(2012-04-18, 23:53)ruuk Wrote: [ -> ]Version 0.9.26
Changes:
- Handling for nested quotes
- Quotes are now colored
- Selected thread text fixed to white in light skin
- Lightened unread thread text slightly in dark skin
- Fixed (I hope) responding to remote back button (for asking to exit)
On my REPO.
test
Hi ruuk
Had a good old test, and it's really quite quick to navigate between all the forums, threads and posts, and quick to change between the different installed forums it will impress when it's in the main repo.
Some things i've noticed
The bold unread posts work properly now, so when going into a bold thread, looking at posts, and coming back out to threads, the threads are no longer bold.
The bold feature looks like it's only active in the XBMC.org forum, i've tried Boxee etc and didn't see any bold threads.
Boxee is not showing post numbers only a zero for every post
vw vortex forum is not showing full screen posts
It might be an idea to have all the bells and whistle on the xbmc.org forum and the basics on the other forums as there seems to be little niggles appearing on various other forums, what do you think.
disregard any that you see fit to add to your TO DO list, or any that just won't work or have been disregarded already or you have already listed.
Adjustable text size
signature
reputation maybe with future tapatalk plugin update
confirmation dialogs for add to favs/remove from favs,
confirmation dialogs for forum added to local m/c,forum removed from local m/c
option to add a forum to online database once happy with it,
Subscribe/unsubscribe at forum/thread level
smiley faces
view video links?
fanart
forum browser user guide?
option maybe to open forum browser straight on your subscriptions page/list
New update
backing out of forum browser now works with back button on remote
Darkened areas are now white text,much more visable
Quotes are different color, blue, but only at thread level not on full screen post
thanks for new update
I'm off to bed now
atb
John
http://homepage.ntlworld.com/john.hanselman/
