2012-05-25, 17:12
(2012-05-25, 16:43)hasselhof Wrote: [ -> ]with the above in mind I went onto forum browser, I PM'd myself, got a green box ok, waited five minutes (it's far less waiting time I know), PM'd myself again got another green box ok. So that solved the glitch with the "error getting posts" message.IE wait a little in between posting. I suspect you may not have any control over the message, but it may be better to say "wait .....seconds before posting again"., instead of "error getting posts"Well, the error getting posts message maybe should be changed to PMs when it's PMs but that particular error occurs when it's trying to refresh the PMs and fails. Which is why it says what it says, and why the list wouldn't be updated.
(2012-05-25, 16:43)hasselhof Wrote: [ -> ]I had thirteen messages in my inbox, I deleted them all no problems until the last one, I got the green box "message deleted", but the last message stayed visable, I had to go out of PM's and back into PM's to see the last one disappear. I seem to remember you saying that your were going to fix that, so maybe it's in the next release.If there was no error, then perhaps there is some issue with deleting the last post. I'll check it out.
(2012-05-25, 16:43)hasselhof Wrote: [ -> ]What I did notice, (again if you have mentioned it in the todo list, or it can't be achieved just ignore), but I had 13 messages 5 unread 8 read forum browser saidThe counts are gotten from the taptalk plugin. They should represent what you see in the browser. If not, there's not a lot I can do about that. I think probably that when you read a PM from FB it's not getting marked as read. There may be a way for me to fix that if that is the case.
13/13 , or is it supposed to be like that?
(2012-05-25, 16:43)hasselhof Wrote: [ -> ]I suspect that you have been watching Duran Duran via forum browser ?Indeed, and with the next update you can too. I broke a release candidate rule and added a feature. I was processing <embed> videos as links in the general browser and I thought, this would be easy to make playable because I already have the code in my ShareSocial addon.
I'll have to find tapatalk and forumrunner forums that have video embedding enabled to see if I can play those (as opposed to links)
In any case, right now it should work with YouTube, Vimeo and Flickr, though I've only tested with YouTube so far.
