Hi ruuk,
did dome more testing, using xbmcbuntu, Confluence, FB v1.3.4
My Tapatalk activity is still showing me viewing my profile all the time.
Good idea to be able to browse to a url when changing logo's. I like the way you present the current logo's address in the keyboard when changing logo. The url based changing of logo's is working really well, the one I did worked great and is a much better logo than the auto scraped offerings. On a side note after typing in the url for the logo, then pressing done on the onscreen keyboard, the forums list is not getting refreshed with the new logo, you have to go out of the forum list and back in again to see the new logo.
Can confirm the cached logo's are being deleted ok.
The forums settings window where you choose the colour, logo & description is working great.
The wrench icon is a nice icon and does what you are aiming for, but it could do with a better colour background than grey as it tends to blend in too much, maybe a red background.
Search threads option from forums window context is working really well, I like how the search terms are in red & the partial matches are in yellow.
Good call on the "New search" buttons focus, ie when you do a quick repeat search the time restriction window appears, the "New search" button is still focused for you to try again after the time limit expires, & what I really like is the search terms are still typed in ready to go.
Thread searching is working great.
If using the "Search posts" from the button on main screen, you are presented with a list of results, if you go into any post, then come back out again the post title thread topic says "none" but before it said the title, not sure if this is the desired effect you were after ?.
when turning on "Searching posts: open thread on post click" in settings this stops the posts from being able to be displayed full screen when selecting the posts. ie with "Searching posts: open thread on post click" switched "off" you get a list of individual posts relating to your search term, click on one and it goes fullscreen. If you have "Searching posts: open thread on post click" switched "on" then the posts won't go fullscreen. I actually prefer the context menu entry of "open post thread" the context menu option works nicely.
help for "Searching posts: open thread on post click" is fine.
Swapping over the settings button with the forums button on main page makes great sense for the everyday user, thanks for asking first
Searching user posts button is another function I use regularly in a browser, but once you've typed the name of the user could you just browse the users post with the latest one first, instead of typing in a search term as well, or is this an xbmc.org limitation ?.
The forums window is looking top notch I really like it.
Web viewer pulled version 0.9.6 ok
How do I instigate a Share social import ( I've done a fresh install, got rid of all old settings folders etc etc.) tried for 10 mins but couldn't get it to activate.?
Now you've implemented a comprehensive search system, could I ask for a saved search list somehow like in your google images add-on, or what I would find useful is that the last typed entry into the keyboard appears the next time you pull the keyboard to the screen,(just trying to save typing with the remote) what do you think ?
I really like the direction your taking this project in, you look like your devoting a lot of spare time to it & it really shows.
I will continue to test it till it breaks over the coming days. Ignore any of the findings if they relate to any problems that you already know about & have mentioned already.
Over & out, awaiting your next release
![Wink Wink](https://forum.kodi.tv/images/smilies/wink.png)
