2013-11-18, 22:58
(2013-11-18, 22:37)hasselhof Wrote: [ -> ]I really like the new 'Sequeal' wip skin, it will be my new skin of choice
(2013-11-18, 22:37)hasselhof Wrote: [ -> ]When previewing images in post view, pressing left keeps you continually focused on the thumbnails, pressing right after you've get to the last preview image jumps onto the three new buttons, could the focus be kept on the preview thumbnails, continually rolling round the preview images. Then to get to the three button press up ?.I don't like it either. I'm trying to figure out how to get around it. The problem is that I want it to go to the image list when you press right when you are focused on the post (up works as well but if you are at the bottom of a long post you have to scroll to the top first). But if the images are hidden, and the image list isn't set to go somewhere when you move right, then nothing happens. The other option is to have it go to the buttons when you press right from the post, but I don't really like that either.
What I really want is it that when you press right from the post it goes to the images (or if they're hidden, it goes to the buttons) and have the image list behave as you said. Hopefully I can figure something out.
(2013-11-18, 22:37)hasselhof Wrote: [ -> ]What I would like if it's possible / no trouble, when you get time is to be able to add things like 'Subscriptions' folder to XBMC favs, and add individual forums to XBMC favs, this would be useful for sub menus in skins like Aeon Nox.Just to be clear, you'd like to be able to add forums to the XBMC favorites so you could jump to them directly? I'll look into how I can get something into the XBMC favorites when I get the chance.
(2013-11-18, 22:37)hasselhof Wrote: [ -> ]Thanks very much for the new skin, & I will continue to check it out.I'm glad you like it. I'll be continuing to improve it. Please let me know where it needs improvement. For example I just decided that I probably need to have a color when highlighting a selected item (forums and threads). The gray tends to get lost on some backgrounds and also some of the item text gets lost against the gray on some backgrounds.
I'll probably default it to blue and make it changeable per view.
