene. Only PornDB and Data18 are automatically selected.
2. Using either PornDB or Data18 causes immense lag and a spamming of "Cannot reach IMGBOX.COM" popups, making scraping even individual files extremely painful.
According to your issues page on Github, #1 is supposed to be working, so I think it is some bizarre config issue on my end. All paths are in X:\blah\blah\Network\Site\Movie, which the response
here suggests should work.
(2022-06-30, 23:13)Gnoman Wrote: [ -> ]Having two major issues with a clean download of the 0.11.0-BETA.2 version (and every previous one)
According to your issues page on Github, #1 is supposed to be working, so I think it is some bizarre config issue on my end. All paths are in X:\blah\blah\Network\Site\Movie, which the response here suggests should work.
Gnoman
1. Try the setting Setting>Movies>Adultsctapper>General Settings>Video/Movie is set on 'Try Autodetect Video".
2. I too have this problem after scraping a few scenes. I found restarting the program will fix it for at least a few more scrapes.
(2022-07-01, 02:47)Juan Mortyme Wrote: [ -> ] (2022-06-30, 23:13)Gnoman Wrote: [ -> ]Having two major issues with a clean download of the 0.11.0-BETA.2 version (and every previous one)
@Gnoman
Gnoman,
2. I think the problem is caused because the
https://imgbox.com/ page (AMM stores the secured or WEBP images there) is not stable in your country. Here is an issue about it:
https://github.com/adultmm/AdultMediaManager/issues/35
adultmm
Thanks, dropped my VPN and works fine from Canada.
Hi @
Gnoman,
I've checked a new install, and it works fine for me, videos are autodetected. Could you send me some full paths that you tried?
Thanks for the software it's great!
Would you be able to add a option to ignore warning messages, so I can leave it to do the matching without input? For example I would like to ignore 'Cannot reach IMGBOX.COM' popups and let the software match everything it can, and then manually fix those ones later.
It would also be great if we could select what sites to match against. For example, if I have a folder I know is all a certain site, it would be great to tell the scraper that so it knows to search that site specifically. Would help a lot with manual matching.
(2022-07-18, 01:17)DrunkSith Wrote: [ -> ]Thanks for the software it's great!
(2022-07-18, 01:17)DrunkSith Wrote: [ -> ]Would you be able to add a option to ignore warning messages, so I can leave it to do the matching without input? For example I would like to ignore 'Cannot reach IMGBOX.COM' popups and let the software match everything it can, and then manually fix those ones later.
I'll check the possibility of a silent mode, or something similar.
(2022-07-18, 01:17)DrunkSith Wrote: [ -> ]It would also be great if we could select what sites to match against. For example, if I have a folder I know is all a certain site, it would be great to tell the scraper that so it knows to search that site specifically. Would help a lot with manual matching.
My plugin tries to autodetect the scrapers by the full path. The name of your folder should be the URL (or the name if it's not too common) of the site and it should work. If it doesn't work, please send me some example paths and I'll fix it.
(2022-07-18, 01:17)DrunkSith Wrote: [ -> ]Thanks!
How do u select the scrapers before scraping begins? (Movies - scrapers - adultscraper - general settings) - I only see theporndb and data18 and only given option to select additional scrapers once scrape begins
