2013-01-27, 21:14
(2013-01-27, 21:08)ruuk Wrote: [ -> ]Holy crap, there's almost 450 forums on the online database!
Just goes to show that a lot of people are using Forum Browser without problems due to your programming being so good
(2013-01-27, 21:14)hasselhof Wrote: [ -> ]That or they don't know about this thread yet...(2013-01-27, 21:08)ruuk Wrote: [ -> ]Holy crap, there's almost 450 forums on the online database!
(2013-01-28, 01:03)carmen Wrote: [ -> ]ruuk: posting as my wife again because I need a new post.
(2013-01-29, 01:07)Martijn Wrote: [ -> ]Does it hang in some loop then?It's not during a loop. I listen for xbmc.abortrequest in my service, but this is not in the service, this is just when sitting on the main window of the addon, which has no loops running. The window is modal and the init functions are done when I try to shutdown XBMC.
If you can provide some more info in what direction to look.
I presume you already listen for xbmc.abortrequest status ?
(2013-01-29, 21:17)jfcarroll Wrote: [ -> ]If the doModal is called in a python created thread, this bug was fixed a couple days ago and the fix made it into Frodo. If not, let me know.
(2013-01-29, 22:48)hasselhof Wrote: [ -> ]Hi ruuk, xbmc.org is really busy obviously for new Frodo release , so forum browser is really slow for me, and is timing outThat's how I realized the release was available.
(2013-01-29, 22:48)hasselhof Wrote: [ -> ]I've done some testing but only a little, for the reason I will explain in a moment.Well, there is some new code that would probably cause what you described if it caused an error. So if when you can get me a log, I'd love to look at it.
Testing on Frodo rc3 - XBMCbuntu
When adding a forum from the online database, it now returns to the list ok.
When removing a forum from the local database, it now returns to the list ok.
When I select "options" nothing is activated the screen just sits there, as if focus is lost.
I'm still able to move about and highlight everything including forums, but clicking everything nothing happens.
My problem is that I cant ssh into XBMCbuntu usb install via winSCP from windows pc for some reason to retrieve the log for you.
I have xbmcbuntu rc3 on a usb for testing, so my eden hard drive install is still safely intact.
When the Frodo final is released for XBMCbuntu I will install to the hard drive and be able to get you the log & do more testing.
Cheers
John.
