2009-07-28, 09:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
2009-07-28, 09:44
Wow this looks excellent, it makes me want to give setting up Myth another go
Looks like i'll be busy this weekend ! :p
Great work.
Great work.
2009-07-29, 03:53
Quote:Re-read the install instructions. Especially the part about where to install the script.
I did read the install instructions before installing. I downloaded the latest version posted and noticed that when un-tarring I got a "file is corrupt" error that I hadn't noticed before. It turned out to be WinRAR v3.0 causing the issue. Upgrading to V3.9 solved it.
BTW, I installed XMBC and MythBox all under the same directory on my D: drive and that works fine.
Thanks! Now back to watching Myth.
JR
2009-07-29, 04:05
AuXBoX Wrote:is there a way to change channels without going back to watch tv menu?
Its on the todo list :-)
2009-07-30, 09:24
Hello, I'm a newbie and desperatately trying to get my XBox XBMC to run MythBox. I updated XBMC to the lastest svn and grabbed the latest MythBox as well. Apart from the error "No module named msvcrt" I then get a "Python script failed: Q:\scripts\MythBox\default.py"
I don't know if I have an old Python version or does that ship inside XBMC, if not how to I check the python version and upgrade if needed? The log output is below, help getting it working will be greatly appreciated.
edit: Just noticed my post got moved, sorry it was in the wrong spot. Does anyone have any ideas for me, I've tried the latest XBMC svn and stable release with the same results!?
16:51:02 M: 55394304 NOTICE: -----------------------------------------------------------------------
16:51:02 M: 55365632 NOTICE: Starting XBMC, Platform: Xbox. Built on Jun 26 2009 (SVN:21142, compiler 1310)
16:51:02 M: 55365632 NOTICE: special://xbmc/ is mapped to: Q:\
16:51:02 M: 55365632 NOTICE: special://masterprofile/ is mapped to: special://xbmc/userdata
16:51:02 M: 55365632 NOTICE: special://home/ is mapped to: Q:\
16:51:02 M: 55365632 NOTICE: special://temp/ is mapped to: Z:\
16:51:02 M: 55365632 NOTICE: The executable running is: E:\Apps\XBMC\default.xbe
16:51:02 M: 55365632 NOTICE: Log File is located: Q:\xbmc.log
16:51:02 M: 55365632 NOTICE: -----------------------------------------------------------------------
16:51:02 M: 55365632 NOTICE: Unmapped drive T
16:51:02 M: 55365632 NOTICE: Mapping drive T to Harddisk0\Partition1\Apps\XBMC\userdata
16:51:02 M: 55365632 NOTICE: Setup DirectX
16:51:03 M: 55341056 NOTICE: Mapping drive C to Harddisk0\Partition2
16:51:03 M: 55341056 NOTICE: Mapping drive E to Harddisk0\Partition1
16:51:03 M: 55341056 NOTICE: Unmapped drive D
16:51:03 M: 55341056 NOTICE: Mapping drive D to Cdrom0
16:51:03 M: 55341056 NOTICE: Mapping drive X to Harddisk0\Partition3
16:51:03 M: 55341056 NOTICE: Mapping drive Y to Harddisk0\Partition4
16:51:03 M: 55336960 NOTICE: Unmapped drive Z
16:51:03 M: 55336960 NOTICE: Mapping drive Z to Harddisk0\Partition5
16:51:03 M: 55336960 NOTICE: load settings...
16:51:03 M: 55336960 NOTICE: Mapping drive P to Harddisk0\Partition1\Apps\XBMC\userdata
16:51:03 M: 55336960 NOTICE: special://profile/ is mapped to: special://xbmc/userdata
16:51:03 M: 55336960 NOTICE: loading special://masterprofile/guisettings.xml
16:51:03 M: 55185408 NOTICE: Getting hardware information now...
16:51:03 M: 55185408 NOTICE: Checking resolution 10
16:51:03 M: 55185408 NOTICE: Setting autoresolution mode 6
16:51:03 M: 55185408 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
16:51:03 M: 55185408 NOTICE: Default Video Player: mplayer
16:51:03 M: 55185408 NOTICE: Default Audio Player: paplayer
16:51:03 M: 55185408 NOTICE: Per AV pack settings are off
16:51:03 M: 55296000 NOTICE: special://xbmc/userdata/sources.xml
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button browser_home
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button browser_favorites
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button browser_refresh
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button browser_search
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button launch_app1_pc_icon
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button launch_media_select
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button play_pause
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button stop
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button volume_up
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button volume_mute
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button volume_down
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button next_track
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button prev_track
16:51:03 M: 48721920 ERROR: Keyboard Translator: Can't find button launch_mail
16:51:03 M: 48975872 NOTICE: Network: Using dashboard IP settings
16:51:03 M: 48672768 NOTICE: Checking the Date!
16:51:03 M: 48672768 NOTICE: start dvd mediatype detection
16:51:03 M: 48607232 NOTICE: initializing playlistplayer
16:51:03 M: 48607232 NOTICE: DONE initializing playlistplayer
16:51:03 M: 48599040 NOTICE: load default skin:[Project Mayhem III]
16:51:05 M: 44322816 NOTICE: initialize done
16:51:05 M: 44322816 NOTICE: Running the application...
16:51:06 M: 41426944 NOTICE: -->Python Initialized<--
16:51:06 M: 41406464 NOTICE:
16:51:06 M: 40882176 NOTICE: XBFileZilla: Starting...
16:51:06 M: 40816640 NOTICE: ES: Starting event server
16:51:06 M: 40816640 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:51:06 M: 40804352 NOTICE: UDP: Listening on port 9777
16:51:07 M: 30597120 NOTICE: Q:\system\python\python24.zlib\regsub.py:15: DeprecationWarning: the regsub module is deprecated; please use re.sub()
16:51:07 M: 33423360 NOTICE: warning: Computing default hostname
16:51:07 M: 33669120 NOTICE:
16:51:07 M: 33624064 WARNING: Untested function dllgethostbyaddr called!
16:51:07 M: 33357824 NOTICE: Chat Server (V1.7) started on port 8888
16:51:07 M: 32301056 NOTICE:
16:51:08 M: 29478912 NOTICE: XBFileZilla: Started
16:51:14 M: 36335616 NOTICE: MythBox: platform = win32
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\src
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\pyxcoder
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\decorator
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\odict
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\elementtree
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\tvdb_api
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\themoviedb
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\IMDbPY
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\simplejson
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\shove
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\MySQLdb
16:51:14 M: 36335616 NOTICE: MythBox: syspath += Q:\scripts\MythBox\resources\lib\MySQLdb\win32
16:51:15 M: 35008512 NOTICE: MythBox: loggerIniFile = Q:\scripts\MythBox\mythbox_win32_log.ini
16:51:15 M: 34988032 NOTICE: DEBUG | mythtv.core | default.py | Line 104 | Mythbox Logger Initialized
16:51:15 M: 34988032 NOTICE: .
16:51:16 M: 33013760 NOTICE: ERROR | mythtv.core | default.py | Line 162 | Initializing stage 2
File "Q:\scripts\MythBox\default.py", line 152, in ?
import mythtv
File "Q:\scripts\MythBox\resources\src\mythtv.py", line 21, in ?
import domain
File "Q:\scripts\MythBox\resources\src\domain.py", line 29, in ?
from ffmpeg import FFMPEG
File "Q:\scripts\MythBox\resources\lib\pyxcoder\ffmpeg\__init__.py", line 1, in ?
from subprocess import Popen
File "Q:\system\python\python24.zlib\subprocess.py", line 368, in ?
ImportError: No module named msvcrt
16:51:16 M: 33013760 NOTICE: .
16:51:20 M: 33468416 NOTICE: Traceback (most recent call last):
16:51:20 M: 33468416 NOTICE: File "Q:\scripts\MythBox\default.py", line 168, in ?
16:51:20 M: 33468416 NOTICE: class Window(ui.BaseWindow):
16:51:20 M: 33472512 NOTICE: NameError
16:51:20 M: 33472512 NOTICE: :
16:51:20 M: 33472512 NOTICE: name 'ui' is not defined
16:51:20 M: 33472512 ERROR: Scriptresult: Error
2009-07-31, 21:05
The README clearly states that the Xbox is not supported.
2009-08-01, 02:41
Oops, I forgot to RTFM.
Any recommendations from anyone on any alternatives that are XBox friendly?
2009-08-03, 19:48
Bedlore Wrote:@analogue
If Xebian was installed on a XBox would MythBox then run on it?
I don't see why not.
2009-08-10, 08:59
Bedlore Wrote:Oops, I forgot to RTFM.
RTFM again
http://wiki.xbmc.org/?title=MythTV#Myth2....28Xbox.29
2009-08-10, 09:00
I couldn't get it working on Arch Linux - filled out a report
http://code.google.com/p/mythbox/issues/...1&q=dlopen
errors:
Unknown dlopen() error
error python script failed
special://home/scripts/mythbox/default.py
errors:
2009-08-10, 15:16
I have installed MythBox without any difficulties, but there is one thing that keeps bugging me: I can't change the order in which TV channels appear in the TV guide screen.
I have resorted the channel table in the MythTV db (with phpadmin or in MythTV backend), but the order in MythBox TV guide remains the same as mc2xml created it (great xmltv grabber by the way!). I can't change the channel order that mc2xml creates...
I have been looking at the MythBox source, and I tried to make some adjustments to mythdb.py I changed the sort property in the SQL GetChannel statement from:
to:
but that screwd up the TV guide info (no data for most channels anymore).
Does anyone know how to change the order of the channels in TV guide?
I am using: mc2xml < MythTV < MythBox < XBMC
Any help would be greatly appreciated!
$p00f3r
ORDER BY ch.chanid
ORDER BY ch.channum
$p00f3r
2009-08-10, 22:23
First: Brilliant front-end!
I'm on an amd64 Linux system so I had to try it through a VMware image. What's the reason for it not working on 64bit Linux? It just dies and I can't find any error in the XBMC log nor the MythBox log. Any pointers?
EDIT:
These are the last eight lines in the xbmc.log:
EDIT2:
I now know that it crashes on
EDIT3:
I copied the settings.xml file from my VMware-appliance to my amd64-box and did some more debugging. If I comment out the line
/F
EDIT:
Quote:23:00:59 T:3706878288 M:3233386496 DEBUG: xbp_dlopen loading python lib /usr/share/xbmc/system/python/python24.zip/_bisect.so. flags: 2
23:00:59 T:3706878288 M:3233386496 DEBUG: Loading: /home/user/.xbmc/temp/_bisect.so
23:00:59 T:3706878288 M:3233386496 DEBUG: RegisterExtensionLib, adding _bisect.so (0x35ce370)
23:00:59 T:3706878288 M:3233386496 DEBUG: xbp_dlsym - load symbol init_bisect
23:00:59 T:3706878288 M:3232669696 DEBUG: xbp_dlopen loading python lib /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/linux64/_mysql.so. flags: 2
23:00:59 T:3706878288 M:3232669696 DEBUG: Loading: /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/linux64/_mysql.so
23:00:59 T:3706878288 M:3232260096 DEBUG: RegisterExtensionLib, adding _mysql.so (0x3702da0)
23:00:59 T:3706878288 M:3232260096 DEBUG: xbp_dlsym - load symbol init_mysql
EDIT2:
Quote: import mythtvin default.py
EDIT3:
Quote:import MySQLdbin mythdb.py it continues on past the line
Quote: import mythtvin default.py and I get into the plugin but with an error message starting with "Settings Error: Coect to MySQL failed: global name 'MySQL...."
/F
2009-08-10, 23:06
beatbreaker Wrote:I couldn't get it working on Arch Linux - filled out a report
errors:
I removed /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/MySQLdb and then copied /usr/lib/python2.6/site-packages/MySQdb to that location.
$rm -r /home/[i]user[/i]/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/MySQLdb
$cp /usr/lib/python2.6/site-packages/MySQLdb/ /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/MySQLdb
Then I removed _mysql.so in the MythBox "linux" directory and replaced it from one from my system.
$rm /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/linux/_mysql.so
$cp /usr/lib/python2.6/site-packages/MySQLdb/_mysql.so /home/user/.xbmc/scripts/My Scripts/MythBox/resources/lib/MySQLdb/linux/_mysql.so
Although my recordings crash when I try to play them, but, I believe thats a seperate issue (MythBox runs and LiveTV plays just fine for example).
Edit: The stability issue may be w/the xbmc-svn build I'm using?
2009-08-11, 09:29
Artebonz Wrote:Although my recordings crash when I try to play them, but, I believe thats a seperate issue (MythBox runs and LiveTV plays just fine for example).
I'll give it a try and report back, thankyou. Are you playing recorded tV over samba? Mounting it locally usually solves it for me tho uve prob already tried
