Hi ruuk,
Thanks for updates V1.0.8, V1.0.9, V1.0.10 much appreciated
All testing was with V1.0.10 active
Here are some of my findings
Signatures show ok in posts in "XBMCHUb.com" and "webuser" to name a couple.
The new setting option for "Hide signature" is working ok.
I haven't came across any "User info" windows that require to scroll yet, will keep an eye out.
In "Tapatalk" the how long ago on activity now shows 0 secs for my initial time, but reverts back to just the word "ago" without a time, for the rest of my stay
other users time show up fine.
There is a definite improvement in the logo detection.
View forum info is a very interesting addition, and works a treat.
When adding forums (which were previously working in the experimental section) into the normal "Add a forum" section it asks me the following question
"Does this forum require a login ?" now I'm not sure in what context the question is in. It makes me think that it's asking me do I know weather or not the forum requires a login for the forum to be viewable, IE only members can view, or is it asking me for my personal log in details for that forum ?. If I say "Yes" I get reverted back to the previously active forum with no message see
log, but if you say "No" It then tells you about the current pitfalls / limitations, then the forum goes on to be successful and works really well, When setting login details via the setting "set logins" I get a red screen see
screenshot &
log it looks like you may have left some reference to a piece of test code.
When I added torrentday.com to FB I declined the "Does this forum require a login" yet it still logged me in, is this the cookie still on my machine ?.
Activity splash appears ok when getting forum list from online database.
The database is a work of art, I especially like the splashes of colour, big thumbs up (I like colour). I've added a couple of forums to try it out and it works great
was able to choose which category to plop it into.The interface type is also interesting.I'm glad you kept the "View all" option as well.
It seems that the "Add current forum to online database" may be broken, it starts to process my action then just reverts back to the active forum see
log
Also if I add a forum to the online database that is already in there it doesn't tell me so (I'm sure it did do in the past).
here's one for you,
http://recipehelpers.com/forum/ is detected ok as a forumrunner forum with a green box,I then click ok, and it does nothing else, it fails to add it to my local list of forums see
log
After updating to V1.0.8 (where you mixed the experimental into the main "Add a forum flow") I lost all my experimental working forums
, as they weren't on the online database I didn't have a backup, so I did a roll back to V1.0.7, retrieved them all and reapplied them all
Again thanks for the updates.
All the best
John.
PS, Is it possible to have my wages put back to the appropriate rate, I tell you, you can't get the staff these days
