2012-05-27, 15:18
(2012-05-27, 14:06)ruuk Wrote: [ -> ](2012-05-27, 08:34)hasselhof Wrote: [ -> ](2012-05-27, 02:29)ruuk Wrote: [ -> ]And this had the same behavior? 'No Messages' in the title and the deleted message stays?
Yes ,to both sorry forgot to say
It sounds like this happens every time you delete the last post. Since it never happens to me, I think is must be a bug with xbmc either related to your xbmc version or the OS. I guess I'll finally update to the newst XBMC version (I'm still on 10) and see if I get the same result. If not I'll still try a workaround and have you test that.
Hi ruuk,
It does exactly the same on my windows machine, whereby it confirms deletion of PM, but the message is still visible
Windows log
Both my machines run Eden.
I might do a complete uninstall of forum browser, web viewer, and all related folders, and see if it still does it.
Go on step into 2012 yourself, and I will see you on the other side.
