Hi ruuk, did some more testing tonight using v2.1.43 on xbmcbuntu, with Aeon Nox skin.
Everything so far is really working nice, I really like this 'Sequel' skin.
This is the white area I was talking about, is it by design or should the threads be right at the top ?.
The threads in
this screenshot are all in capitals which looks really effective, can this be done for xbmc.org, & xbmct*lk as well or is this how it's fetched from the website.
In the 'unread threads window you get some 'last post' info see
screenshot which is nice,
but on the 'posts view' there is no 'last post' info see
screenshot, is it possible to add it ?.
There is no header description in the subscription window see
screenshot & should the create thread button be there ?.
I'm using the Aeon Nox skin which somewhere inside this skin (I think) it has this lovley mottled effect overlay which I can't find the actual file, but looks really cool, see
screenshot. I would love to be able to use this as an all over effect ie on every screen, just to see what it looks like. It only appears sometimes for example when clicking search as in screenshot. I don't know if you can find it for me to try ?. but only if you still have Aeon Nox skin installed
The colour changer is very comprehensive & works very well indeed as you can see from my screenshots. Its so much easier to use now you have added the six starting point colours. It works really well.
I like the forum manager new menu, the whole arrangement of the skin is very smooth, I like the red line to delete a local forum. The forums database is really neat as well, the new forum icons look great.
I've added quite a few different forums and they all worked no problems
Thanks very much for all the updates, I will take another close look tomorrow and feedback any findings.
