2012-05-07, 20:54
(2012-05-07, 20:50)ruuk Wrote: [ -> ](2012-05-07, 20:28)dj_gerbil Wrote: [ -> ]Hi ruuk, just test the latest build on TVC's forum to see if I can delete a post and I can't. I get an error saying "I might not have permission". I've posted my log for you here. Hope it helpsWas it your own post (this probably shouldn't matter, but is useful to know)? There's no more info in the log than the message you get (and there's no error)
It may be that either it's not enabled in the Tapatalk config for the forum, or that it doesn't work on some plugin versions. I'll probably just leave it as is as it may work for some situations, and only moderators are going to be able to do it right now anyway.
It was perhaps useful to see some flags that are set when your a moderator.
You at least confirmed that it's detecting your moderator status and allowing the delete option to show.
It was my own post, although as you say, it doesn't make any difference as I'm a super mod. I've deleted posts before using the TapaTalk app on my phone so it should have worked. Glad the rest of the info was useful, let me know if you need me to test some more
